Zoneminder 1.23X Deleting Events
I cannot understand why the systems take so long to purge images. I simply select to display all of the events and then delete them. It take a long time so purge the images. Why doesn't zoneminder do it immediately?
Last edited by metallica1973 on Sun Feb 08, 2009 3:50 am, edited 2 times in total.
This is probably what you are looking for:
ZM_OPT_FAST_DELETE
Normally an event created as the result of an alarm consists of entries in one or more database tables plus the various files associated with it. When deleting events in the browser it can take a long time to remove all of this if your are trying to do a lot of events at once. It is recommended that you set this option which means that the browser client only deletes the key entries in the events table, which means the events will no longer appear in the listing, and leaves the zmaudit daemon to clear up the rest later.
ZM_OPT_FAST_DELETE
