HikVision PTZ control
bobylapointe69300
Re: HikVision PTZ control
Post by bobylapointe69300 » Tue Mar 20, 2018 2:56 pm
Thanks for the update. In fact the reply from seller is helping, at least to understand that this camera is not using HIKVISION protocol, but Pelco-D instead. I suspect you are able to use PTZ commands in iVMS-4200 probably because it uses ONVIF (Pelco-D commands get translated via onvif...). Not 100% sure about that, because I thought iVMS-4200 was not accepting 3rd party cameras... iVMS-5200 does.
Codes given by the seller (in the {}) are command strings used by Pelco-D protocol (https://www.commfront.com/pages/pelco-d ... tutorial#3). You find them in Pelco-D for each command (group of figures starting with 0x..).
So your protocol being known as Pelco-D, you should use the Pelco-D protocol present in ZM control. To be honest I have not configured any Pelco-D cameras with this protocol, so I might not help you a lot, but as this is a standard Pelco-D protocol, you should just have to make sure you fill fields in correctly in ZM control. Make sure also at each change you restart ZM.
You may want to continue discussion on a dedicated post as it does not concern anymore HIKVISION protocol.
pat2
Post by pat2 » Wed Mar 21, 2018 8:18 am
uhmmm, interesting comment.
So, you think that camera is not using HIKvision protocol. And they are claiming the HIKvision compatibility on Amazon (and in fact there is compatibility with HIKvision since i'm able to see stream and send PTZ commands with iVMS4200 client) because there is a "Pelco-D to HIKvision" protocol translation via onvif (they claimed too the camera is ONVIF compatible). And it is coherent with the fact i'm not able to reach the standard HIKvision url:
http://<your camera>/ISAPI/System/deviceInfo
So, the protocol to be used is Pelco-D or ONVIF.
Ok, i will try with them and i will move to the proper thread in the forum.
thanks
tomcat84
Post by tomcat84 » Wed Aug 26, 2020 2:43 am
I just tryed to get the DS-2DE3A404IW-DE/W working.
Configured are the following settings:
But its not working and the logs are spammed with:
2020-08-26 04:40:02	zmcontrol_7		16709	FAT	No protocol is set in monitor. Please edit the monitor, edit control type, select the control capability and fill in the Protocol field	zmcontrol.pl
2020-08-26 04:39:22	zmcontrol_7		16622	FAT	No protocol is set in monitor. Please edit the monitor, edit control type, select the control capability and fill in the Protocol field	zmcontrol.pl
2020-08-26 04:39:02	zmcontrol_7		16556	FAT	No protocol is set in monitor. Please edit the monitor, edit control type, select the control capability and fill in the Protocol field	zmcontrol.pl
2020-08-26 04:38:52	zmcontrol_7		16460	FAT	No protocol is set in monitor. Please edit the monitor, edit control type, select the control capability and fill in the Protocol field	zmcontrol.pl
2020-08-26 04:38:46	zmcontrol_7		16379	FAT	No protocol is set in monitor. Please edit the monitor, edit control type, select the control capability and fill in the Protocol field	zmcontrol.pl
2020-08-26 04:38:45	zmcontrol_7		16365	FAT	No protocol is set in monitor. Please edit the monitor, edit control type, select the control capability and fill in the Protocol field	zmcontrol.pl
Any suggestions?
With Blueiris ptz is working so it cant be the camera...
[Edit] got it working.
Only Zoom is not working hm..
JasonBorn
Post by JasonBorn » Thu Jan 14, 2021 8:34 am
@tomcat84
with special help from Paranoid zoom is now working on my system.
Can you send your zoom settings? Maybe i can help you
Paranoid
Post by Paranoid » Thu Jan 14, 2021 10:37 am
Any suggestions?
Go to the screen you show in your post and click "edit" next to the "Control Type".
Scroll down and select HikVision.
In the "main" tab set Protocol to HikVision.
