watch mpeg streaming with Mediaplayer
boombari
Post by boombari »
Hi to all,
is it possibile to watch mpeg straming with windows media playes, without make login in zm ?
zoneminder
Site Admin
Post by zoneminder »
It should be (though not tested) but you will have to pass the username and password in the url to zms. You could use the an authentication string instead but you will have to make sure you use the same method as ZM in building it.
Phil
boombari
Post by boombari »
so without autentication isn't possible ?
zoneminder
Site Admin
If you don't have authentication switched on in ZM at all then you should be fine, just copy the URL that the web page uses (use 'view source' to find it).
Phil
boombari
Post by boombari »
ok, but in this way ...everyone can access to zm controll panel, and modify options ?
zoneminder
Site Admin
Yes, potentially. The other alternative is to create a user with only stream 'view' privileges and pass that users detail to zms. Then even if anyone logs in all they'll be able to do is watch the streams anyway.
Phil
