1.34 or 1.35
1.34 or 1.35
Hi.
Should I go with version 1.35 or 1.34? Or is just 1.35 "beta"?
Re: 1.34 or 1.35
1.35 is bleeding edge development so unless you need some feature that is in 1.35, stick with 1.34.
Re: 1.34 or 1.35
Hello, I am new to Zoneminder but like it and plan to use it. I need the ability to have cameras on two different network interfaces. I am running that now and believe that is the reason the ONVIF probe never finds anything even when I can use the ONVIF driver manager tool to configure these cameras. I was thinking from what I read here that v1.35 might help this issue.
Is V1.35 still planned for an October 2020 release date?
Re: 1.34 or 1.35
1.35 lets you select the network to scan so yes it will help.
No, I think January 1st is more likely.
Users browsing this forum: No registered users and 6 guests
