TENVIS JPT3815W Pan/Tilt Control Script
hunternet93
Post by hunternet93 » Wed Jul 09, 2014 4:34 pm
I now have the super-cheap TENVIS JPT3815W pan/tilt camera working in ZoneMinder. My attached script allows ZM to control the camera's pan, tilt, and presets. If you need instructions on installing the script, please reply here and I'll add them.
(copy-pasting here because the attachment box apparently doesn't allow .pm or .txt)
Filename: TENVISJPT3815W.pm
# ZoneMinder Panasonic IP Control Protocol Module, $Date$, $Revision$
# Copyright (C) 2001-2008  Philip Coombes
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module contains the implementation of the Panasonic IP camera control
# protocol
package ZoneMinder::Control::TENVISJPT3815W;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# TENVIS JPT2815W Control Protocol
use Time::HiRes qw( usleep );
my $axis = 0;
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
#    my $req = HTTP::Request->new( GET=>"http://10.99.2.191:7777/".$cmd );
#    $req->authorization_basic("admin", "admin");
    if ( $res->is_success )
        $result = !undef;
    else
        Error( "Error check failed: '".$res->status_line()."' URL:".$req->uri );
    return( $result );
sub cameraReset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "reboot.asp";
    $self->sendCmd( $cmd );
sub moveConUp
    my $self = shift;
    Debug( "Move Up" );
    $self->moveStop();
    $axis = 1;
    my $cmd = "media/?action=cmd&code=2&value=1";
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    $self->moveStop();
    $axis = 2;
    my $cmd = "media/?action=cmd&code=2&value=2";
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    $self->moveStop();
    $axis = 4;
    my $cmd = "media/?action=cmd&code=2&value=4";
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    $self->moveStop();
    $axis = 3;
    my $cmd = "media/?action=cmd&code=2&value=3";
sub moveStop
    my $self = shift;
    if ($axis != 0) {
        my $cmd = "media/?action=cmd&code=3&value=$axis";
        $axis = 0;
sub presetSet
    my $self = shift;
    my $params = shift;
    my $cmd = "media/?action=cmd&code=11&value=$preset";
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $cmd = "media/?action=cmd&code=13&value=$preset";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
  use ZoneMinder::Database;
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cu
SteveGilvarry
Re: TENVIS JPT3815W Pan/Tilt Control Script
Post by SteveGilvarry » Sun Jul 13, 2014 2:09 pm
Don't have PTZ but I believe the scripts all live here if you want to add to Github.
https://github.com/ZoneMinder/ZoneMinde ... er/Control
Production Zoneminder 1.35.x
More Dev VM's than I care to count.
petegriggs
Post by petegriggs » Thu Jan 26, 2017 9:26 am
If you have install instructions that would be good? I can't seem to get it to work.
Best Wishes
Pete.
Verna
Post by Verna » Wed Jun 13, 2018 7:41 am
Hello mates!!
I have the same camera but I am unable to configurate it.
Can somebody help me to do that?
I need help with the script and with the steps to configurate it.
Many thanks in advance!!!
johng143
Post by johng143 » Tue Dec 29, 2020 9:22 pm
so where to install this file and how set it up?
thx ,
have several of these cheap cams.
jg
Post by Magic919 » Wed Dec 30, 2020 7:31 am
Put it with all the other scripts. Have a read https://zoneminder.readthedocs.io/en/st ... ntrol.html
