1.34.7 video segments erratic
Anyone else seeing erratic segment lengths? I recently upgraded to 1.34.7 on a system that was performing well. I have 20 cameras RTSP and some show erratic segment lengths ... one camera as an example typically 3000 frames ... then you'll see 65, 243, etc and then back to 3000. Logs not showing any obvious errors.
Re: 1.34.7 video segments erratic
Upgraded from what?
Depends how you have the monitors set up, if an event happens during a Mocord session it will do some different behaviour.
Sorry for the delay here ... I'm seeing the zmc process crash on a couple of monitors
This monitor is mocord with source rtsp via ffmpeg and video writer passthru
See a portion of the debug (level 5) below... I can't find the root cause. Tried level 9 debug as well but nothing jumps out.
10/20/21 14:07:25.219840 zmc_m18[206186].DB1-zm_zone_stats.h/54 [ZoneStat: After detect motion zone_id: 18 pixel_diff=48 alarm_pixels=3730 alarm_filter_pixels=0 alarm_blob_pixels=0 alarm_blob
s=0 min_blob_size=0 max_blob_size=0 alarm_box=(0,0=>0,0) alarm_center=(0,0) score=0]
10/20/21 14:07:25.219846 zmc_m18[206186].DB1-zm_zone_stats.h/54 [ZoneStat: GetStats zone_id: 20 pixel_diff=0 alarm_pixels=0 alarm_filter_pixels=0 alarm_blob_pixels=0 alarm_blobs=0 min_blob_si
10/20/21 14:07:25.219851 zmc_m18[206186].DB1-zm_zone_stats.h/54 [ZoneStat: After detect motion zone_id: 20 pixel_diff=0 alarm_pixels=0 alarm_filter_pixels=0 alarm_blob_pixels=0 alarm_blobs=0
10/20/21 14:07:25.219881 zmc_m18[206186].DB3-zm_monitor.cpp/1909 [After motion detection, score:0 last_motion_score(0), new motion score(0)]
10/20/21 14:07:25.219890 zmc_m18[206186].DB2-zm_monitor.cpp/1937 [Have event 3337073 in record]
10/20/21 14:07:25.219897 zmc_m18[206186].DB1-zm_monitor.cpp/2169 [State TAPE because image_count(82)-last_alarm_count(0) > post_event_count(10) and timestamp.tv_sec(1634760429) - recording.tv
_src(1634760418) >= min_section_length(10)]
10/20/21 14:07:25.219903 zmc_m18[206186].DB1-zm_monitor.cpp/2246 [Blending]
10/20/21 14:07:25.230450 zmc_m18[206011].DB1-zm_ffmpeg_camera.cpp/621 [Received terminate in cb]
10/20/21 14:07:25.232523 zmc_m18[206011].DB3-zm_ffmpeg.cpp/69 [ct_type:0 pic_struct:0]
10/20/21 14:07:25.232591 zmc_m18[206011].DB3-zm_ffmpeg.cpp/69 [unknown SEI type 128]
10/20/21 14:07:25.235762 zmc_m18[206011].DB2-zm_ffmpeg_camera.cpp/236 [ffmpeg_camera in: pts: 2880000 * 1/90000=32.000000, dts: 2880000, size: 553752, stream_index: 0, video flags: 0001, keyf
rame(1) pos: -1, duration: 18000]
10/20/21 14:07:25.235911 zmc_m18[206011].DB4-zm_monitor.cpp/2499 [Back from capture result=1 image count 160]
10/20/21 14:07:25.236065 zmc_m18[206011].DB2-zm_monitor.cpp/2527 [Have packet stream_index:0 ?= videostream_id: 0 q.vpktcount 90 event? 1 image_count 160]
10/20/21 14:07:25.236100 zmc_m18[206011].DB2-zm_packetqueue.cpp/147 [packet counts for 0 is 91]
10/20/21 14:07:25.236121 zmc_m18[206011].DB4-zm_packetqueue.cpp/161 [it 0x561b7342db60 not at end]
10/20/21 14:07:25.236135 zmc_m18[206011].DB4-zm_packetqueue.cpp/161 [it 0x561b7342da20 not at end]
10/20/21 14:07:25.236142 zmc_m18[206011].DB4-zm_packetqueue.cpp/166 [packetqueue queuepacket, unlocked signalling]
10/20/21 14:07:25.236156 zmc_m18[206011].DB1-zm_packetqueue.cpp/327 [Clearing packetqueue]
