Mysql_free_result () called twice to free same result
Paranoid
Post by Paranoid » Fri Jan 15, 2021 1:14 pm
The zmLoadUser function in zm_user.cpp has this section of code:
  if ( mysql_num_rows(result) == 1 ) {
    MYSQL_ROW dbrow = mysql_fetch_row(result);
    User *user = new User(dbrow);
    mysql_free_result(result);
    if (
        (! password )  // relay type must be none
        verifyPassword(username, password, user->getPassword()) ) {
      Info("Authenticated user '%s'", user->getUsername());
      return user;
  }  // end if 1 result from db
If you use a valid username but an incorrect password then mysql_free_result() gets called twice. Once in the first if construct and again when the if finishes.
The code should be:
    if (
      return user;
