I found a script on these forums some years ago to make a video of the previous hour and leave this in a folder of your choice.
I have taken that script and modified it to make an mp4 video of the previous full day, the scrip works perfect and the video is almost perfect.
The problem is the video will get mixed up with frames from earlier or later in the day and so gets garbled, the script works by querying the sql database for the events required for the period then makes a link to the jpeg files
sorted in the events folder, once it has a large sequential list of jpgs it uses ffmpeg to compress the series into a single mp4 file.
The scrip is as follows, can anyone spot the error that causing my problems and suggest a solution.
Thanks in advance.
#!/bin/bash
MUSER="zmuser"
MPASS="zmpass"
MHOST="localhost"
MDB="zm"
MYSQL="$(which mysql)"
MYSQLDUMP="$(which mysqldump)"
PATHTOEVENTS="/var/www/html/zm/events"
MonitorId="$1"
tmpdir="/tmp"
if [ "$1" == "$null" ]
then
echo You Must Specify The Monitor ID i.e \'$0 4\' would specify monitor id 4
exit
fi
EVENTS="$($MYSQL -D$MDB -u$MUSER -p$MPASS -Bse 'select id from Events WHERE (StartTime BETWEEN DATE_SUB(CURDATE( ) ,INTERVAL 1 DAY ) AND CURDATE( )) AND (MonitorId = '$MonitorId') order by id asc')"
echo $EVENTS
mkdir $tmpdir/$MonitorId
x=1
for event in ${EVENTS[@]}
do
if [ $x -eq 1 ]
then
mysqldate="$($MYSQL -D$MDB -u$MUSER -p$MPASS -Bse 'select StartTime from Events WHERE id = '$event'')"
date=`date +%b%d-%Y --date="$mysqldate"`
firstevent="$event"
echo Making Images and Placing them in $tmpdir/$MonitorId .... Please Be Patient this could take a while.
fi
for i in $(ls $PATHTOEVENTS/$MonitorId/$(TZ=EST24EDT date +%y/%m/%d)/.$event/*jpg)
do counter=$(printf %06d $x)
ln -s "$i" $tmpdir/$MonitorId/img"$counter".jpg
x=$(($x+1))
done
done
ffmpeg -f image2 -i $tmpdir/$MonitorId/img%06d.jpg -vcodec libx264 -vpre libx264-normal -threads 0 /var/www/html/Monitor-$1-$(date +%Y-%m-%d).mp4
rm -rf $tmpdir/$MonitorId
Script to make mp4 video of previous day
Re: Script to make mp4 video of previous day
I have it like this...
Create a folder like /home/user/bin, inside bin create a file like zmmkmov with
#!/bin/sh
#Next line is where you store the list of files to append to a movie.
rm /home/weatherman/bin/list.txt
#do a simple ls command, but for all files that were created "yesterday" and numerical sort rigth "-v" and place it in a file!
ls -Ca --format=single-column -v /where_the_folder/events/1/$(TZ=EST24EDT date +%y/%m/%d)/.*/*capture.jpg > /home/user/bin/list.txt
#Do your stuff Mr. Mencoder... fps = Frames per second!
/usr/bin/mencoder "mf://@/home/user/bin/list.txt" -mf fps=2 -o /home/user/bin/mon1-$(TZ=EST26EDT date +%F).avi -ovc lavc -lavcopts vcodec=mpeg4
#Move the created video to the Videos folder
mv /home/user/bin/mon1-$(TZ=EST26EDT date +%F).avi /home/user/Videos
Then create a cron job for it, like run it every day at 12:30 or sumtin!
#!/bin/sh
But then again, to avoid the Argument too long error... try find instead!
Replace this line...
With...
find /where_the_folder/events/1/$(TZ=EST24EDT date +%y/%m/%d)/ -type f -name *capture.jpg | sort > /home/user/bin/list.txt
With...
I know this is old but I found the same script and used it for a while. I have this one now and it works.
I have used this for a while now and it does work decentily. I created a cronjob to run at 12am, 2am, and 4am for each camera I have. Yes only 3 but it works. Playback in VLC and you can increase/decrease speed (useful if you know around when an event happened). My cams record 24x7 and zmaudit runs every 6 hours to cleanup the previous day events. Also I changed the 'USE_DEEP_STORAGE' to off. BE CAREFUL BECAUSE IT WILL CLEAR ALL CURRENT EVENTS IF YOU SELECT IT!!!!
Hope it helps and any improvments I am open for suggestions.
#!/bin/sh
# Change to suit your needs
### MUST RUN AS ROOT #######
# If you do not want to delete events after video is made
# Comment out lines 'xargs -I{} sh -c 'rm {}' < $TMPDIR/$TMPFILE' and 'find $EVENTSDIR/$MONID -empty -exec rm -r {} \;'
# Monitor ID - MUST BE NUMERICAL ID OF MONITOR WILL NOT FOLLOW SYMLINK
MONID=3
# TMP DIR - change if you have to
TMPDIR=/home/$USER/tmp
# Events dir (look where you specified ZM to store events eg:/var/cache/zoneminder/events)
EVENTSDIR=/var/cache/zoneminder/events
# Output dir
OUTDIR=/home/$USER/Videos/Events/$MONID/$(TZ=EST26EDT date +%F)
# What user/group we save videos as
USER=my user
GROUP=my user
#### DO NOT MODIFY BELOW #######
# Create Output dir if it doesnt exist
mkdir $OUTDIR
# TMP file name
TMPFILE=$MONID.txt
# DON'T CHANGE
EVENTS=$EVENTSDIR/$MONID
# Output filename
OUTFILE=$MONID-$(TZ=EST26EDT date +%F).avi
# Dont remove dir just make so we dont delete running jobs
# rm -vfr $TMPDIR
mkdir $TMPDIR
# Find each jpg modified in 24hrs and sort numerically (eg 100 before 10000)
find $EVENTS -type f -name *capture.jpg -mmin -$((60*24)) -printf "%C@ %p\n" | sort -M | awk '{print $2;}' > $TMPDIR/$TMPFILE
# Mencoder time... fps = Frames per second! NOTE my cameras are captured at 15fps so 60 means each minute lasts only ~5 seconds!!!
/usr/bin/mencoder "mf://@$TMPDIR/$TMPFILE" -mf fps=60 -o $OUTDIR/$OUTFILE -ovc lavc -lavcopts vcodec=mpeg4:threads=2
# Clean up jpgs of what we just made so zmaudit.pl will remove events
# Find all empty files and dir and remove them (More clean up)
# Change permission of outfile to user
chown -R $USER:$GROUP $OUTDIR
