Ebay light bulb 360 1080p android compatible
rangerbob
Post by rangerbob »
has anyone tried any of these new cameras built into led light bulbs with 360 Panoramic views that have speaker / mic and have a motion detector? this sounds like a great door or hallway cam.
They mention no ports for router and cloud alot. The descriptions usually mention not compatible without IE or chrome. so I wounder has anyone wiresharked or tcpdumped this to see if it is able to be supported on zoneminder..
https://www.ebay.ca/itm/360-Mini-Securi ... :rk:8:pf:0
https://www.aliexpress.com/w/wholesale- ... eedQuery=n
these look pretty cool. be nice if motion would trigger alarm on zoneminder and if they can be made to work and block cloud
Re: Ebay light bulb 360 1080p android compatible
ZM is definitely going to need a de-fisheye filter for that...
rangerbob
Post by rangerbob »
has anyone done anything with theses yet?
You may be looking at something different, but the ones I bought a couple years ago died before I could figure out how to access them in ZM...
The light they put out was pretty lame, too.
