HikVision PTZ control
Paranoid
Post by Paranoid » Wed Nov 02, 2016 1:16 pm
I've written a PTZ control script that should work for HikVision IP cameras.
It has the following capabilities:
  • Move including diagonals
  • Zoom
  • Focus
  • Iris
  • Goto and Set presets
  • Home position
  • Camera reset (reboot)
Instructions
1. Save the code to a file named "HikVision.pm"
2. Find out where the control scripts are stored on your system and put the file there.
If you don’t know where they are located then execute the following:
perl -E'use ZoneMinder::Control::PelcoD; say $INC{"ZoneMinder/Controli/PelcoD.pm"};'
This will tell you where the PelcoD.pm file is. Put the HikVision.pm in the same directory. You might need root permissions.
Execute the following to see if it is installed correctly:
perl -E'use ZoneMinder::Control::HikVision; say "Looks OK";'
3. Add the HikVision capabilities to ZoneMinder
Go to the Control tab on your camera settings and where it says "Control Type" click on edit.
This will bring up the Control Capabilities window. Click on "Add New Control".
Give it name, set the type to Remote and Protocol to "HikVision". If you want to be able to reboot your camera from zoneminder then you should also check "Can Reset"
Under the "Move" tab check "Can Move", "Can Move Diagonally" and "Can Move Continuous"
For the Pan/Tilt/Zoom/Focus/Iris tabs check the "Can Pan/Tilt/..." and the "Has Pan/Tilt/... Speed". The speed range is 1(slowest) to 100(fastest). If you prefer a constant speed then set the min and max values to whatever speed you prefer.
It can not "White balance"
In the preset tab check the "Has Presets", "Has Home Preset" and "Can Set Presets" option. Enter the number of presets you have (Note: even though my camera has over 200 presets I only put 20 here).
4. When you are sure all is correct then hit the save button.
5. Close any open zoneminder configuration windows including the the one for configuring your camera.
6. Open the camera configuration window and go to the control tab.
7. Under "Control Type" select the one you have just created
8. Enter your camera model in "Control Device"
This has to be the exact model. If you get it wrong then this will not work
If your IP camera has a web interface you can find it under Configuration->System Settings->Basic Information.
9. In "Control Address" put the username, password, camera address and port as shown below:
username:password@192.168.1.20:88
If it has a DNS entry set up you can use its hostname rather than ip address.
10. Save
If you have more than one HikVision camera then you need only do steps 6 - 10 for each additional camera
EDIT: I developed this on a camera that hasn't been installed yet. It is currently sitting upside down on a table. As a result I got the tilt direction wrong. This has now been corrected.
EDIT: Added some logging for when authentication fails
# ZoneMinder HikVision Control Protocol Module
# Copyright (C) 2016 Terry Sanders
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module contains an implementation of the HikVision ISAPI camera control
# protocol
package ZoneMinder::Control::HikVision;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# HiKVision ISAPI Control Protocol
# Set the following:
# ControlAddress: username:password@camera_webaddress:port
# ControlDevice: IP Camera Model
use Time::HiRes qw( usleep );
use LWP::UserAgent;
use HTTP::Cookies;
my $ChannelID = 1;              # Usually...
my $DefaultFocusSpeed = 50;     # Should be between 1 and 100
my $DefaultIrisSpeed = 50;      # Should be between 1 and 100
sub new {
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD {
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open {
    my $self = shift;
    $self->loadMonitor();
    # Create a UserAgent for the requests
    $self->{UA} = LWP::UserAgent->new();
    $self->{UA}->cookie_jar( {} );
    # Extract the username/password host/port from ControlAddress
    my ($user,$pass,$host,$port);
    if( $self->{Monitor}{ControlAddress} =~ /^([^:]+):([^@]+)@(.+)/ ) { # user:pass@host...
      $user = $1;
      $pass = $2;
      $host = $3;
    elsif( $self->{Monitor}{ControlAddress} =~ /^([^@]+)@(.+)/ )  { # user@host...