10/20/21 14:07:25.236170 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 70]
10/20/21 14:07:25.236180 zmc_m18[206011].DB4-zm_packet.h/102 [packet 70 locked]
10/20/21 14:07:25.236191 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:70 with keyframe:1, video frames in queue:91 max: 10, queuesize:91]
10/20/21 14:07:25.236205 zmc_m18[206011].DB4-zm_packet.h/112 [packet 70 unlocked]
10/20/21 14:07:25.236262 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 71]
10/20/21 14:07:25.236287 zmc_m18[206011].DB4-zm_packet.h/102 [packet 71 locked]
10/20/21 14:07:25.236303 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:71 with keyframe:0, video frames in queue:91 max: 10, queuesize:90]
10/20/21 14:07:25.236320 zmc_m18[206011].DB4-zm_packet.h/112 [packet 71 unlocked]
10/20/21 14:07:25.236367 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 72]
10/20/21 14:07:25.236388 zmc_m18[206011].DB4-zm_packet.h/102 [packet 72 locked]
10/20/21 14:07:25.236399 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:72 with keyframe:0, video frames in queue:91 max: 10, queuesize:89]
10/20/21 14:07:25.236412 zmc_m18[206011].DB4-zm_packet.h/112 [packet 72 unlocked]
10/20/21 14:07:25.236436 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 73]
10/20/21 14:07:25.236456 zmc_m18[206011].DB4-zm_packet.h/102 [packet 73 locked]
10/20/21 14:07:25.236469 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:73 with keyframe:0, video frames in queue:91 max: 10, queuesize:88]
10/20/21 14:07:25.236482 zmc_m18[206011].DB4-zm_packet.h/112 [packet 73 unlocked]
10/20/21 14:07:25.236511 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 74]
10/20/21 14:07:25.236534 zmc_m18[206011].DB4-zm_packet.h/102 [packet 74 locked]
10/20/21 14:07:25.236544 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:74 with keyframe:0, video frames in queue:91 max: 10, queuesize:87]
10/20/21 14:07:25.236591 zmc_m18[206011].DB4-zm_packet.h/112 [packet 74 unlocked]
10/20/21 14:07:25.236618 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 75]
10/20/21 14:07:25.236633 zmc_m18[206011].DB4-zm_packet.h/102 [packet 75 locked]
10/20/21 14:07:25.236639 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:75 with keyframe:0, video frames in queue:91 max: 10, queuesize:86]
10/20/21 14:07:25.236651 zmc_m18[206011].DB4-zm_packet.h/112 [packet 75 unlocked]
10/20/21 14:07:25.236674 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 76]
10/20/21 14:07:25.236688 zmc_m18[206011].DB4-zm_packet.h/102 [packet 76 locked]
10/20/21 14:07:25.236694 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:76 with keyframe:0, video frames in queue:91 max: 10, queuesize:85]
10/20/21 14:07:25.236701 zmc_m18[206011].DB4-zm_packet.h/112 [packet 76 unlocked]
10/20/21 14:07:25.236713 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 77]
10/20/21 14:07:25.236720 zmc_m18[206011].DB4-zm_packet.h/102 [packet 77 locked]
10/20/21 14:07:25.236725 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:77 with keyframe:0, video frames in queue:91 max: 10, queuesize:84]
10/20/21 14:07:25.236732 zmc_m18[206011].DB4-zm_packet.h/112 [packet 77 unlocked]
10/20/21 14:07:25.236742 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 78]
10/20/21 14:07:25.236753 zmc_m18[206011].DB4-zm_packet.h/102 [packet 78 locked]
