New Skin for 1.24
logray
Post by logray » Fri Sep 17, 2010 8:13 pm
Yes on every event.
I even deleted the new directory and re-gitt'ed it. :-)
scanto
Post by scanto » Wed Sep 29, 2010 3:15 pm
this skin is compatible with 1.24.2 zoneminder? in my installation 1.24.2 in the dashboard the cam do not work and the events are empty
bumann
Post by bumann » Sat Oct 09, 2010 1:52 pm
I have git the new skin and I have changed in the function.php the name of mootools. So the error message install motools fixed. But the dashboard shows no image in monitor of my jpeg stream. Another prob that i have is when i add a new monitor i can't witch to the monitor source!
I have got zm 1.24.2 and the mootools from the zm sources.
Any suggestions? the skin lookes very good.
kylejohnson
Post by kylejohnson » Sat Oct 09, 2010 4:47 pm
bumann wrote:I have git the new skin and I have changed in the function.php the name of mootools. So the error message install motools fixed. But the dashboard shows no image in monitor of my jpeg stream. Another prob that i have is when i add a new monitor i can't witch to the monitor source!
You changed jQuery to mootools? That is the cause of your issue. This skin is built around jQuery.
Idling as gnulnx in #zoneminder on freenode. Come say hi!
bumann
Post by bumann » Sat Oct 09, 2010 5:47 pm
Tnx. I have loaded the latest mootools from url and set the link from mootools-core.js to the new core file but it dosent work. the link is in the zm/tools/mootools dir. What i did wrong with the update?! any suggestions?
bumann
Post by bumann » Sat Oct 09, 2010 9:44 pm
I had fixed my problem with live view on dashboard. I made a new git an change the function.php again with the right version number of mootools. And i witched the zm autentification off :-) ! But the problem to add a new monitor is still there. When i add a new monitor i can´t witch to the source setting to set the cam adress and so on. Is that a bug of the skin or only for my installation?
Greetings from Germany!
Thank you for the work on this beautiful skin!
kylejohnson
Post by kylejohnson » Sun Oct 10, 2010 4:18 am
I haven't seen that happen on either of my boxes.
I don't understand why you're using mootools? This skin requires jquery. If you've replaced jquery with mootools that will definitely cause problems.
bumann
Post by bumann » Sun Oct 10, 2010 9:56 am
Hi!
I didn´t have replaced jquery, i only changed the name from mootools version 1.2 in the skript to version 1.2.1 that comes with my zm installation. Without this change the skin allways display mootools not found. Where i can see that jquery is installed?! Comes jquery with the normal zm installation? Could it be that my problem is because my zm webdir is /var/www/zm? I made no apache settings after zm installation, so i must go to 192.168.2.48/zm to open zm console!
Mika
Post by Mika » Mon Nov 08, 2010 12:14 pm
i try use this repository:
git clone git://github.com/kylejohnson/zm_newskin.git new
I install in skins/new and user http://YourZM/?skin=new, i see the new skin, but when i try acces to "Events" menu, don't see anything, and Apache2 report a lot of undefinied index and variable.
This is the last version of this theme?
Thx
grmela
Post by grmela » Tue Nov 09, 2010 9:15 am
It's possible it's been already answered here but nine pages thread is a nine pages thread :-)
My question: is there any chance of getting the new skin (or some equally nice and usable one) in the next stock ZM release by default? That would be great! The current skin has a lot of functions but is sometimes confusing for the not-really-advanced users and doesn't look any great either. This one is the exactly right direction how the default should change.
DREMA
Post by DREMA » Wed Nov 10, 2010 3:47 pm
Have you thought on integrating the Timeline somewhere on your skin? I think that would be a great feature.
larrywise
Not Working
Post by larrywise » Fri Nov 12, 2010 1:56 pm
I have downloaded this skin but i cant get it working there are so many error in it i am using 1.24.2 and with ubuntu 10.10
any help
Larry
DREMA
Post by DREMA » Thu Nov 25, 2010 9:17 am
Any nwes on the progress with this?? Any way we can help you?? :D
timgman
Post by timgman » Tue Nov 30, 2010 7:27 pm
timeline would be a great Idea... I LOVE the diginet timeline feature.. It's key here in the c-store industry.
albertotoba
Post by albertotoba » Thu Dec 16, 2010 2:14 pm
hi
I've installed the skin and everything looks fine. However i have some problems
1- Thumbnails on events home screen are not resized and it's not possible order by date desc.
2- Opening events by clicking the event no loading but opening in a new tab or page load fine and I can play the video.
3- if i search for an event, i can't play it. if clink the image i see just the image.
thanks..and it's a really good job.
