jZMConsole V0.2B Available
ahagadorn
Post by ahagadorn »
It currently does not directly handle proxies, but it is fairly easy for me to add that.
I will look in to a quick fix for the port issue.
Andy
namwons
Logs
Post by namwons »
I have been pounding my head all day on trying to get this to work. I get nothing in the log files they are all zero bytes. I have tried on Ubuntu 9.04 desktop, Ubuntu 8.04 desktop and a windows XP machine.
The windows client gets to login and once I auth just hangs. My Linux boxes launch and hang with
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException.
I am wondering about the JMF install on the server, when I do it I get the following at the end.
Exception in thread "main" java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159)
at java.awt.Window.<init>(Window.java:431)
at java.awt.Frame.<init>(Frame.java:403)
at JMFInit.<init>(JMFInit.java:23)
at JMFInit.main(JMFInit.java:248)
These are headless ubuntu 9.04 64 Bit server installs. I have one running 1.23.3 from repos and one running 1.24.2 from source. Both systems are working just fine. Can get to web interface auth and view cameras and events.
I downloaded the code for console from sourceforge. Any suggestions are greatly appreciated.
I am going to install zmarch and see if I have any better luck.
ahagadorn
Post by ahagadorn »
It could be the JMF install. Make sure that /usr/local/JMF-2.1.1e/lib/ is populated, specifically, jmf.jar
Andy
namwons
Post by namwons »
This is from the server. Are the rights accurate for those jar files?
-rw-r--r-- 1 root root 1814984 2009-09-22 11:52 jmf.jar
-rw-r--r-- 1 root root 29462 2009-09-22 11:52 jmf.properties
-rw-r--r-- 1 root root 29462 2009-09-22 11:52 jmf.properties.orig
-rwxr-xr-x 1 root root 38258 2009-09-22 11:52 libjmcvid.so
-rwxr-xr-x 1 root root 9814 2009-09-22 11:52 libjmdaud.so
-rwxr-xr-x 1 root root 7189 2009-09-22 11:52 libjmfjawt.so
-rwxr-xr-x 1 root root 80486 2009-09-22 11:52 libjmg723.so
-rwxr-xr-x 1 root root 35085 2009-09-22 11:52 libjmgsm.so
-rwxr-xr-x 1 root root 384577 2009-09-22 11:52 libjmh261.so
-rwxr-xr-x 1 root root 74228 2009-09-22 11:52 libjmh263enc.so
-rwxr-xr-x 1 root root 136718 2009-09-22 11:52 libjmjpeg.so
-rwxr-xr-x 1 root root 370204 2009-09-22 11:52 libjmmpa.so
-rwxr-xr-x 1 root root 77211 2009-09-22 11:52 libjmmpegv.so
-rwxr-xr-x 1 root root 164990 2009-09-22 11:52 libjmmpx.so
-rwxr-xr-x 1 root root 46856 2009-09-22 11:52 libjmutil.so
-rwxr-xr-x 1 root root 14123 2009-09-22 11:52 libjmv4l.so
-rwxr-xr-x 1 root root 14590 2009-09-22 11:52 libjmxlib.so
-rw-r--r-- 1 root root 35882 2009-09-22 11:52 mediaplayer.jar
-rw-r--r-- 1 root root 57246 2009-09-22 11:52 multiplayer.jar
sef1976
Post by sef1976 »
23.09.2009 7:59:14 org.apache.commons.httpclient.HttpMethodDirector executeWithRetry
INFO: I/O exception (org.apache.commons.httpclient.NoHttpResponseException) caught when processing request: The server xxxxxxxx failed to respond
INFO: Retrying request
but on browser server xxxxxx view Ok
my PC not use proxy :D
whatboy
Post by whatboy »
All I get is this...
Nevermind... it was a permission issue...
cubber
Post by cubber »
I am getting the same error when I try to input my zoneminder url. How did you fix it?
Anything I try to input comes back as an invalid zoneminder url
littlej
Post by littlej »
hmmm i have instaled u'r latest version, runing windows 7 64bit, works ok, but i canot view events... i can view the list but have no idea how i can open to view what it recorded. isnt that feature implemented or ? thanks a lot
Tempest
Can't replay events
Post by Tempest »
Hi there as with littlej, I too can not replay any events that are listed.
I did see on your website's screenshots page
"3-12-2009 - The features and screenshots shown here reflect the latest version I have been working on that is not available for download yet! I will be putting it on SourceForge soon, so hang in there"
so presumable it's not availible yet,
as it's a feature thats definantly wanted, i'd be happy to test it, and report any issues, if that helps?
Also any chance of a mac version?
Cheers & keep up the good work
Windows Vista Home Premium SP2, Java JRE V1.6 Update 17 - also tried it under Update17
littlej
Post by littlej »
no news about the new version? i would gladly beta test it if u wish :) cheers.