10/20/21 14:07:25.236760 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:78 with keyframe:0, video frames in queue:91 max: 10, queuesize:83]
10/20/21 14:07:25.236765 zmc_m18[206011].DB4-zm_packet.h/112 [packet 78 unlocked]
10/20/21 14:07:25.236775 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 79]
10/20/21 14:07:25.236781 zmc_m18[206011].DB4-zm_packet.h/102 [packet 79 locked]
10/20/21 14:07:25.236786 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:79 with keyframe:0, video frames in queue:91 max: 10, queuesize:82]
10/20/21 14:07:25.236792 zmc_m18[206011].DB4-zm_packet.h/112 [packet 79 unlocked]
10/20/21 14:07:25.236800 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 80]
10/20/21 14:07:25.236806 zmc_m18[206011].DB4-zm_packet.h/102 [packet 80 locked]
10/20/21 14:07:25.236812 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:80 with keyframe:1, video frames in queue:91 max: 10, queuesize:81]
10/20/21 14:07:25.236818 zmc_m18[206011].DB4-zm_packet.h/112 [packet 80 unlocked]
10/20/21 14:07:25.236831 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 81]
10/20/21 14:07:25.236838 zmc_m18[206011].DB4-zm_packet.h/102 [packet 81 locked]
10/20/21 14:07:25.236843 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:81 with keyframe:0, video frames in queue:91 max: 10, queuesize:80]
10/20/21 14:07:25.236848 zmc_m18[206011].DB4-zm_packet.h/112 [packet 81 unlocked]
10/20/21 14:07:25.236864 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 82]
10/20/21 14:07:25.258133 zmc_m18[206185].DB1-zm_packet.cpp/130 [got frame: format 12 yuvj420p 3840x2160 linesize:3840x1920 pts: 2016900 keyframe: 0]
10/20/21 14:07:25.258193 zmc_m18[206185].DB3-zm_packet.cpp/208 [Same pix format yuvj420p so not hwtransferring. sw_pix_fmt is yuvj420p]
10/20/21 14:07:25.258227 zmc_m18[206185].DB1-zm_image.cpp/249 [PopulateFrame: width 3840 height 2160 linesize 15360 colours 4 imagesize 33177600 rgba]
10/20/21 14:07:25.258235 zmc_m18[206185].DB1-zm_image.cpp/281 [PopulateFrame: width 3840 height 2160 linesize 15360 colours 4 imagesize 33177600]
10/20/21 14:07:25.258241 zmc_m18[206185].DB1-zm_image.cpp/282 [Image.Populate(frame): format 26 rgba 3840x2160 linesize:15360x0 pts: -9223372036854775808 keyframe: 1]
10/20/21 14:07:25.258246 zmc_m18[206185].DB1-zm_image.cpp/311 [source frame before convert: format 12 yuvj420p 3840x2160 linesize:3840x1920 pts: 2016900 keyframe: 0]
10/20/21 14:07:25.271041 zmc_m18[206185].DB1-zm_image.cpp/323 [dest frame after convert: format 26 rgba 3840x2160 linesize:15360x0 pts: 2016900 keyframe: 1]
10/20/21 14:07:25.271081 zmc_m18[206185].DB3-zm_monitor.cpp/2718 [Timestamping]
10/20/21 14:07:25.271089 zmc_m18[206185].DB2-zm_monitor.cpp/2769 [annotating southeast-entrance - 20/10/21 14:07:15]
10/20/21 14:07:25.271115 zmc_m18[206185].DB2-zm_monitor.cpp/2771 [done annotating southeast-entrance - 20/10/21 14:07:15]
10/20/21 14:07:25.271500 zmc_m18[206186].DB1-zm_monitor.cpp/2248 [Done Blending]
10/20/21 14:07:25.271528 zmc_m18[206186].DB2-zm_event.cpp/427 [have_video_keyframe 1 codec_type 0 == video? 1 packet keyframe 0]
10/20/21 14:07:25.271538 zmc_m18[206186].DB2-zm_event.cpp/429 [Adding to event: pts: 1476900, dts: 1476900, size: 36635, stream_index: 0, flags: 0000, keyframe(0) pos: -1, duration: 18000]
