ZM Live CD
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
ddrg
ZM Live CD
Post by ddrg »
Hello Everyone
I've trying to run ZMLiveCd. It boots normally and comes to a KDE screen asking for username and password.
admin/admin does not work, There is a user named "user" but i cannot find the password....
Thank You
Dionysis Droggitis
rdmelin
Re: ZM Live CD
Post by rdmelin »
Hi All,
The usernames and passwords are in index.html in the root of the liveCD. If you insert the disk on a windows machine IE will autorun and display it. The same info is in the README which will display on the desktop everytime you reboot and KDE starts. Dionysis, it sounds like you found yourself at a display manager (KDM) login screen. The system should autologin at reboot to the user desktop, but if you log out from the desktop you will need this info to log back in. From the README:
--------------Please Change These !!!------------------
Passwords:
root: qwerty
user: qwerty
MySQL Passwords
root: mko0nji9
zm_admin: zaq1xsw2
zm_user: zse4xdr5
Zoneminder Passwords
admin: admin
Best regards,
Ross
