Suse 10.3, ZM 1.23.1 Can't connect to local MySQL server
keynet
Post by keynet » Sun Feb 17, 2008 4:54 pm
Hi
I've been struggling with this mysql error for a day or so, and tried searching the forums, but am now stuck.
I've tried both the rpm for Suse 10.3 and building from source with the pre-requisites. Both behave the same.
I get
Feb 17 16:15:07 ha-server zmfix[17676]: ERR [Can't connect to server: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)]
Feb 17 16:15:07 ha-server zmpkg[17666]: ERR [Unable to run "sudo -u wwwrun /usr/local/bin/zmfix", output is ""]
zmpkg.log is
02/17/08 16:15:07.452446 zmpkg[17666].INF [Command: start]
02/17/08 16:15:07.452953 zmpkg[17666].DBG [Testing valid shell syntax]
02/17/08 16:15:07.453061 zmpkg[17666].DBG [Testing "sudo -u wwwrun true"]
02/17/08 16:15:07.461883 zmpkg[17666].DBG [Test ok, using format "sudo -u wwwrun <command>"]
02/17/08 16:15:07.462011 zmpkg[17666].DBG [Command: sudo -u wwwrun /usr/local/bin/zmdc.pl check]
02/17/08 16:15:07.608870 zmpkg[17666].DBG [Output: stopped]
02/17/08 16:15:07.608993 zmpkg[17666].DBG [Removing shared memory]
02/17/08 16:15:07.609053 zmpkg[17666].DBG [Checking for shared memory with 'ipcs -m | grep '^0x7a6d00'']
02/17/08 16:15:07.613977 zmpkg[17666].DBG [Command: sudo -u wwwrun /usr/local/bin/zmfix]
02/17/08 16:15:07.623394 zmpkg[17666].ERR [Unable to run "sudo -u wwwrun /usr/local/bin/zmfix", output is ""]
I have checked that mysql is running and used mysqladmin to checkout the basics - that looks OK, it's running.
So I tried editing my.cnf to change the socket location to /tmp/mysql.sock, restarted mysql (the socket location changes as expected), but now zmpkg gives the following error:
DBI connect('database=zm;host=localhost','zm_admin',...) failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder.pm line 33.
Compilation failed in require at /usr/local/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 45.
It appears like different parts of the program are hardwired to look in different places for the socket, and both can't be right at the same time.
Can I change where zmfix is looking for the socket - can't see anything obvious in the source.
But maybe it's some kind of simple permissions problem instead?
Help much appreciated
zoneminder
Site Admin
Post by zoneminder » Mon Feb 18, 2008 10:50 pm
They can sometimes be configured to be in different places. This is a mysql and perl issue rather than ZM. Off the top of my head I can't remember where this config is set so the easiest thing I normally recommend is just creating a soft link from one to the other.
So
ln -s /var/lib/mysql/mysql.sock /tmp/mysql.sock
for example, though do it whichever way round so that the one that exists is first. That way whenever one is created so will the other be.
Phil
keynet
Post by keynet » Thu Feb 21, 2008 12:29 am
Thanks - yes that's got it going
Users browsing this forum: No registered users and 19 guests
