Can I enable telnet?
Is there an easy way to enable telnet access to the zoneminder box that I setup using the live-cd?
SSH access should be enabled on the live cd, to connect to it just download an ssh client such as putty.exe
http://the.earth.li/~sgtatham/putty/lat ... /putty.exe
- Contact:
whatever you set your user namer and password as. By default root access isnt allowed and needs to be turned on
James Wilson
