Card driver
LuChris
Card driver
Post by LuChris »
I have a 8 chipsets card and i dont know if it is supported. Is there a program or something which i can do to test whether the card can be used in linux or even in ZM? I am sure its a BTT card, it comes with windows driver but not linux. I am running it with Fedora Core 2. I am not an expert in linux. Or how can i check if Fedora has detected it?
best regards
curtishall
Post by curtishall »
Paste the contents of 'lspci -v', specifically thing after the 'Multimedia video controller'.
Does your card have a BT8x8 chipset? Do you have the model number if you can't find anything with lspci?
LuChris
Post by LuChris »
Thanks. I did that and i had found a numbers of Mutli media video controller. Total 16 in all. From :-
02:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 11
Memory at dfcfe000 (32-bit, prefetchable)
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
To :-
02:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at dfcf1000 (32-bit, prefetchable)
Does this means that i can now install ZM?
best regards
