1.36.11
1.36.11
After the latest update, I am no longer able to delete events from the live stream screen after reviewing the event. Events are listed at the bottom of the live stream page. If I select an event from the list by pressing the 'Id' for it, I can view the event. If I don't want to keep this event, I can then press the red button with the garbage can on it. It then asks you to confirm the delete by pressing the red delete button. There are no error messages that pop up and it seems as though everything has worked, but going back to the event list shows that the event I just deleted is still there.
Re: 1.36.11
I found this message in 'web_php.log', 20/11/21 11:47:18.705855 web_php[39783].ERR [::1] [Unrecognised action or insufficient permissions for user admin] at /usr/share/zoneminder/www/includes/functions.php line 1902.
That line corresponds to a function called ajaxCleanup which I cannot find anywhere.
Re: 1.36.11
Hash tag me too.
It's possible to delete them from the events list.
Re: 1.36.11
What platform? Ubuntu?
Re: 1.36.11
Yes, sorry. Ubuntu 20.04.
Re: 1.36.11
Fix found, is in master. Will be pushed to zoneminder-proposed ppa today.
Re: 1.36.11
I have the identical issue as well. I'm running Ubuntu 20.04 server and zoneminder 1.36.11 both are fresh installs as of nov.28.2021.
Was there a fix or workaround?
PS. I'm newish to the linux world.
Re: 1.36.11
So it should appear in the next version of 1.36 - .12 probably.
Post by iconnor » Mon Nov 29, 2021 11:00 am
Top
