I have been using other windows based security camera systems and recently switched to ZM. I would like a way to filter events based on the length of time that they have been in existence. If this was available I could create a filter to (for example) delete any events for a certain monitor or storage area that are greater than 365 days or greater than 12 months or greater than well.......any given time frame. I have found that so far I can only specify a certain calendar date/time to do this.
Thank you.
Add event columns for easier filter creation
Re: Add event columns for easier filter creation
See https://zoneminder.readthedocs.io/en/la ... te-stringsdthomas0424 wrote: ↑Fri Feb 26, 2021 3:50 pmI would like a way to filter events based on the length of time that they have been in existence.
fastest way to test streams:
ffmpeg -i rtsp://<ipaddress>:554/path output.mp4
from terminal, and run through paths on ispydb or in zm hcl
If you are new to security software, read this:
