Sorry more "NUBE" questions again. (I have read through the manual too!)
I have my zoneminder now up and running from the excellent live cd (done full install). I am trying now to access the web interface from another PC; at the moment just on my internal network. I put in the IP address of my linux box, but all I see is a webpage that says "Its Works!". Where have I gone wrong please.
Cheers again
Web server ???
The "it works" page shows that your web server is running... The zoneminder stuff can be found at
http://www.mydomain.co.uk/zm
(obviously replace www.mydomain.co.uk with your specific details).
I don't know if the use of "/zm" is supposed to deter opportunist people from finding your installation over the web? Maybe someone will know.
Section 8.7 again
I think the ability to mess with the zones is considered to be the "Monitors" setting, but I must admit that I haven't checked.
