Scalable images in Montage view
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
unclerichy
Post by unclerichy »
How about being able to select a scale for each camera when in Montage view? I have two cameras using different image sizes which result in the Montage window being rather large - it would be nice to be able to make them the same size by selecting 1/2 and 1/3 scales (for example) respectively.
Looking at the source for the image windows it seems as if it's just a case of tagging on width and height tags along with a scale parameter. But I may be wrong :)
unclerichy
Just found the montage width and height options on the Web tab of the Option screen. :oops:
