to polish language
If you would like to check the status of a language, volunteer to do a translation, or highlight or correct a problem in one of the existing language files then post here.
ALU
to polish language
Post by ALU » Mon Sep 27, 2004 8:17 am
Hi!
Aslo I can translate to polish - instalation guide.
Regards
rdmelin
Post by rdmelin » Mon Sep 27, 2004 1:53 pm
Very good. I was planning to get the new version out in the next few days and the polish translation is still missing.
Best regards
Ross
tomkolp
Re: to polish language
Post by tomkolp » Tue Dec 18, 2012 7:05 pm
Polish translation of 87%. The rest soon.
Polskie tłumaczenie 87%, przetłumaczony kawałek opcji. Mile widziana pomoc w tłumaczeniu tekst w opcjach.
pl.tar
Polskie tłumaczenie 87% /var/www/html/zm/lang/
+ fix umożliwiający przetłumaczenie opcji
/var/www/html/zm/skin/classic/views/
(70 KiB) Downloaded 445 times
loguky
Post by loguky » Thu Jul 06, 2017 12:46 pm
If you look for some help with the polish translation - you can always write me a PM.
To want to, is to be able to.
