installation ok ... browser ko
boombari
Post by boombari » Sun Oct 30, 2005 1:34 pm
hi to all,
i have installed zm 1.21.3 on debian sarge ...configure e making ok, ..but when i open the index.php file ...i get this error:
Warning: fopen(): open_basedir restriction in effect. File(/usr/local/etc/zm.conf) is not within the allowed path(s):
Warning: fopen(/usr/local/etc/zm.conf): failed to open stream: Operation not permitted in /var/www/virtual/nethosting.homeip.net/htdocs/zm_config.php on line 29
Could not open config file.
cordel
Post by cordel » Sun Oct 30, 2005 2:21 pm
Your configuration for apache is to strict.
You need to configure apache to be allowed read the zm.conf in /etc
other wise could also be a permissions issue, make sure that zm.conf is owned by your webuser and/or webgroup.
Check the ownership of the zm.conf file first, else you will need to configure apache correctly but most likely just a permissions issue.
Regards,
Cordel
boombari
Post by boombari » Mon Oct 31, 2005 10:02 am
hi,
i have chmoded 777 zm.conf ...but the result is the same :(
where i can modify the apache.conf to read the directory where is /usr/local/etc/zm.conf ?
thanks.
cordel
Post by cordel » Mon Oct 31, 2005 10:31 am
Try checking your php.ini file and see if safe mode is on. This might also restrict apache from going out to read that directory.
The open_base_dir setting is primarily used to prevent php scripts for a particular user from accessing files in another user's account. So usually, any files in your own account should be readable by your own scripts. ie the webuser.
Regards,
Cordel
Users browsing this forum: No registered users and 5 guests