      $user = $1;
      $host = $2;
    else { # Just a host
      $host = $self->{Monitor}{ControlAddress};
    # Check if it is a host and port or just a host
    if( $host =~ /([^:]+):(.+)/ ) {
      $host = $1;
      $port = $2;
    else {
      $port = 80;
    # Save the credentials
    if( defined($user) ) {
      $self->{UA}->credentials( "$host:$port", $self->{Monitor}{ControlDevice}, $user, $pass );
    # Save the base url
    $self->{BaseURL} = "http://$host:$port";
sub PutCmd {
    my $self = shift;
    my $cmd = shift;
    my $content = shift;
    my $req = HTTP::Request->new(PUT => "$self->{BaseURL}/$cmd");
    if(defined($content)) {
      $req->content_type("application/x-www-form-urlencoded; charset=UTF-8");
      $req->content('<?xml version="1.0" encoding="UTF-8"?>' . "\n" . $content);
    my $res = $self->{UA}->request($req);
    unless( $res->is_success ) {
      # The camera timeouts connections at short intervals. When this
      # happens the user agent connects again and uses the same auth tokens.
      # The camera rejects this and asks for another token but the UserAgent
      # just gives up. Because of this I try the request again and it should
      # succeed the second time if the credentials are correct.
      if($res->code == 401) {
          # It has failed authentication. The odds are
          # that the user has set some paramater incorrectly
          # so check the realm against the ControlDevice
          # entry and send a message if different
          my $auth = $res->headers->www_authenticate;
          foreach (split(/\s*,\s*/,$auth)) {
            if( $_ =~ /^realm\s*=\s*"([^"]+)"/i ) {
              if( $self->{Monitor}{ControlDevice} ne $1 ) {
                Info "Control Device appears to be incorrect.";
                Info "Control Device should be set to \"$1\".";
                Info "Control Device currently set to \"$self->{Monitor}{ControlDevice}\".";
          # Check for username/password
          if( $self->{Monitor}{ControlAddress} =~ /.+:(.+)@.+/ ) {
            Info "Check username/password is correct";
          } elsif ( $self->{Monitor}{ControlAddress} =~ /^[^:]+@.+/ ) {
            Info "No password in Control Address. Should there be one?";
          } elsif ( $self->{Monitor}{ControlAddress} =~ /^:.+@.+/ ) {
            Info "Password but no username in Control Address.";
          } else {
            Info "Missing username and password in Control Address.";
          Fatal $res->status_line;
      else {
# The move continuous functions all call moveVector
# with the direction to move in. This includes zoom
sub moveVector {
    my $self = shift;
    my $pandirection  = shift;
    my $tiltdirection = shift;
    my $zoomdirection = shift;
    my $params = shift;
    my $command;                    # The ISAPI/PTZ command
    # Calculate autostop time
    my $duration = $self->getParam( $params, 'autostop', 0 ) * $self->{Monitor}{AutoStopTimeout};
    # Change from microseconds to milliseconds
    $duration = int($duration/1000);
    my $momentxml;
    if( $duration ) {
      $momentxml = "<Momentary><duration>$duration</duration></Momentary>";
      $command = "ISAPI/PTZCtrl/channels/$ChannelID/momentary";
    else {
      $momentxml = "";
      $command = "ISAPI/PTZCtrl/channels/$ChannelID/continuous";
    # Calculate movement speeds
    my $x = $pandirection  * $self->getParam( $params, 'panspeed', 0 );
    my $y = $tiltdirection * $self->getParam( $params, 'tiltspeed', 0 );
    my $z = $zoomdirection * $self->getParam( $params, 'speed', 0 );
    # Create the XML
    my $xml = "<PTZData><pan>$x</pan><tilt>$y</tilt><zoom>$z</zoom>$momentxml</PTZData>";
    # Send it to the camera
