Is there anyway we can check and then change the camera function from the back end via shell or perl? let say there are 8 cameras and they are all "Mocord" and I want to change to camera 1 - 4 to "Modect" and 5-8 to "Monitor"?
Thanks.
Change Camera function from backend
- zoneminder
- Site Admin
- Contact:
The monitor states will always be accessible in the DB. This you can get easily from perl, or slightly less easily via shell.
You can use run states to control your monitors behaviour. This is easy to do from both perl and shell.
Phil
- zoneminder
- Site Admin
- Contact:
