error install zoneminder
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
gallico
Post by gallico »
Did you mean
I installed zoneminder with all dependencies on debian wheezy derivative.
ok apache, mysql ok, at the end of zoneminder installation does not start, and not off.
apt-get install zoneminder back to me this message, it looks like a permissions problem.
installation as root on a PuppyLinux derivative (debian Porteus).
error
Setting up zoneminder (1.25.0-4) ...
Insecure directory in $ENV{PATH} while running with -T switch at /usr/share/perl5/ZoneMinder/General.pm line 107.
ZoneMinder is stopped
invoke-rc.d: initscript zoneminder, action "status" failed.
Starting ZoneMinder: Insecure directory in $ENV{PATH} while running with -T switch at /usr/share/perl5/ZoneMinder/General.pm line 107.
failure
Nerre
Re: error install zoneminder
Post by Nerre »
This sounds as if you have made "bad" changes to your PATH. What does 'echo $PATH' say?
in puppy linux this error is caused a write permission on a directory in the environment path. Look at the permissions for each directory in the environment path. Change to read only and it will be fixed.