    $self->PutCmd($command,$xml);
sub moveStop         { $_[0]->moveVector(  0,  0, 0, splice(@_,1)); }
sub moveConUp        { $_[0]->moveVector(  0,  1, 0, splice(@_,1)); }
sub moveConUpRight   { $_[0]->moveVector(  1,  1, 0, splice(@_,1)); }
sub moveConRight     { $_[0]->moveVector(  1,  0, 0, splice(@_,1)); }
sub moveConDownRight { $_[0]->moveVector(  1, -1, 0, splice(@_,1)); }
sub moveConDown      { $_[0]->moveVector(  0, -1, 0, splice(@_,1)); }
sub moveConDownLeft  { $_[0]->moveVector( -1, -1, 0, splice(@_,1)); }
sub moveConLeft      { $_[0]->moveVector( -1,  0, 0, splice(@_,1)); }
sub moveConUpLeft    { $_[0]->moveVector( -1,  1, 0, splice(@_,1)); }
sub zoomConTele      { $_[0]->moveVector(  0,  0, 1, splice(@_,1)); }
sub zoomConWide      { $_[0]->moveVector(  0,  0,-1, splice(@_,1)); }
# Presets including Home set and clear
sub presetGoto {
    my $self = shift;
    my $params = shift;
    my $preset = $self->getParam($params,'preset');
    $self->PutCmd("ISAPI/PTZCtrl/channels/$ChannelID/presets/$preset/goto");
sub presetSet {
    my $self = shift;
    my $params = shift;
    my $xml = "<PTZPreset><id>$preset</id></PTZPreset>";
    $self->PutCmd("ISAPI/PTZCtrl/channels/$ChannelID/presets/$preset",$xml);
sub presetHome {
    my $self = shift;
    my $params = shift;
    $self->PutCmd("ISAPI/PTZCtrl/channels/$ChannelID/homeposition/goto");
# Focus controls all call Focus with a +/- speed
sub Focus {
    my $self = shift;
    my $speed = shift;
    my $xml = "<FocusData><focus>$speed</focus></FocusData>";
    $self->PutCmd("ISAPI/System/Video/inputs/channels/$ChannelID/focus",$xml);
sub focusConNear {
    my $self = shift;
    my $params = shift;
    # Get the focus speed
    my $speed = $self->getParam( $params, 'speed', $DefaultFocusSpeed );
    $self->Focus(-$speed);
    if($duration) {
      usleep($duration);
      $self->moveStop($params);
sub Near {
    my $self = shift;
    my $params = shift;
    $self->Focus(-$DefaultFocusSpeed);
sub focusAbsNear {
    my $self = shift;
    my $params = shift;
sub focusRelNear {
    my $self = shift;
    my $params = shift;
sub focusConFar {
    my $self = shift;
    my $params = shift;
    $self->Focus($speed);
    if($duration) {
      usleep($duration);
sub Far {
    my $self = shift;
    my $params = shift;
    $self->Focus($DefaultFocusSpeed);
sub focusAbsFar {
    my $self = shift;
    my $params = shift;
sub focusRelFar {
    my $self = shift;
    my $params = shift;
# Iris controls all call Iris with a +/- speed
sub Iris {
    my $self = shift;
    my $speed = shift;
    my $xml = "<IrisData><iris>$speed</iris></IrisData>";
    $self->PutCmd("ISAPI/System/Video/inputs/channels/$ChannelID/iris",$xml);
sub irisConClose {
    my $self = shift;
    my $params = shift;
    # Get the iris speed
    my $speed = $self->getParam( $params, 'speed', $DefaultIrisSpeed );
    $self->Iris(-$speed);
    if($duration) {
      usleep($duration);
sub Close {
    my $self = shift;
    my $params = shift;
    $self->Iris(-$DefaultIrisSpeed);
sub irisAbsClose {
    my $self = shift;
    my $params = shift;
sub irisRelClose {
    my $self = shift;
    my $params = shift;
sub irisConOpen {
    my $self = shift;
    my $params = shift;
    $self->Iris($speed);
    if($duration) {
      usleep($duration);
sub Open {
    my $self = shift;
    my $params = shift;
    $self->Iris($DefaultIrisSpeed);
sub irisAbsOpen {
    my $self = shift;
    my $params = shift;
sub irisRelOpen {
    my $self = shift;
    my $params = shift;
# reset (reboot) the device
sub reset {
    my $self = shift;
    $self->PutCmd("ISAPI/System/reboot");
1;
Re: HikVision PTZ control
Post by knight-of-ni » Wed Nov 02, 2016 3:13 pm
Thank you for doing the work.
