Can't initiate email notifications
Re: Can't initiate email notifications
da7, welcome to the club of the befuddled!
What do you have for a ZM filter? Can you execute it directly and is it coming up with matches? (and I'm assuming that "Email details of all matches" is checked/enabled)
I enabled debugging on zmfilter and I'm still not seeing anything that points to the problem! Alarm states are happening, and events are being captured but zmfilter isn't being called.
BTW - Here's someone else that had this problem. No solution was given. I've PM'd this person but have not heard back, yet.
viewtopic.php?t=24652
Bump...
This issues is driving me nuts.
I am able to trigger an event. Logs show going in and out of alarm mode. No traces of zmfilter running at all. If I run the filter manually I can see the event I just triggered; but, there is NO attempt to invoke email. System shows that the zmfilter.pl process is running.
Well, a bit of a snafu on my part. I wasn't actually executing the filter, I was just submitting. BUT, the Execute button is not enabled. This may very well be at the heart of the problem. I'm logging in a Guest and perhaps I don't have permissions set that allow me to execute? But, this doesn't answer why the system isn't executing.
OK... I am able to execute my filter from the terminal: I have e-mail authentication issues, but, again, that's a totally separate matter.
http://zoneminder.readthedocs.io/en/sta ... vents.html Troubleshooting tips mentions possible problems with the filters running this way (directly from Perl), but in my case it's the opposite: works via Perl, doesn't work within Zoneminder (either automatically or manually [I can't even select "Execute"]).
I do get log entries when executing the filter from a terminal. But nothing of value for the actual problem.
UPDATE:
I now have ZM invoking zmfilter and the email function. So, as far as ZM is concerned I'm all configured correctly. What made it "work?" Not completely sure. I updated the system (Debian 9), though I don't think this was the thing that did it because it had been working previously. The other thing I did was to set the filter's "Archive all matches" bit.
ZM now shows it has attempted to send email. It's now failing as I expect, due to authentication issues with ssmtp and hotmail. I don't have certificates on the system and I'm thinking that I'll need to set them up in order to make this work: not sure how it could have worked before, though.
SOLVED
Educational process for sure.
I had not realized that in order to automate filters one had to set/check "Run filter in background." Thought that their existence as filters would mean they were all considered for every event.
Seems obvious now, but... The documentation mentions this but only in a more side-note kind of way.
I've been working on...experimenting with ZM since version 1.24 and still am mystified at times....and forget solutions for problems already solved....bad notes to myself......
Re: SOLVED
Someone said to make sure you have set it to run in the background in post #2. Just saying...SkippyDo wrote: ↑Sat Jan 13, 2018 9:40 amEducational process for sure.
Re: SOLVED
Yes, and I was thinking that that was more of a workaround rather than "how it should be done." Like I said, the documentation could be a little more forward on this point.montagdude wrote: ↑Mon Jan 15, 2018 3:06 pmSomeone said to make sure you have set it to run in the background in post #2. Just saying...SkippyDo wrote: ↑Sat Jan 13, 2018 9:40 amEducational process for sure.
Users browsing this forum: No registered users and 10 guests
