Motion detection on substream without recording
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
Johnny1337
Post by Johnny1337 » Sun Aug 23, 2020 7:56 am
Many cameras have both a main stream and a sub stream. I think it would be a good feature to do motion detection on the substream and then record only the mainstream.
I dont know if it is possible to make it but I think it would save both cpu and disk space.
Paranoid
Re: Motion detection on substream without recording
Post by Paranoid » Sun Jan 17, 2021 12:02 am
You might already be able to do that.
Set up to 2 monitors, one for the sub stream and one for the main.
The sub stream detects the motion and triggers the main one to record.
smokinjoe
Post by smokinjoe » Thu Feb 04, 2021 11:52 am
Substreams can be so small why bother? If you don't want them hogging disk space I would make a zfs dataset for just the 640x480 substreams and make it so that it gets to your 80% number quicker, i.e. give that dataset only 5gb and it will auto clean. use your other datasets for your other cameras/events.
I am happy with Zoneminder on FreeNAS as a plugin, on 11.3-U5 it took me less than 5 minutes to have it working almost 100% perfect.