However, can I get you to add this to the wiki?
https://wiki.zoneminder.com/Hikvision
Note that you can use zmcamtool to export the PTZ Hikvision ptz configuration from your database, and thus save everyone else the work of manually having to add it to their own system.
The following should work:
sudo zmcamtool.pl --export HikVision
Then just paste it to the wiki along with the control script.
Other users can then import it into their own system by saving your output as hikvision.sql and then issuing the following:
sudo zmcamtool.pl --import hikvision.sql
Also, if I could look a gift horse in the mouth, it would be very helpful if you would turn this into a pull request on our github site so we could add it to zoneminder. You can use this pr as an example of what you need to do:
https://github.com/ZoneMinder/ZoneMinder/pull/1305
apbb2
Post by apbb2 » Wed Nov 02, 2016 6:40 pm
This is great. Thank you.
I am having a hard time getting started though as I cannot find where PelcoD.pm resides. The perl script gives me nothing, so I am thinking it is not on my machine. whereis also comes up blank.
Where should it be?
I am currently running Ubuntu 16.04 with ZM 1.30 installed using PPA.
Once I get this installed I am sure it will work. Thanks Paranoid for getting this going!
Nevermind. I found it. It's in usr/share/perl5/ZoneMinder/Control/
apbb2
Post by apbb2 » Wed Nov 02, 2016 7:15 pm
OK. Sorry for the PTZ noob questions, but i have one more.
I have setup the script & setup the control on ZM. When I try to move the camera, I am get an error:
Control response was status = undefined message = /usr/bin/zmcontrol.pl --panspeed=65 --autostop --command=moveConLeft --id=20=>
I set the Pan & Tilt speed min & max (1 & 100) & have no other values for the other min & max, range, step, etc.
Any insight appreciated.
Thanks.
Paranoid
Post by Paranoid » Wed Nov 02, 2016 8:51 pm
apbb2 wrote:OK. Sorry for the PTZ noob questions, but i have one more.
Thanks.
What was the output when you ran the following?
If it is anything other than "Looks OK" then copy the output here.
Can you also provide the output of the following:
apbb2
Post by apbb2 » Thu Nov 03, 2016 5:36 pm
Running the perl gives me a 'Looks OK'
Here is the output of: sudo zmcamtool.pl --export HikVision
mysqldump: [Warning] Using a password on the command line interface can be insecure.
INSERT INTO `Controls` VALUES (NULL,'HikVision','Local','',0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,20,1,1,1,1,0,0,0,1,1,0,0,0,0,1,1,100,0,0,1,0,0,0,0,1,1,100,1,0,0,0);
Paranoid
Post by Paranoid » Thu Nov 03, 2016 5:49 pm
apbb2 wrote:Running the perl gives me a 'Looks OK'
Go into your camera setup.
Select the control tab.
Click on edit next to Control type.
A new window with pop up with the control capabilities.
Select "HikVision" and another window will pop up
In the "Protocol" entry put "HikVision"
Save and try again.
apbb2
Post by apbb2 » Thu Nov 03, 2016 6:32 pm
Thanks. Almost.
We seem to have fixed the error, however now when you try to control, there is no response from the camera.
I'm stuck. Sorry to bug about this but i am hoping my stupidity helps someone else out down the line.
Paranoid
Post by Paranoid » Thu Nov 03, 2016 8:30 pm
apbb2 wrote:Thanks. Almost.
I've modified the code so as add some loging when authentication fails. Can you download it again?
The most likely problem is authentication.
In the control tab you must set the "Control Device" to the exact model of your camera and "Control Address" must have the username:password@cameraaddress for the camera.
After you have saved the new version try again. If you look in the zmcontrol log file there should be messages indicating what might have gone wrong.
If you dont know where the log files are then do the following.
1. Open the main options page on the consle.
2. Look under the Paths tab and the PATH_LOGS will tell you where the log files are located.
3. Select the "Logging" tab and make sure LOG_LEVEL_FILE is set to Info
You might have to stop/start zoneminder to make any changes take effect.
apbb2
Post by apbb2 » Thu Nov 03, 2016 8:57 pm
Got it to work!
