Installing on Kubuntu 13.10
Has anyone got ZoneMinder working on Ubuntu 13.10 64bit.
I followed "Installation from a .deb" but with advice from "Fixing Apache after Ubuntu 13.10 upgrade".
When I access localhost I get a blank page.
Any ideas, please? Thank you.
Re: Installing on Kubuntu 13.10
Just tried this, but:
Help please. Thank you.
peter@dv-460mt:/var/log$ service zoneminder start
Starting ZoneMinder: failure
Failure isn't very helpful.
locate your zmpkg.pl file and attempt to execute it directly and post back what the standard output is. Also monitor your system log.
Hans
Hans
Thanks Hans, but I just found this, which got me sorted:
"When you try to access the ZM web page you get a blank screen.
The issue is in the php.ini file and is a value called:
short_open_tag = Off
This value needs to be set to On
sudo nano /etc/php5/apache2/php.ini
find the short_open_tag = Off and change it to On
Ctrl +o to save the file Ctrl +x to exit
/etc/init.d/apache2 force-reload
and now you should see the ZM page! "
Alas, not quite sorted, but I am in the console thus:
ZoneMinder Console - Running - v1.25.0
Logged in as admin, configured for Low Bandwidth
However, when I click "Add New Monitor", NOTHING HAPPENS!
Please Help, Hans, or anybody else, I have spent so long reading documentation and forum posts, but I won't give in!
Thank you.
23/02/2014 12:19:55 dv-460mt zmpkg[20450] INF [Command: status]
23/02/2014 12:19:55 dv-460mt zmpkg[20461] INF [Command: stop]
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF ['zmaudit.pl -c' stopping at 14/02/23 12:19:55]
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF [Can't find child with pid of '11607']
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF ['zmaudit.pl -c' exited, signal 14]
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF ['zmfilter.pl ' stopping at 14/02/23 12:19:55]
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF ['zmfilter.pl ' exited, signal 14]
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF ['zmwatch.pl ' stopping at 14/02/23 12:19:55]
23/02/2014 12:19:55 dv-460mt zmdc[11606] INF ['zmwatch.pl ' exited, signal 14]
23/02/2014 12:20:05 dv-460mt zmdc[11606] INF [Server shutdown at 14/02/23 12:20:05]
23/02/2014 12:20:06 dv-460mt zmpkg[20511] INF [Command: start]
23/02/2014 12:20:06 dv-460mt zmdc[20528] INF [Server starting at 14/02/23 12:20:06]
23/02/2014 12:20:09 dv-460mt zmdc[20528] INF ['zmfilter.pl' starting at 14/02/23 12:20:09, pid = 20552]
23/02/2014 12:20:09 dv-460mt zmdc[20552] INF ['zmfilter.pl' started at 14/02/23 12:20:09]
23/02/2014 12:20:09 dv-460mt zmdc[20528] INF ['zmaudit.pl -c' starting at 14/02/23 12:20:09, pid = 20557]
23/02/2014 12:20:09 dv-460mt zmdc[20557] INF ['zmaudit.pl -c' started at 14/02/23 12:20:09]
23/02/2014 12:20:09 dv-460mt zmfilter[20552] INF [Scanning for events]
23/02/2014 12:20:09 dv-460mt zmdc[20528] INF ['zmwatch.pl' starting at 14/02/23 12:20:09, pid = 20562]
23/02/2014 12:20:09 dv-460mt zmdc[20562] INF ['zmwatch.pl' started at 14/02/23 12:20:09]
23/02/2014 12:20:09 dv-460mt zmwatch[20562] INF [Watchdog starting]
23/02/2014 12:20:09 dv-460mt zmwatch[20562] INF [Watchdog pausing for 30 seconds]
23/02/2014 12:45:40 dv-460mt zmu[20757] INF [Authenticated user 'admin']
23/02/2014 12:45:40 dv-460mt zmu[20757] ERR [Failed to enumerate standard 0: Inappropriate ioctl for device]
23/02/2014 13:17:40 dv-460mt zmpkg[20955] INF [Command: status]
23/02/2014 13:18:07 dv-460mt zmpkg[20970] INF [Command: stop]
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF ['zmfilter.pl ' stopping at 14/02/23 13:18:07]
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF [Can't find child with pid of '20529']
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF ['zmfilter.pl ' exited, signal 14]
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF ['zmaudit.pl -c' stopping at 14/02/23 13:18:07]
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF ['zmaudit.pl -c' exited, signal 14]
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF ['zmwatch.pl ' stopping at 14/02/23 13:18:07]
23/02/2014 13:18:07 dv-460mt zmdc[20528] INF ['zmwatch.pl ' exited, signal 14]
23/02/2014 13:18:17 dv-460mt zmdc[20528] INF [Server shutdown at 14/02/23 13:18:17]
23/02/2014 13:18:17 dv-460mt zmfix[21005] DB1 [LogOpts: level=DB1/DB1, screen=OFF, database=INF, logfile=DB1->/tmp/zm/zm_debug.log.21005, syslog=DB9]
23/02/2014 13:18:17 dv-460mt zmpkg[21007] INF [Command: start]
23/02/2014 13:18:17 dv-460mt zmfix[21019] DB1 [LogOpts: level=DB1/DB1, screen=OFF, database=INF, logfile=DB1->/tmp/zm/zm_debug.log.21019, syslog=DB9]
23/02/2014 13:18:18 dv-460mt zmdc[21024] INF [Server starting at 14/02/23 13:18:18]
23/02/2014 13:18:21 dv-460mt zmdc[21024] INF ['zmfilter.pl' starting at 14/02/23 13:18:21, pid = 21048]
23/02/2014 13:18:21 dv-460mt zmdc[21048] INF ['zmfilter.pl' started at 14/02/23 13:18:21]
23/02/2014 13:18:21 dv-460mt zmdc[21024] INF ['zmaudit.pl -c' starting at 14/02/23 13:18:21, pid = 21053]
23/02/2014 13:18:21 dv-460mt zmdc[21053] INF ['zmaudit.pl -c' started at 14/02/23 13:18:21]
23/02/2014 13:18:21 dv-460mt zmfilter[21048] INF [Scanning for events]
23/02/2014 13:18:21 dv-460mt zmdc[21024] INF ['zmwatch.pl' starting at 14/02/23 13:18:21, pid = 21058]
23/02/2014 13:18:21 dv-460mt zmdc[21058] INF ['zmwatch.pl' started at 14/02/23 13:18:21]
23/02/2014 13:18:21 dv-460mt zmwatch[21058] INF [Watchdog starting]
23/02/2014 13:18:21 dv-460mt zmwatch[21058] INF [Watchdog pausing for 30 seconds]
140224 18:41:38 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
140224 18:41:38 [Note] Plugin 'FEDERATED' is disabled.
