DBD::mysql::st execute failed: Table 'zm.Config'
Posted: Tue Feb 08, 2005 8:31 pm
I found some one else with this problem but I couldn't find an answer so I try again.
I just follow the installation instructions and get to a point where I think the script start to create the tables, then I get the error massage:
Loading config from 'zmconfig.txt'
Loading config from DB
DBD::mysql::st execute failed: Table 'zm.Config' doesn't exist at zmconfig.pl line 1627.
Can't execute: Table 'zm.Config' doesn't exist at zmconfig.pl line 1627.
I do have a db called zm and a user defined with all privileges (not grant option).
Any ideas?
thanks, tord
PS. PERL/PHP/MYSQL is all the latest stuff on MDK 10.1 OE
Any ideas?
thanks, tord