My issue was somewhat my stupidity & somewhat not.
I had a typo on my IP & when I took out port 88 I got it to work.
Logging definitely helped out for me.
Great Job!
Thank you so much for this.
Post by knight-of-ni » Sun Nov 06, 2016 2:11 pm
FYI:
https://github.com/ZoneMinder/ZoneMinder/pull/1674
Note I did make the assumption Paranoid implicitly gave his permission to include his script in ZoneMinder. If this is not the case, then please let us know. It's your script, so tell us if this is ok.
vbo68
Post by vbo68 » Fri May 26, 2017 6:01 pm
Thanks a LOT ! :D
Works Great with DS-2DE4220IW-DE
Now I will try to make the script work for Tracking, as the manual says :
"This will only work if your camera supports mapped movement modes where a point on an image can be mapped to a control command. This is generally most common on network cameras but can be replicated to some degree on other cameras that support relative movement modes. See the Camera Control section for more details"
Do you know if this HikVision camera supports "relative movement modes" ?
vbo68
Post by vbo68 » Fri May 26, 2017 6:56 pm
Just found the API Standards used by Hiksivion :
http://static.interlogix.com/library/In ... LISHED.pdf
Here are all the commands supported by the cameras, for good scripters (that I am not, but I will try)
Have fun !
Paranoid
Post by Paranoid » Fri May 26, 2017 7:02 pm
You should be able to find all the information you need here: http://oversea-download.hikvision.com/u ... ervice.pdf
vbo68
Post by vbo68 » Sat May 27, 2017 12:15 am
Thanks Paranoid ! I will have a look at it.
Meanwhile, I managed to add the mapping capability to your HikVision Script, It works, and now you can click on the picture to center it where you click, but the only issue is that is requires knowing the capture resolution of the camera stream in the monitor configuration, so for the moment I have hard coded it...
For the "relative" move functions, that will enable the motion tracking feature, I am still at the very begining because I think I have to calibrate the speed based on the value of the steps send by zoneminder. If someone that is really a develloper could have a look at it it would be great, here is where I stand :
# protocol
use 5.006;
use strict;
use warnings;
use LWP::UserAgent;
use HTTP::Cookies;
my $xResolution = 704;
my $yResolution = 576;
sub new {
    my $class = shift;
    my $id = shift;
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD {
    my $self = shift;
    $name =~ s/.*://;
sub open {
    my $self = shift;
      $user = $1;
      $pass = $2;
      $host = $3;
      $user = $1;
      $host = $2;
      $host = $1;
      $port = $2;
    else {
      $port = 80;
    # Save the base url
sub PutCmd {
    my $self = shift;
    my $cmd = shift;
          } else {
      else {
sub moveVector {
    my $self = shift;
    my $params = shift;
    my $momentxml;
    if( $duration ) {
    else {
      $momentxml = "";
    # Create the XML
sub presetGoto {
    my $self = shift;
    my $params = shift;
sub presetSet {
    my $self = shift;
    my $params = shift;
sub presetHome {
    my $self = shift;
    my $params = shift;
sub Focus {
    my $self = shift;
    my $speed = shift;
sub focusConNear {
    my $self = shift;
    my $params = shift;
    if($duration) {
      usleep($duration);
sub Near {
    my $self = shift;
    my $params = shift;
sub focusAbsNear {
    my $self = shift;
    my $params = shift;
sub focusRelNear {
    my $self = shift;
    my $params = shift;
sub focusConFar {
    my $self = shift;
    my $params = shift;
    if($duration) {
      usleep($duration);
sub Far {
    my $self = shift;
    my $params = shift;
sub focusAbsFar {
    my $self = shift;
    my $params = shift;
sub focusRelFar {