10/20/21 14:07:25.271550 zmc_m18[206186].DB2-zm_videostore.cpp/1191 [Doing passthrough, just copy packet: pts: 1476900 * 1/90000=16.410000, dts: 1476900, size: 36635, stream_index: 0, video f
10/20/21 14:07:25.271565 zmc_m18[206186].DB2-zm_videostore.cpp/1216 [after pts adjustment: pts: 1368000 * 1/90000=15.200000, dts: 1368000, size: 36635, stream_index: 0, video flags: 0000, key
10/20/21 14:07:25.271579 zmc_m18[206186].DB2-zm_videostore.cpp/1330 [finished pkt: pts: 1368000 * 1/90000=15.200000, dts: 1368000, size: 36635, stream_index: 0, video flags: 0000, keyframe(0)
10/20/21 14:07:25.271592 zmc_m18[206186].DB3-zm_videostore.cpp/1332 [next_dts for stream 0 has become 1386000]
10/20/21 14:07:25.271690 zmc_m18[206186].DB4-zm_videostore.cpp/1339 [Success writing packet]
10/20/21 14:07:25.271709 zmc_m18[206186].DB1-zm_event.cpp/521 [Have frame type Normal from score(0) state 4 frames 83 bulk frame interval 100 and mod83]
10/20/21 14:07:25.271721 zmc_m18[206186].DB1-zm_monitor.cpp/2269 [Deleting image data for 82]
10/20/21 14:07:25.271733 zmc_m18[206186].DB1-zm_monitor.cpp/1677 [analysis_image_count(83) motion_count(82) fps_report_interval(100) mod0]
10/20/21 14:07:25.271742 zmc_m18[206186].DB2-zm_packetqueue.cpp/477 [Incrementing 0x561b7342da20, queue size 79, end? 0]
10/20/21 14:07:25.271749 zmc_m18[206186].DB4-zm_packet.h/112 [packet 82 unlocked]
10/20/21 14:07:25.271768 zmc_m18[206011].DB4-zm_packet.h/102 [packet 82 locked]
10/20/21 14:07:25.271794 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:82 with keyframe:0, video frames in queue:91 max: 10, queuesize:79]
10/20/21 14:07:25.271805 zmc_m18[206011].DB4-zm_packet.h/112 [packet 82 unlocked]
10/20/21 14:07:25.271848 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 83]
10/20/21 14:07:25.271862 zmc_m18[206011].DB4-zm_packet.h/102 [packet 83 locked]
10/20/21 14:07:25.271869 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:83 with keyframe:0, video frames in queue:91 max: 10, queuesize:78]
10/20/21 14:07:25.271877 zmc_m18[206011].DB4-zm_packet.h/112 [packet 83 unlocked]
10/20/21 14:07:25.271902 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 84]
10/20/21 14:07:25.271916 zmc_m18[206011].DB4-zm_packet.h/102 [packet 84 locked]
10/20/21 14:07:25.271925 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:84 with keyframe:0, video frames in queue:91 max: 10, queuesize:77]
10/20/21 14:07:25.271933 zmc_m18[206011].DB4-zm_packet.h/112 [packet 84 unlocked]
10/20/21 14:07:25.271957 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 85]
10/20/21 14:07:25.271967 zmc_m18[206011].DB4-zm_packet.h/102 [packet 85 locked]
10/20/21 14:07:25.271974 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:85 with keyframe:0, video frames in queue:91 max: 10, queuesize:76]
10/20/21 14:07:25.271983 zmc_m18[206011].DB4-zm_packet.h/112 [packet 85 unlocked]
10/20/21 14:07:25.272005 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 86]
10/20/21 14:07:25.272016 zmc_m18[206011].DB4-zm_packet.h/102 [packet 86 locked]
10/20/21 14:07:25.272050 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:86 with keyframe:0, video frames in queue:91 max: 10, queuesize:75]
10/20/21 14:07:25.272061 zmc_m18[206011].DB4-zm_packet.h/112 [packet 86 unlocked]
10/20/21 14:07:25.272082 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 87]
10/20/21 14:07:25.272093 zmc_m18[206011].DB4-zm_packet.h/102 [packet 87 locked]
