upgraded libs broke code again..
reza
Post by reza » Tue May 24, 2005 9:03 am
Seems like the latest version of ffmpeg (ffmpeg-devel-0.4.9-9_cvs20050517.rhfc3.at) breaks the code.
The struct AVCodecContext changed. The entries frame_rate and frame_rate_base are no longer there, but replaced with something called pts which really isn't defined. Here's the line from /usr/include/ffmpeg/avcodec.h
     * presentation timestamp in time_base units (time when frame should be shown to user)\
     * if AV_NOPTS_VALUE then frame_rate = 1/time_base will be assumed\
     * - encoding: MUST be set by user\
     * - decoding: set by lavc\
    int64_t pts;\
I commented out
                //c->frame_rate = frame_rate;
                //c->frame_rate_base = 1;
from zm_mpeg.cpp to get zm to recompile. Any thoughts?
Reza
zoneminder
Site Admin
Post by zoneminder » Tue May 24, 2005 11:05 am
Thanks for highlighting this. I'll take a look.
Phil
zengelan
Post by zengelan » Fri Jul 22, 2005 3:31 pm
i just commented out the two line mentioned above.
But now i get another error:
make  all-recursive
make[1]: Entering directory `/root/software/zm-1.21.3'
Making all in src
make[2]: Entering directory `/root/software/zm-1.21.3/src'
if g++ -DHAVE_CONFIG_H -I. -I. -I..  -I/usr/include -I/usr/include   -g -O2 -MT zm_mpeg.o -MD -MP -MF ".deps/zm_mpeg.Tpo" -c -o zm_mpeg.o zm_mpeg.cpp; \
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
zm_mpeg.cpp: In member function `void VideoStream::SetupCodec(int, int, int,
   int, int)':
zm_mpeg.cpp:78: error: cannot convert `AVCodecContext**' to `AVCodecContext*'
   in initialization
zm_mpeg.cpp: In member function `void VideoStream::OpenStream()':
zm_mpeg.cpp:120: error: cannot convert `AVCodecContext**' to `AVCodecContext*'
   in initialization
zm_mpeg.cpp: In destructor `VideoStream::~VideoStream()':
zm_mpeg.cpp:220: error: cannot convert `AVCodecContext**' to `AVCodecContext*'
   for argument `1' to `int avcodec_close(AVCodecContext*)'
zm_mpeg.cpp: In member function `double VideoStream::EncodeFrame(uint8_t*, int,
   bool, unsigned int)':
zm_mpeg.cpp:263: error: cannot convert `AVCodecContext**' to `AVCodecContext*'
   in initialization
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/root/software/zm-1.21.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/software/zm-1.21.3'
make: *** [all] Error 2
Any Ideas?
br andy[quote][/quote]
reza
dunno
Post by reza » Fri Jul 22, 2005 5:57 pm
Looks liek the AVCodecContext might have been misdefined somplace. I stopped upgrading ZM as it seems to break every time I do.
Reza
rjohanne
Did you ever figure this problem out?
Post by rjohanne » Tue Oct 11, 2005 11:13 pm
Hi Zoneminder,
Did you ever figure this compile problem out? I get the same exact errors on FC4, trying to compile zm 1.21.3 with ffmpeg from cvs as of last Sunday.
How do I get around the problem?
thanks
rj
zoneminder
Site Admin
Post by zoneminder » Thu Oct 13, 2005 8:32 pm
The ffmpeg interface changed a while back. I have a version of ZM that works now with the cvs version of ffmpeg. It's not released yet but will be very shortly.
Phil
jameswilson
Post by jameswilson » Thu Oct 13, 2005 8:33 pm
goody goody
James
(Silly smilly face lol)
daveparker01
zm-1.21.4 won't compile with ffmpeg-devel-0.4.9-10_cvs200506
Post by daveparker01 » Thu Dec 15, 2005 4:42 am
Am I right in assuming that building is broken again? zm 1.21.4's release notes suggest that this problem has been fixed, but I'm still seeing
zm_mpeg.cpp:102: error: 'struct AVCodecContext' has no member named 'frame_rate'
zm_mpeg.cpp:103: error: 'struct AVCodecContext' has no member named 'frame_rate_base'
Is there a fix for this (quick or otherwise)? I was going to browse through CVS but I've had no luck finding the repository for zoneminder.
zoneminder
Site Admin
Post by zoneminder » Thu Dec 15, 2005 9:44 am
1.21.4 seems to be broken with respect to ffmpeg 0.4.9-pre1. However 0.4.8 and the cvs release (of ffmpeg) are fine. I would recommend the latter.
1.22.0 works with all (so far) ffmpeg versions.
Phil
reza
hmm
Post by reza » Thu Dec 15, 2005 9:49 am
I might try upgrading. if things break, i'll be unhappy and sad.
reza
jameswilson
Post by jameswilson » Thu Dec 15, 2005 10:14 am
quick homer simpson imprssion
mmmmmmmmmm, 1.22.0..
woohoo!!!
James
James Wilson
daveparker01
Is 1.22.0 available somewhere?
Post by daveparker01 » Thu Dec 15, 2005 6:19 pm
I'd like very much to try this 1.22.0 - I've hit the wall on my FC4 box trying to get an ffmpeg to build that's ostensibly compatible with zoneminder.
The problem is that, given the gcc version I have, ffmpeg 4.8 simply will not compile. And none of the repositories I've got in apt have anything older than 4.9. It's really a nightmare - I've spent many hours just trying to get ffmpeg 4.8 to build. From what I've been able to gather, it's b/c of some known issue with gcc4.
I'd be very overjoyed to have the opportunity to try zm 1.22.0
I'm hoping that zm will support my v4l2 device (which motion pretty much does not afaict).
zoneminder
Site Admin
Post by zoneminder » Sat Dec 17, 2005 10:59 am
Are you saying that the ffmpeg cvs version doesn't compile either, or that it won't link with ZM or neither?
If all you want to do is see if your card works then you can install ZM without ffmpeg as it's not critical for the basic functions.
Phil
SyRenity
Post by SyRenity » Sun Dec 18, 2005 3:04 pm
Hi.
Have you tried to check-out the latest CVS version of FFMPEG, and compile it? It should be compiled fine on GCC 3 and 4.
kbuytaert
Same issu on FC4
Post by kbuytaert » Sun Apr 02, 2006 1:06 pm
I have the same issue on Fedora Core 4.
I can't find any prebuild rpm's either ..
Anyone ?
greetings
Kris
Users browsing this forum: No registered users and 12 guests