140224 18:41:38 InnoDB: The InnoDB memory heap is disabled
140224 18:41:38 InnoDB: Mutexes and rw_locks use GCC atomic builtins
140224 18:41:38 InnoDB: Compressed tables use zlib 1.2.8
140224 18:41:38 InnoDB: Using Linux native AIO
140224 18:41:38 InnoDB: Initializing buffer pool, size = 128.0M
140224 18:41:38 InnoDB: Completed initialization of buffer pool
140224 18:41:38 InnoDB: highest supported file format is Barracuda.
140224 18:41:38 InnoDB: Waiting for the background threads to start
140224 18:41:39 InnoDB: 5.5.35 started; log sequence number 1595705
140224 18:41:39 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
140224 18:41:39 [Note] - '127.0.0.1' resolves to '127.0.0.1';
140224 18:41:39 [Note] Server socket created on IP: '127.0.0.1'.
140224 18:41:40 [Note] Event Scheduler: Loaded 0 events
140224 18:41:40 [Note] /usr/sbin/mysqld: ready for connections.
Version: '5.5.35-0ubuntu0.13.10.2' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Ubuntu)
140224 18:41:41 [ERROR] /usr/sbin/mysqld: Table './zm/Config' is marked as crashed and should be repaired
140224 18:41:41 [Warning] Checking table: './zm/Config'
140224 18:41:41 [ERROR] /usr/sbin/mysqld: Table './zm/Logs' is marked as crashed and should be repaired
140224 18:41:41 [Warning] Checking table: './zm/Logs'
*** PLEASE HELP, THANK YOU ***
Please could someone help me?
When I click "Add New Monitor", NOTHING HAPPENS!
Have found this in mysql log but I do not know how to repair tables or how to do anything in mysql:
Can I delete the database then reinstall it, maybe? If so how would I do this? Where is the ZM database?
Any help or suggestions would be very much appreciated. Thank you.
I will do:
Seems a bad installation.
PacoLM
apt-get purge zoneminder
apt-get install zoneminder
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
Thanks for the tip PacoLM. I`ve done the following:
But still when I click "Add New Monitor", NOTHING HAPPENS!
Any ideas what I should try next, anybody? Thank you.
Your cambozola installation is not working, search how to install it and this will fix your problem (hopefully).
TelegramBot
Thanks PacoLM, here is what I have just done:
But still, when I click "Add New Monitor", NOTHING HAPPENS!
More help please. Thanks.
Peter.
sudo cd /usr/src && wget http://www.andywilcock.com/code/cambozola/cambozola-latest.tar.gz
sudo tar -xzvf cambozola-latest.tar.gz
sudo cp cambozola-0.935/dist/cambozola.jar /usr/share/zoneminder
sudo service zoneminder restart
sudo apache2ctl restart
Peter.
I am using Firefox 27.0.1
But, in the javascript console I get:
Peter.
Anyone know Why? Please help, thanks.TypeError: window.addEvent is not a function
Peter.
I never could get my cameras working with Kubuntu 13.10. they would just show up as a blank screen. So I went ahead and just migrated to 14.10 Beta. I noticed a couple things right away. First, my system felt a little "zippier". Mabye that's just wishful thinking, but it sure aint slower.
Second, and most important - ZoneMinder is working better than ever! No camera dropouts on my IP cameras, which I did get frequently on Kubuntu 13.04 and ZoneMinde 1.25.
So ZoneMinder 1.26.5 on Kubuntu 14.10 64 bit.... This solution worked well for me, but if you have a system that you really can't slide into beta, then this may not be something you're willing to try. Kubuntu 14.10 should be stable in late April I think.
Thank you davetib, please confirm, are you sure about 14.10, can I assume you mean 14.04?
