X-Files
Post
by X-Files » Sat Jun 13, 2009 8:13 pm
#!/usr/bin/php
</Version>/dev/null 2>/dev/null
Tested in 1.24.1 - OK
$zm_events_path = "/home/web/www.site.com/zm/events";
$zm_tmp_path = "/tmp/zm_tmp";
$zm_archive_video_path = "/home/web/www.site.com/zm/ARCHIVE";
// tmp
$array_tmp_monitor = array();
$YESTERDAY=date("Y-m-d", mktime(0, 0, 0, date("m") , date("d")-1, date("Y")) );
$STARTTIME="$YESTERDAY 00:00:00";
$ENDTIME="$YESTERDAY 23:59:59";
// end tmp
$sql_host = "localhost";
$sql_login = "zmuser";
$sql_pass = "zmpass";
$sql_base = "zm";
// SQL connect
if (!@mysql_connect($sql_host, $sql_login, $sql_pass)) die("Can't connect to MySQL databse");
if (!@mysql_select_db($sql_base)) die("Can't use database : $sql_base");
function scanDirectories($rootDir) {
$invisibleFileNames = array(".", "..");
$dirContent = scandir($rootDir);
$allData = array();
$fileCounter = 0;
foreach($dirContent as $key => $content) {
$path = $rootDir.'/'.$content;
if(!in_array($content, $invisibleFileNames)) {
if(is_file($path) && is_readable($path)) {
$tmpPathArray = explode("/",$path);
$allData[$fileCounter]['fileName'] = end($tmpPathArray);
$allData[$fileCounter]['filePath'] = $path;
$filePartsTmp = explode(".", end($tmpPathArray));
$allData[$fileCounter]['fileExt'] = end($filePartsTmp);
$fileCounter++;
}elseif(is_dir($path) && is_readable($path)) {
$dirNameArray = explode('/',$path);
$allData[$path]['dirPath'] = $path;
$allData[$path]['dirName'] = end($dirNameArray);
$allData[$path]['content'] = scanDirectories($path);
return $allData;
function number_pad($number,$n) {
return str_pad((int) $number,$n,"0",STR_PAD_LEFT);
$sql_DB_Events=mysql_query("
SELECT MonitorId,Id,Name FROM Events
WHERE StartTime > '".$STARTTIME."' and StartTime <= '".$ENDTIME."'
ORDER BY MonitorID,Id
$n_DB_Events=mysql_num_rows($sql_DB_Events);
for ($i_DB_Events=0;$i_DB_Events<n_DB_Events> $content) {
if ($content[fileExt] != 'jpg') {continue;}
$array_tmp_monitor[$row_DB_Events[MonitorId]]=$array_tmp_monitor[$row_DB_Events[MonitorId]]+1;
$dir_from = $content[filePath];
$dir_to = $zm_tmp_path."/".$row_DB_Events[MonitorId]."/".number_pad($array_tmp_monitor[$row_DB_Events[MonitorId]],3).".jpg";
rename($dir_from,$dir_to);
system("rm -rf ".$zm_events_path."/".$row_DB_Events[MonitorId]."/".$row_DB_Events[Id]);
foreach($array_tmp_monitor as $key => $content) {
if (!is_dir($zm_archive_video_path)){mkdir ($zm_archive_video_path, 0777);print "Status: Dir Added ".$zm_archive_video_path." !!! \n";}
if (!is_dir($zm_archive_video_path."/".$key)){mkdir ($zm_archive_video_path."/".$key, 0777);print "Status: Dir Added ".$zm_archive_video_path."/".$key." !!! \n";}
if (!is_dir($zm_archive_video_path."/".$key."/".$YESTERDAY)){mkdir ($zm_archive_video_path."/".$key."/".$YESTERDAY, 0777);print "Status: Dir Added ".$zm_archive_video_path."/".$key."/".$YESTERDAY." !!! \n";}
system("ffmpeg -y -i ".$zm_tmp_path."/".$key."/%03d.jpg -s 640x480 -r 30 ".$zm_archive_video_path."/".$key."/".$YESTERDAY."/cam_nr-".$key."_date".$YESTERDAY.".mpg");
system("rm -rf ".$zm_tmp_path."/".$key);
echo "END !!!";
kingofkya
Post
by kingofkya » Tue Jun 16, 2009 5:39 am
not trying to discount what you did but zoneminder already does this
see filters
ekiboy69
Post
by ekiboy69 » Mon Jun 22, 2009 9:09 pm
If the code does what the topic says is does something quite different compared to filters. Filters create one video file per event. If this really creates one big mpeg file it is truly a different thing IMHO.
robi
Post
by robi » Mon Jun 22, 2009 9:13 pm
ekiboy69 wrote:If the code does what the topic says is does something quite different compared to filters. Filters create one video file per event. If this really creates one big mpeg file it is truly a different thing IMHO.
Agree.
v1.25.0 + Ubuntu Linux 12.04 Server
trendkill
Post
by trendkill » Fri Oct 16, 2009 11:18 pm
great!
how can I run this script?
/usr/bin/php <filename> command writes the code to the terminal...
whatboy
Post
by whatboy » Sun Oct 18, 2009 12:55 am
I think it would be better to create a crontab entry and run it every day say at 00:10
Like if you run the gui with one user lets say... watcher
copy the script and put it where the user can execute it... like /home/watcher/bin
10 00 * * * umask 002; /home/watcher/bin/mkmovie
Am I right???
Hmmm... guess NOT... ok, so how do you execute this code??? I try put ./mkmovie and it just text out on the terminal...
trendkill
Post
by trendkill » Sun Oct 18, 2009 11:34 pm
yes this is the main problem
I don't know how php works, but i have to use this script...
trendkill
Post
by trendkill » Thu Oct 22, 2009 10:39 pm
Anybody?????
trendkill wrote:yes this is the main problem
bazso
Post
by bazso » Sat Oct 24, 2009 7:31 am
Nice work, only the fix 30FPS in the ffmpeg parameters seems a bit problematic (Honestly I haven't tried the script yet), because how can I be sure that all events have this frame rate?
Kind Regards,
BaZso
whatboy
Post
by whatboy » Tue Oct 27, 2009 6:39 pm
Anyone??? any tips on how to run this script??? Pretty please!!!
kwire
Post
by kwire » Tue Oct 27, 2009 10:33 pm
whatboy and trendkill,
I am not a PHP programmer either, but what have you done to execute the script?
I did not try the script as presented, but I have run a few scripts before... Try to follow the instructions
hereand report back.
Keith
whatboy
Post
by whatboy » Wed Oct 28, 2009 12:34 am
I think that script is incomplete or part of another script... I check another script and it need to define something like this...
# Include from system perl paths only
use ZoneMinder::Base qw(:all);
use ZoneMinder::General qw(:all);
use ZoneMinder::Database qw(:all);
use ZoneMinder::ConfigAdmin qw( :functions );
or sumtin!!! I think!!!
whatboy
Post
by whatboy » Wed Oct 28, 2009 12:45 am
DAMN IT... the script sounds soo good to not have it!!! F...
whatboy
Post
by whatboy » Thu Oct 29, 2009 1:12 am
Ok. I PM X-Files, we just have to wait and see if he responds...
arielf
Post
by arielf » Thu Oct 29, 2009 1:22 pm
Question: Generates a video with all cameras or video monitor set individually for each?
Users browsing this forum: No registered users and 5 guests
