Container on QNAP - how do I access
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
tre4b
Post by tre4b » Fri Sep 20, 2019 3:56 pm
So I thought I would look at ZM, i.e. I'm as noob as can be.
Loaded the docker image I found that seemed to be based around the ZM github site on QNAP. Loaded up and seems to be running however if I try and access the root address I get.
Unable to connect to ZM db.SQLSTATE[HY000] [1045] Access denied for user 'zmuser'@'localhost' (using password: YES)
If instead I try to acces the /zm address I get
Not Found
The requested URL /zm was not found on this server.
Apache/2.4.18 (Ubuntu) Server at 10.0.10.24 Port 80
There is definitely something running, I just cannot figure out how to actually get at the device. I can access the terminal through the QNAP container stuff, I just do not know what to look for. Any pointers that would get me into it to start with. From there I can work out where to go ;-)
