Optimal capture resolution?
I've been running ZM for years. Been capturing at half PAL resolution, as I never figured out the actual ouput resolution of my cameras.
I have thirteen of these cameras:
http://www.altram.com.pl/Katalogi/Videotronic/fs6_e.pdf
and two of these:
http://www.altram.com.pl/Katalogi/Videotronic/fs7_e.pdf
(-6012P and -7012P)
What is the optimal capture resolution? I know the cameras have X TV-lines (vertical resolution), but what is the optimal horizontal resolution?
and two of these:
(-6012P and -7012P)
Cameras have For 330 TV lines resolution and 460 TV lines resolution. Best match if the number of lines equals with the height of the captured picture. Bigger height is useless.
However in PAL, capturing above 384x288 produces interlacing.
So the recommended settings would be 320x240 for the first type you mentioned, and 384x288 for the second one.
You can however run all in 384x288 to have them equal and look good.
v1.25.0 + Ubuntu Linux 12.04 Server
OK... I have a couple of these too, it seems:
http://www.sanyosecurity.com/np-item/p_ ... 6585p.html
What would be the best capture resolution on these?
OK. Great, thanks .
Is 384x288 "compatible" with the actual ouput from the cameras, though? It won't cause any distortion like if you don't do a linear resize on both axis?
The reason I'm asking is that stored images aren't exactly impressive in quality. Might be JPEG-"noise", though. Perhaps ZM will come with PNG-support as a lossless option. Requires more space, but higher quality might come in handy to some.
Use 100 in the quality thats pretty lossless, but lossless images IMO would be a huge waste of space, much better to get a better source and PAL/NTSC isnt itsgn wrote:One last thing, which palette should I be using? Using RGB24 now, it works, but might be the cause of the crappy images? Seeing the other thread about the "lines" due to shmem, where the images were far better?
James Wilson
as above if you go above half res on your standard )ie pall is 288) then you will get interlace issues. So dont go any higher, or go higher and accept it. Or use ip cams that dont have this issue (ie axis) then you can do multi megapixel.
James Wilson
How do the apps that come with tuner cards give a good picture at full res? Do they do software deinterlacing, or use the hardware differently?jameswilson wrote:as above if you go above half res on your standard )ie pall is 288) then you will get interlace issues. So dont go any higher, or go higher and accept it. Or use ip cams that dont have this issue (ie axis) then you can do multi megapixel.
I'm running my cameras at 352x288 at the moment, but there are some cameras that could greatly benefit from 704x576, at which i get interlacing issues.
I'm using a Kodicom 8800, which I thought was capable of 8x 704x576...
Is there a way to do software deinterlacing? I should have enough cpu cycles to spare for one or two cameras.
thanks
mmm.. looks like the video card does the deinterlacing, at least in a pc with a decent graphics card.eug wrote:How do the apps that come with tuner cards give a good picture at full res? Do they do software deinterlacing, or use the hardware differently?jameswilson wrote:as above if you go above half res on your standard )ie pall is 288) then you will get interlace issues. So dont go any higher, or go higher and accept it. Or use ip cams that dont have this issue (ie axis) then you can do multi megapixel.
It'd be great if ZM could do s/w deinterlacing one day...
edit: looks like deinterlacing is being looked at already.. here's to hoping everything falls into place eventually!
