Axis 212 PTZ - No control from Zoneminder
mjsameth
Post by mjsameth » Thu Jan 14, 2010 1:16 am
Hello All,
Can somebody post suggestions for configuring monitor for Axis 212 PTZ camera?
Viewing is just fine. Unfortunately, PTZ controls don't work...
Control Type - Axix API v2
Control Device - blank
Control Address - username:password@IP:80
Thanks for any suggestions. I currently have 23 cameras on this system. They are all Panasonic. I have purchased Axis strictly for ability to use PTZ controls.
I appreciate any quick responses or suggestions.
Micah J. Sameth
Data Center Manager
kingofkya
Post by kingofkya » Thu Jan 14, 2010 8:03 pm
Axis ptz is supported out of the the box when you select the ptz option in the options page.
OPT_CONTROL Support controllable (e.g. PTZ) cameras (?)
Then go to the control tab in the camera settings page and select AXIS.
mjsameth
Post by mjsameth » Thu Jan 14, 2010 9:25 pm
I tried many times and have done everything you have mentioned below.....
mjsameth
Post by mjsameth » Fri Jan 29, 2010 1:07 am
Does authentication have anything to do with why it doesn't work? Unfortunately, I haven't figured out a way to have an Axis camera NOT require authentication - so it could be tested. I'm wondering if a configuration file needs to be edited if the camera requires authentication. I'm willing to provide contact info and/or recipriocate for consultation - if their are those who have time or meaningful suggestions. Zoneminder is working fantastic - currently doing motion detection on now 25 views on Data Centers in the NE of the US. Would really like to implement web controls
Users browsing this forum: No registered users and 11 guests
