Leverage CakePHP for web UI
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
carbenium
Post by carbenium »
Currently the web UI is driven by a custom PHP "framework" and shares functionality wise probably quite a bit with the API.
I'd suggest to merge/rewrite the UI by leveraging the already existing API project.
Couple of thoughts:
* less maintenance burden since lots of things (routing, ORM, ...) are implemented by CakePHP
* views can use the template engine
* skins can be implemented using CakePHP themes
Any thoughts from the maintainers if this is something that can be explored?
Re: Leverage CakePHP for web UI
The maintainer(me) doesn't really like cakephp and can't be bothered.
If you want to do it, be my guest! I'll try to support in any way that I can.
Also, feel free to do it in python or whatever else tickles your fancy.
carbenium
Post by carbenium »
Thanks for the supporting words!
I must admit CakePHP isn't my favourite as well. I just didn't want to present too extreme ideas as a first-time contributor.
I'll try to come up with some ideas in the next weeks.
