ok when i tryed to install zoneminder used wget then i installed all the dependences useing apt-get but then i use dpkg -i it returns an error saying
zoneminder depends on php4 | php5
package php4 not installed
package php5 not installed
dpkg: error processing zoneminder (--install):
dependency problems - leaving configured
Has any one had the same problem and solved it
Thank You in Advance
Ubuntu Server Edition 6.06
The recommended method . . .
After the failure by dpkg -i typing
should pull in everything required.
apt-get -f install
however . . .
Before you do the apt-get step, I'd be interested to know what PHP packages you have installed, if not php4 or php5.
If it's because you've manually installed php there is a dpkg command to tell it to ignore dependencies, but that means it will ignore all the other missing dependencies too . . .
