rdmerlin is the package matainer and the ZMarch cd the zm forum seamed appriopriait place to ask.
What are the packages needed to upgrade to the latest svn version of zm or if some one eles has done it on arch linux/ zmarch cd please post.
when i say upgrade i mean via the AUR so the package manger knows about it.
or should pacman -Su cover the deps
Upgrade zmarch to svn useing AUR
In case anyone else trys this be aware if you dont have 2gb free bad things happen. (They are fixable though)
anyways I did a full upgrade
installed ffmpeg-svn
now trying to use the zoneminder svn package
and i get
==> ERROR: Integrity checks are missing.
Error: Makepkg was unable to build zoneminder package.
and i get
Dont you love new features
anyways i get
anyways i get
collect: recompiling zm_sdp.cpp
collect: relinking
zm_local_camera.o: In function `vidioctl(int, int, void*)':
zm_local_camera.cpp:(.text+0x27f): undefined reference to `v4l2_ioctl'
zm_local_camera.o: In function `LocalCamera::PostCapture()':
zm_local_camera.cpp:(.text+0x430): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x483): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x4bf): undefined reference to `v4l1_ioctl'
zm_local_camera.o: In function `LocalCamera::Contrast(int)':
zm_local_camera.cpp:(.text+0x962): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x98b): undefined reference to `v4l1_ioctl'
zm_local_camera.o:zm_local_camera.cpp:(.text+0xbca): more undefined references to `v4l1_ioctl' follow
zm_local_camera.o: In function `LocalCamera::GetCurrentSettings(char const*, char*, int, bool)':
zm_local_camera.cpp:(.text+0x1c91): undefined reference to `v4l1_open'
zm_local_camera.cpp:(.text+0x1cf9): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x2014): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x20fd): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x24eb): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x261d): undefined reference to `v4l1_close'
zm_local_camera.o: In function `LocalCamera::Terminate()':
zm_local_camera.cpp:(.text+0x3ddf): undefined reference to `v4l1_close'
zm_local_camera.cpp:(.text+0x3e0f): undefined reference to `v4l1_munmap'
zm_local_camera.cpp:(.text+0x3ea7): undefined reference to `v4l2_munmap'
zm_local_camera.o: In function `LocalCamera::Initialise()':
zm_local_camera.cpp:(.text+0x40f2): undefined reference to `v4l1_open'
zm_local_camera.cpp:(.text+0x46dd): undefined reference to `v4l2_mmap'
zm_local_camera.cpp:(.text+0x4921): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x49ae): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x49f1): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x4a40): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x4a72): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x4b05): undefined reference to `v4l1_mmap'
zm_local_camera.cpp:(.text+0x5552): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x5595): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x55b9): undefined reference to `v4l1_ioctl'
zm_local_camera.cpp:(.text+0x55eb): undefined reference to `v4l1_ioctl'
zm_local_camera.o: In function `LocalCamera::PrimeCapture()':
zm_local_camera.cpp:(.text+0x5f48): undefined reference to `v4l1_ioctl'
collect2: ld returned 1 exit status
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/home/user/build/zoneminder/src/ZoneMinder-1.24.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/user/build/zoneminder/src/ZoneMinder-1.24.2'
make: *** [all] Error 2
==> ERROR: Build Failed.
Aborting...
Got it
http://bbs.archlinux.org/viewtopic.php?pid=642032
needs to be added before ./configure in PKBUILDexport LDFLAGS="${LDFLAGS//-Wl,--as-needed}"
is coming up random places may be my php version being too high
using zoneminde-svn (if debugging is turned up) Also as a waring when php 6 comes out split() will be gone.
Deprecated: Function split() is deprecated in /var/lib/zm/www/skins/classic/views/options.php on line 193
The big prob is
The big prob is
my shared memory was fine before and my original sysctrl is still there11/10/09 20:58:52.051120 zmc_m4[23226].DB2-zm_remote_camera_http.cpp/69 [Request: GET /axis-cgi/mjpg/video.cgi?resolution=800x600 HTTP/1.1
User-Agent: ZoneMinder/1.24.2
Host: 192.168.0.94
Connection: Keep-Alive
11/10/09 20:58:52.054671 zmc_m4[23226].DB1-zm_monitor.cpp/338 [monitor purpose=1]
11/10/09 20:58:52.054706 zmc_m4[23226].DB1-zm_monitor.cpp/345 [mem.size=57601192]
11/10/09 20:58:52.054760 zmc_m4[23226].ERR-zm_monitor.cpp/378 [Can't shmget, probably not enough shared memory space free: Invalid argument]
