Aviosys IP Kamera 9060
bainssu
Post by bainssu »
i bought a few of these kits as i was so impressed with the camera and general function and the price having come right down to about 40 pounds for the kit form..!!. I have made a slighty modification to the original script .. (I'm a perl novice)..! I've just added a rename so that the file generated isn't picked up too early ..!
#!/usr/bin/perl
use IO::Socket;
my $iphost="192.168.11.29:80";
my $frame_count=25;
my $image_filename="ip_Kamera_9060_1";
my $no_print_data;
my $target_path='/cgi-bin/Stream?Video';
my $debug=0;
sub main {
my ($heraddr);
RECONNECT:
$t=0;
print STDERR "connecting to $iphost\n";
do {
$F = IO::Socket::INET->new(
PeerAddr => $iphost,
Proto => "tcp",
Type => SOCK_STREAM,
Timeout => 10) ;
$t++;
die ("Socket fail : $!") if $t > 10;
} while( $F == undef );
print STDERR "Connnected\n";
$qu = "GET $target_path HTTP/1.0\r\n" .
"Accept: */*\r\n" .
"Keep-Alive: 300\r\n" .
"Connection: keep-alive\r\n" .
"Cookie: webcamPWD=RootCookie00000\r\n" .
"User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)\r\n" .
"\r\n";
print $F $qu;
#print $D $qu;
while ($j = read($F, $data, 20) ) {
#print " j = $j\n";
@a = unpack('v10', $data);
if ($debug) {
for $i ( 0 .. $#a ) {
#print $D "$i = $a[$i]\n";
print "$i = $a[$i]\n";
# make sure er got pre-image header.
unless ($a[0] == 10794 && $a[3] && $a[4] && $a[5]) {
close($F);
print STDERR "bad header image $image_filenam\n";
goto RECONNECT ;
$j = read($F, $data, $a[1]) or die ("bad read: $!");
open(J, ">$image_filename.JPG");
print J $data;
close(J);
# $image_filename++;
rename("ip_Kamera_9060_1.JPG", "front_camera_1.jpg");
#last unless --$frame_count;
&main;
exit;
zoneminder
Site Admin
Post by zoneminder »
Thanks for this. When you say you got the camera in 'kit form' what do you mean? No case and just pcbs etc?
Phil
bainssu
Post by bainssu »
Yes that's right the kit is basically a pcb with an ethernet and power connector, a ribbon cable and a camera on a seperate pcb connected via the ribbon cable.
here are details of where I bought it
http://www.digidave.co.uk/product_info. ... cts_id=231
regards
Surj
zoneminder
Site Admin
Interesting, thanks.
Phil
unclerichy
Re: Aviosys IP Kamera 9060
Post by unclerichy »
bainssu wrote:i bought a few of these kits as i was so impressed with the camera and general function and the price having come right down to about 40 pounds for the kit form..!!.
To be fair for the price they're not bad, but no way can they be considered low-light cameras (as it says on the various sellers' sites). I have a street light directly in front of my house and that doesn't give sufficient light for one of the cameras when it's in my bedroom window. My 'real' cameras (a 'mini' camera' and a bullet camera) can both see without a problem.
Similarly the picture's very low quality with numerous odd shades of red and green - a symptom of it being a CMOS lens rather than a CCD.
None the less, the fact that the camera can be tucked away discreetly somewhere makes them interesting :wink:
alexcami
Post by alexcami »
bainssu wrote:I have made a slighty modification to the original script .. (I'm a perl novice)..! I've just added a rename so that the file generated isn't picked up too early ..!
Instead of getting single frames from Aviosys camera, is it possible to get directly the video streaming ... ?
Is this less CPU intensive for the ZM Server? :?
bainssu
9060 streaming video
Post by bainssu »
I think you can get a stream of jpegs in the mjpeg format.
Here is a script I found on the net for doing just that..
usage perl ip_video.pl >out.mjpeg. I haven't got zoneminder to pick this up yet... however videolan works fine...
#!/usr/bin/perl
use IO::Socket;
my $no_print_data;
my $target_path='/cgi-bin/Stream?Video webcamPWD=RootCookie00000';
my $debug=0;
sub main {
my ($heraddr);
open(STDERR, ">/tmp/debug_stderr"); #unless -t;
# $no_print_data++ if -t;
select((select(STDOUT), $| = 1)[0]);
select((select(STDERR), $| = 1)[0]);
#open($D, ">dat_dump");
#select((select($D), $| = 1)[0]);
#$hersockaddr = getpeername(S);
#(undef, undef, $heraddr) = unpack($sockaddr, $hersockaddr);
#$t=<STDIN>;
$t="GET / HTTP/1.0"; # temp hack
if ( $t =~ /^GET/ ) {
$qu = "HTTP/1.0 200 OK\r\n".
