After upgrading gentoo - no image in zm - libavutil.so.49
christophe_y2k
Post by christophe_y2k »
hello !
after upgrading my gentoo server
no image in ZM V1.23.3
zm run fine but when i wanna to see a cam, broken link no image
but that say video - 2.67 fps and that detect alert but haven't got any image
i precise all work fine before upgrade my gentoo
error in apache
/var/www/localhost/cgi-bin/nph-zms: error while loading libraries: libavutil.so.49: cannot open shared object file: No such file or directory,
i reinstall ffmpeg with no success
haven't got: libavutil.so.49
but i have: libavutil.so.50
new version?
any idea?
Joyeuse fêtes de fin d'année
christophe_y2k
workaround
i create a symbolic link to livavutil.so.50.3.0 present on my system in /usr/lib64 to libavutil.so.49
that works fine but this is a piece of scotch
if anybody have better idea !!!
special thanks to Philip Coombes for this work
now i'm an happy paypal contributor
:D
cordel
Post by cordel »
You would have to rebuild ZM and honestly I'm surprised that simlinking worked since the differences between 4.9 and 5.0 are tremendous.
Matter of fact you might just leave it be as I'm not sure that 1.23.3 can build on the newer ffmpeg without patching.
christophe_y2k
thanks for your reply...
i try to rebuild zm with no succes (when i say rebuild i use the installer from gentoo "emerge zoneminder" not compiling from source)
the latest version is not released for gentoo .
i try to compile from source the latest version on another computer ....
i can't try on my product server
now i know i c'ant upgrade my gentoo "in security" ...
mastertheknife
Post by mastertheknife »
After doing major updates with gentoo, its sometimes necessary to rebuild few things
just run: revdep-rebuild and it should do the job.
braindead0
Re: After upgrading gentoo - no image in zm - libavutil.so.4
Post by braindead0 »
christophe_y2k wrote:hello !
error in apache
new version?
any idea?
Re-emerge apache, should take care of that.