In the "Zoom" tab unset "Can Zoom Relative" and "Can Zoom Absolute". Set "Can Zoom Continuous" and "Has Zoom Speed". Set min speed to 1 and max to 100.
tomcat84
Post by tomcat84 » Fri Jan 15, 2021 1:49 pm
@tomcat84
You are right. Zoom was not working. I didnt even try to use it :lol:
After I changed as suggested from Paranoid its working now.
TY guys :mrgreen:
jperkins
Post by jperkins » Sat Jan 23, 2021 7:31 pm
Thanks so much. I got zoom working on my Anpiz PTZIP204WX4IR Hikvision (OEM DS-2DE2A404IW-DE3).
However I was getting an error when I attempted to 'stop zoom ' . and I believe this error would cause other things to reset
ERR [Can't access name:zoomStop AUTOLOAD:ZoneMinder::Control::HikVision::zoomStop member of object of class ZoneMinder::Control::HikVision from main:186]
I (probably incorrectly ) fixed the issue by editing /usr/share/perl5/ZoneMinder/Control/HikVision.pm
I went to line 187 and copied the line 'sub moveStop ..." as 'sub zoomStop ...'
jperkins@zoneminder:/usr/share/perl5/ZoneMinder/Control$ diff HikVision.pm HikVision.pm.bak
188d187
< sub zoomStop         { $_[0]->moveVector(  0,  0, 0, splice(@_,1)); }
I am willing to make a PR if it is wanted
tommyraton
Post by tommyraton » Sun Jan 24, 2021 5:40 pm
HikVision DS-2CD2743G1-IZS
(This is my 1st post on any forum so if there's formatting I should use, I apologize, and point me to how to be better)
I've got unstoppable focus and unstoppable zoom using the HikVision.pm on this ebay purchased camera HikVision DS-2CD2743G1-IZS
Working only on the unstoppable zoom.
Same error when attempting to stop zoom as jperkins
However the edit as jperkins described did not change the error message in my instance. When one edits the .pm file is that immediately in effect or does one have to stop and restart the zoneminder service to take effect?
Output from
http://<your camera/ISAPI/System/deviceInfo
Note that although the camera is as above a DS-2CD2743G1-IZS, from other error messages I had to use
IP Camera(E2451) for the device (NOT "IP CAMERA" NOT "IP Camera" but "IP Camera(E2451)"
And although I thought this device info implied port 88, had to use port 80 in the ControlAddress
<DeviceInfo xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<deviceName>IP CAMERA</deviceName>
<deviceID>29c30000-6580-11b3-81a1-accb516269ca</deviceID>
<deviceDescription>IPCamera</deviceDescription>
<deviceLocation>hangzhou</deviceLocation>
<systemContact>Hikvision.China</systemContact>
<model>DS-2CD2743G1-IZS</model>
<serialNumber>DS-2CD2743G1-IZS20200417AAWRE24517626</serialNumber>
<macAddress>ac:cb:51:62:69:ca</macAddress>
<firmwareVersion>V5.6.4</firmwareVersion>
<firmwareReleasedDate>build 191224</firmwareReleasedDate>
<encoderVersion>V7.3</encoderVersion>
<encoderReleasedDate>build 190910</encoderReleasedDate>
<bootVersion>V1.3.4</bootVersion>
<bootReleasedDate>100316</bootReleasedDate>
<hardwareVersion>0x0</hardwareVersion>
<deviceType>IPCamera</deviceType>
<telecontrolID>88</telecontrolID>
<supportBeep>false</supportBeep>
<supportVideoLoss>false</supportVideoLoss>
<firmwareVersionInfo>B-R-G1-0</firmwareVersionInfo>
</DeviceInfo>
tommyraton
Post by tommyraton » Sun Jan 24, 2021 6:02 pm
Ignore my previous post.
Well I needed to start and stop the zoneminder service and now it works. Kinda kludgy to edit the HikVision.pm. Typical though. Beat on it until it gives up and works!
jperkins
Post by jperkins » Thu Feb 18, 2021 1:06 am
created a pull request to allow the 'zoom' to stop 'zooming' EDIT. zoom stop pull merged into master on 2/18/2021. thanks
https://github.com/ZoneMinder/zoneminder/pull/3164
Users browsing this forum: No registered users and 6 guests