"Server: Perl Hack\r\n".
"Content-Type: multipart/x-mixed-replace;boundary=IPCamBoundary\r\n".
"Pragma: no-cache\r\n".
"Cache-Control: no-cache\r\n".
"Expires: 01 Jan 1970 00:00:00 GMT\r\n".
"\r\n";
print $qu;
} else {
print "HTTP/1.0 404 File Not Found\r\n\r\n";
exit;
RECONNECT:
$t=0;
do {
Proto => "tcp",
Timeout => 10) ;
$t++;
"Accept: */*\r\n" .
"\r\n";
print $F $qu;
#print $D $qu;
$t=0;
#print " j = $j\n";
if ($debug) {
close($F);
print STDERR "bad header image $t\n";
goto RECONNECT ;
print STDERR "Size=$a[1]\tWidth=$a[3]\tHeight=$a[4],Compress=$a[5]\n";
print STDERR "read $j\n";
print "--IPCamBoundary\r\n",
"ETag: image_$t\r\n",
"Content-Type: image/jpeg\r\n",
"Content-Length: $a[$i]\r\n",
"\r\n";
$t++;
print $data or print STDERR " print error: $!\n";
"\r\n";
$#a=-1;
last if $t > 100;
if ($t < 1 ) {
warn("Huh j= $j: $!\n");
sleep 1;
goto RECONNECT ;
print STDERR "t: $t\t", $t / (time - $^T) , "\n";
&main;
exit;
alexcami
Re: 9060 streaming video
Post by alexcami »
Thank You!
this get the stream ... but how to use it with ZoneMinder?
have you tried also to get the audio channel and put all togheter in an MJPEG Stream?
bainssu wrote:I think you can get a stream of jpegs in the mjpeg format.
#!/usr/bin/perl
use IO::Socket;
my $no_print_data;
my $debug=0;
sub main {
my ($heraddr);
    #$t=<STDIN>;
            "\r\n";
    print $qu;
    } else {
        exit;
RECONNECT:
    $t=0;
    do {
            Proto    => "tcp",
            Timeout  => 10) ;
        $t++;
        "Accept: */*\r\n" .
        "\r\n";
    print $F $qu;
    #print $D $qu;
    $t=0;
        #print " j = $j\n";
        if ($debug) {
            close($F);
            goto RECONNECT ;
                "\r\n";
        $t++;
                "\r\n";
        $#a=-1;
        last if $t > 100;
    if ($t < 1 ) {
        sleep 1;
        goto RECONNECT ;
&main;
exit;
bainssu
Post by bainssu »
I'm not sure how to actually use it with zm. They only way I've been able to use the 9060 cameras is by creating an image file on the webserver(previous perl script) and then specificying it as a local file src in the zm config. This works ok for a while but every now and then fails and stops working which isn't great.. how do you currently run it..?
regards
Surj
bainssu
IP_9060 additional tweaks.. and fixes
Post by bainssu »
I've added a script to restart the perl scripts that I was using to feed zm and some modifications to the perl script it self to allow it to work...
stick this file in /etc/cron/hourly
and modify the line near the bottom which points to the perl script (in my case it is in /srv/www/htdocs/)
#!/bin/bash
# restart_ip_Kamera.sh
# This is a script to restart ip_Kamera.
# This can be called from another script which could be monitoring logs or
# detecting bad frames etc............
function kill_Kamera {
        for pid in `ps -ef | grep Kamera_hack.pl | grep -v grep | awk '{print $2}'`
        do
                kill $1 $pid
        done
printf "Performing hard kill on Kamera processes\n"
timestamp=`date`
echo "$timestamp Restarted ip_Kamera" >> /tmp/KameraRestarter.log
kill_Kamera -9
sleep 5
nohup perl /srv/www/htdocs/ip_Kamera_hack.pl &
ps -ef | egrep perl
exit 0
and this one in your document root (in my case it is in /srv/www/htdocs/)
again modifying to point to the right locations and ip
#!/usr/bin/perl
use IO::Socket;
my $frame_count=25;
my $image_filename="/srv/www/htdocs/ip_Kamera_9060_1";
my $no_print_data;
my $debug=0;
sub main {
my ($heraddr);
RECONNECT:
    $t=0;
    do {
            Proto    => "tcp",
            Timeout  => 10) ;
        $t++;
        "Accept: */*\r\n" .
        "\r\n";
    print $F $qu;
    #print $D $qu;
        #print " j = $j\n";
        if ($debug) {
            close($F);
         sleep (10);
     system("nohup ./restart_ip_kamera.sh &");
        print J $data;
        close(J);
        sleep(0.25);
      rename("/srv/www/htdocs/ip_Kamera_9060_1.JPG", "/srv/www/htdocs/front_camera_1.jpg");
&main;
exit;
