configure problem on Mandrake 10.1, zm 1.20
cordel
Post by cordel » Fri Mar 11, 2005 7:31 pm
The user and password to login is:
admin
Cheers,
Cordel
chris-tux
Post by chris-tux » Fri Mar 11, 2005 10:34 pm
sorry about that stupid question! :oops: I forgot the README file
arggh, chris RTFM :?
thanks again, If I have the courage , when zm will be up (soon I hope), I will post a short HOW TO for the mdk RPM from scratch :wink:
cordel
Post by cordel » Fri Mar 11, 2005 11:52 pm
I think Ross has already writen a howto in the readme doc that installs with the package. You might want to take a glance at it. I know I have plans to do the same withthe Fedora package and it will be done in the next release.
Cheers,
Cordel
chris-tux
Post by chris-tux » Sat Mar 12, 2005 12:49 pm
I didn''t find any howto but perhaps I didn't look at the right place :wink:
Anyway, with a few advices and the original README instructions, it runs all right.
The problem is when you start playing with the RPM, you don't what has configured the rpm for you.
To save time for people wanting to install Ross RPM on Mandrake, I would say:
1- Have apache, php 4 and SQL installed and running,
2- install the zm RPM,
3- as root, modify /etc/zm.conf:
choose a user name and a password,
5- as root, create the sql database:
cd /usr/lib/zm/bin
./zminit
enter root as sql administrator then do not enter a password
6- start zm with service zm start
7- http://localhost/zm/
and then you can join the README instructions of Phil at paragraph 5: Tutorial.
Users browsing this forum: No registered users and 10 guests