    my $self = shift;
    my $params = shift;
sub Iris {
    my $self = shift;
    my $speed = shift;
sub irisConClose {
    my $self = shift;
    my $params = shift;
    if($duration) {
      usleep($duration);
sub Close {
    my $self = shift;
    my $params = shift;
sub irisAbsClose {
    my $self = shift;
    my $params = shift;
sub irisRelClose {
    my $self = shift;
    my $params = shift;
sub irisConOpen {
    my $self = shift;
    my $params = shift;
    if($duration) {
      usleep($duration);
sub Open {
    my $self = shift;
    my $params = shift;
sub irisAbsOpen {
    my $self = shift;
    my $params = shift;
sub irisRelOpen {
    my $self = shift;
    my $params = shift;
sub reset {
    my $self = shift;
sub moveRelVector {
    my $self = shift;
    my $panstep  = shift;
    my $tiltstep = shift;
    my $params = shift;
    my $duration = int(100);
    my $momentxml;
    my $x = $panstep  * $self->getParam( $params, 'panspeed', 0 );
    my $y = $tiltstep * $self->getParam( $params, 'tiltspeed', 0 );
    # Create the XML
    my $xml = "<PTZData><pan>$x</pan><tilt>$y</tilt><zoom>0</zoom>$momentxml</PTZData>";
sub moveRelUp
    my $self = shift;
    my $params = shift;
    my $step = $self->getParam( $params, 'tiltstep' );
    Debug( "Step Up $step" );
    $_[0]->moveRelVector(  0,  $step, 0, splice(@_,1));
sub moveRelDown
    my $self = shift;
    my $params = shift;
    Debug( "Step Down $step" );
sub moveRelLeft
    my $self = shift;
    my $params = shift;
    my $step = $self->getParam( $params, 'panstep' );
    Debug( "Step Left $step" );
    $_[0]->moveRelVector( $step ,  0, 0, splice(@_,1));
sub moveRelRight
    my $self = shift;
    my $params = shift;
    Debug( "Step Right $step" );
    $_[0]->moveRelVector(  $step   0, 0, splice(@_,1));
sub moveRelUpRight
    my $self = shift;
    my $params = shift;
    my $panstep = $self->getParam( $params, 'panstep' );
    my $tiltstep = $self->getParam( $params, 'tiltstep' );
    Debug( "Step Up/Right $tiltstep/$panstep" );
    $_[0]->moveRelVector( $panstep , $tiltstep , 0, splice(@_,1));
sub moveRelUpLeft
    my $self = shift;
    my $params = shift;
    Debug( "Step Up/Left $tiltstep/$panstep" );
sub moveRelDownRight
    my $self = shift;
    my $params = shift;
    Debug( "Step Down/Right $tiltstep/$panstep" );
sub moveRelDownLeft
    my $self = shift;
    my $params = shift;
    Debug( "Step Down/Left $tiltstep/$panstep" );
sub moveMap {
    my $self = shift;
    my $params = shift;
    my $xcoord = $self->getParam( $params, 'xcoord' );
    my $ycoord = $self->getParam( $params, 'ycoord' );
    my $command;
    my $positionx = int((($yResolution - $ycoord)/$yResolution)*255);
    my $positiony = int((($xcoord)/$xResolution)*255);
    Debug( "Move Map to $xcoord,$ycoord" );
    $command = "ISAPI/PTZCtrl/channels/$ChannelID/relative";
    my $xml = "<PTZData><Relative><positionX> $positionx </positionX><positionY> $positiony </positionY><relativeZoom> 0</relativeZoom></Relative></PTZData>";
sub moveAbs_todo {
    my $self = shift;
    my $params = shift;
    my $command;
    Debug( "Move  to absolute elevation and azimuth $xcoord,$ycoord" );
    $command = "ISAPI/PTZCtrl/channels/$ChannelID/absolute";
    my $xml = "<PTZData><AbsoluteHigh><elevation> 50 </elevation> <azimuth> 50 </azimuth><absoluteZoom> 0 </absoluteZoom></AbsoluteHigh></PTZData>";
Any comment welcome, just don't be too hard on my coding, I am self teached develloper...
Anyway I will still work on it this weekend, and see if I can finalyse the Motion tracking capability.
The moveAbs {} , function is just at a very preliminary stage as I could not find exemples in the scripts of other cameras.
Good Night !
Users browsing this forum: No registered users and 6 guests
