Gentoo 64 - emerge zoneminder v1.23.3 faillure
christophe_y2k
Post by christophe_y2k »
Hello, have a serious probleme
since few weeks its impossible to install zoneminder v1.23.3
any idea?
zm_jpeg.h:39: erreur: declaration of C function ‘void jpeg_mem_src(jpeg_decompre ss_struct*, const JOCTET*, int)’ conflicts with
/usr/include/jpeglib.h:959: erreur: previous declaration ‘void jpeg_mem_src(jpeg _decompress_struct*, unsigned char*, long unsigned int)’ here
zm_jpeg.h:40: erreur: declaration of C function ‘void jpeg_mem_dest(jpeg_compres s_struct*, JOCTET*, int*)’ conflicts with
/usr/include/jpeglib.h:956: erreur: previous declaration ‘void jpeg_mem_dest(jpe g_compress_struct*, unsigned char**, long unsigned int*)’ here
In file included from zm_image.h:33,
from zm_image.cpp:21:
zm_image.cpp: In member function ‘bool Image::ReadRaw(const char*)’:
zm_image.cpp:277: attention : ignoring return value of ‘size_t fread(void*, size _t, size_t, FILE*)’, declared with attribute warn_unused_result
zm_image.cpp: In member function ‘bool Image::WriteRaw(const char*) const’:
zm_image.cpp:293: attention : ignoring return value of ‘size_t fwrite(const void *, size_t, size_t, FILE*)’, declared with attribute warn_unused_result
zm_image.cpp: In member function ‘void Image::Blend(const Image&, int) const’:
zm_image.cpp:768: attention : operation on ‘pdest’ may be undefined
In file included from zm_zone.h:27,
from zm_monitor.h:27,
from zmc.cpp:27:
zm_event.h:188: attention : ‘typedef’ was ignored in this declaration
zm_event.h:200: attention : ‘typedef’ was ignored in this declaration
make[2]: *** [zm_image.o] Erreur 1
make[2]: *** Attente des tâches non terminées....
mv -f .deps/zm_config.Tpo .deps/zm_config.Po
In file included from zmc.cpp:27:
zm_monitor.h:114: attention : ‘typedef’ was ignored in this declaration
make[2]: *** [zmc.o] Erreur 1
make[2]: quittant le répertoire « /var/tmp/portage/www-misc/zoneminder-1.23.3/wo rk/ZoneMinder-1.23.3/src »
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le répertoire « /var/tmp/portage/www-misc/zoneminder-1.23.3/wo rk/ZoneMinder-1.23.3 »
make: *** [all] Erreur 2
* ERROR: www-misc/zoneminder-1.23.3 failed:
* emake failed
