Can't access API on 1.30.4 and Debian 9
JustinG
Post by JustinG »
Hello All,
My system has been running great for the past year. Recently I upgraded the system from Debian 8 to Debian 9. Everything seems to work fine except the API access. When accessed from a browser, I get an HTTP Error 500.
In my apache error.log, I see the following:
[Mon Jan 29 11:04:32.716667 2018] [:error] [pid 16050] [client 100.x.x.x:39302] PHP Fatal error:  Call to undefined function apc_fetch() in /usr/share/php/Cake/Cache/Engine/ApcEngine.php on line 91
After I've researched the other forum posts with the same issue (viewtopic.php?f=36&t=26140 and [url]viewtopic.php?f=36&t=26122[/url)], and they stated to install php-apcu-bc and cakephp. Tried to install them but my system says they're already installed:
cakephp is already the newest version (2.8.5-1).
php-apcu-bc is already the newest version (1.0.3-2).
I even tried re-installing the zoneminder package, as well as the cakephp and php-apcu-bc package, but no luck.
Some more info for troubleshooting:
PHP Version: PHP 7.0.27-0+deb9u1 (cli) (built: Jan 5 2018 13:51:52) ( NTS )
Apache2 Verison: 2.4.25
ZM Version: 1.30.4
OS: Debian 9 Stretch
Any help would be greatly appreciated.
Re: Can't access API on 1.30.4 and Debian 9
JustinG
Post by JustinG »
Hello bbunge,
Thank you for the suggestion. I checked permissions and www-data was already chown-ed to that folder.
I re-ran the command anyway, but I still get an HTTP Error 500 when trying to access anything related to the API.
You may want to force a reinstall of Zoneminder 1.30.4 and include vlc-plugin-base php7.0-gd.
See: https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
mic07
Post by mic07 »
Hi Justin!
I'm not sure how the package names under debian are, but since you are using php7.0, did you check if there is a package for php7.0? like php7.0-apcu and php7.0-apcu-bc
what's the output of
apt-cache search 'php.*apcu.*'
BR Michael
JustinG
Post by JustinG »
Thank you all so much for your posts, I do appreciate it.
I should note that I was able to replicate this in another one of my systems. It seems the issue occurs after upgrading a Debian Jessie (8) box to Debian Stretch (9).
I've tried re-installing the zoneminder package, but no avail. I tried the following command:
apt install --reinstall zoneminder
Should I try the reinstall a different way?
Also the output of the apt-cache search command is:
php-apcu - APC User Cache for PHP
php-apcu-bc - APCu Backwards Compatibility Module
php-symfony-polyfill-apcu - Symfony polyfill backporting apcu_* functions to lower PHP versions
I ran a apt install for all the php-apc packages there, but they're already installed.
php-apcu is already the newest version (5.1.8+4.0.11-1).
I have deployed about 5 ZoneMinder boxes to my friends and family all seeing the same issue when updated from Debian 8 to Debian 9. (All boxes configured the same way at the beginning).
Thanks again for your time.
are all the directories that need to be in place correct? such as
/usr/share/zoneminder/www/api/app/tmp/cache
and can it e written to by www-data?
make sure
/usr/share/zoneminder/www/api/app/tmp/cache/models
and
/usr/share/zoneminder/www/api/app/tmp/cache/persistent
exist and are writable by www-data
JustinG
Post by JustinG »
Thank you so much for the suggestion.
I confirmed those directories do exist. www-data has full read+write permission to them.
I still however get an error 500.
And in Apache's error.log:
[Sun Feb 11 23:45:08.713776 2018] [:error] [pid 12126] [client 100.x.x.x:56877] PHP Fatal error:  Call to undefined function apc_fetch() in /usr/share/php/Cake/Cache/Engine/ApcEngine.php on line 91
This is such a strange issue. I double checked on my other box having issues as well and same thing, the directories exist and www-data has full permission to them, but I still get an error 500.
Am I going to have to completely re-install these boxes? :(
I have a DebianDog (Debian 9 Stretch based) set up running with ZM 1.30.4 at my fingertips at the moment...I used the Debian zm install notes and the system is up and running and ZM shows a green Log indicator......so far the http://zm-server/zm/api/host/getVersion.json is returning the correct response...but I do remember not being able to get zmNinja to run with the Debian setup. While I have this going I will test out some stuff and see if we can get to the bottom of this....I recall having some strange nagging little problems in the Debian 9 setup that do not appear in the Ubuntu setup.
JustinG
Post by JustinG »
Interesting.
I can confirm when a clean install is performed on Debian 9 it works fine. I've only had this issue with boxes upgraded from Debian 8 to Debian 9. Out of 3 boxes I've upgraded, all 3 were effected.
What a strange issue. Oh well, I'll re-install them with a clean Debian 9 sometime later this week.
mic07
Post by mic07 »
Maybe this thread can help (I had similar problems with Debian 9 on Tinkerboard):
ZM 1.30.4 API issue on ubuntu 17.10