10/20/21 14:07:25.272101 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:87 with keyframe:0, video frames in queue:91 max: 10, queuesize:74]
10/20/21 14:07:25.272111 zmc_m18[206011].DB4-zm_packet.h/112 [packet 87 unlocked]
10/20/21 14:07:25.272133 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 88]
10/20/21 14:07:25.272143 zmc_m18[206011].DB4-zm_packet.h/102 [packet 88 locked]
10/20/21 14:07:25.272150 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:88 with keyframe:0, video frames in queue:91 max: 10, queuesize:73]
10/20/21 14:07:25.272160 zmc_m18[206011].DB4-zm_packet.h/112 [packet 88 unlocked]
10/20/21 14:07:25.272217 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 89]
10/20/21 14:07:25.272234 zmc_m18[206011].DB4-zm_packet.h/102 [packet 89 locked]
10/20/21 14:07:25.272242 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:89 with keyframe:0, video frames in queue:91 max: 10, queuesize:72]
10/20/21 14:07:25.272252 zmc_m18[206011].DB4-zm_packet.h/112 [packet 89 unlocked]
10/20/21 14:07:25.272267 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 90]
10/20/21 14:07:25.272279 zmc_m18[206011].DB4-zm_packet.h/102 [packet 90 locked]
10/20/21 14:07:25.272286 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:90 with keyframe:1, video frames in queue:91 max: 10, queuesize:71]
10/20/21 14:07:25.272296 zmc_m18[206011].DB4-zm_packet.h/112 [packet 90 unlocked]
10/20/21 14:07:25.272317 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 91]
10/20/21 14:07:25.272329 zmc_m18[206011].DB4-zm_packet.h/102 [packet 91 locked]
10/20/21 14:07:25.272337 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:91 with keyframe:0, video frames in queue:91 max: 10, queuesize:70]
10/20/21 14:07:25.272344 zmc_m18[206011].DB4-zm_packet.h/112 [packet 91 unlocked]
10/20/21 14:07:25.272378 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 92]
10/20/21 14:07:25.272454 zmc_m18[206011].DB4-zm_packet.h/102 [packet 92 locked]
10/20/21 14:07:25.272468 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:92 with keyframe:0, video frames in queue:91 max: 10, queuesize:69]
10/20/21 14:07:25.272479 zmc_m18[206011].DB4-zm_packet.h/112 [packet 92 unlocked]
10/20/21 14:07:25.272504 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 93]
10/20/21 14:07:25.272518 zmc_m18[206011].DB4-zm_packet.h/102 [packet 93 locked]
10/20/21 14:07:25.272526 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:93 with keyframe:0, video frames in queue:91 max: 10, queuesize:68]
10/20/21 14:07:25.272534 zmc_m18[206011].DB4-zm_packet.h/112 [packet 93 unlocked]
10/20/21 14:07:25.272552 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 94]
10/20/21 14:07:25.272560 zmc_m18[206011].DB4-zm_packet.h/102 [packet 94 locked]
10/20/21 14:07:25.272567 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:94 with keyframe:0, video frames in queue:91 max: 10, queuesize:67]
10/20/21 14:07:25.272575 zmc_m18[206011].DB4-zm_packet.h/112 [packet 94 unlocked]
10/20/21 14:07:25.272592 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 95]
10/20/21 14:07:25.272604 zmc_m18[206011].DB4-zm_packet.h/102 [packet 95 locked]
10/20/21 14:07:25.272613 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:95 with keyframe:0, video frames in queue:91 max: 10, queuesize:66]
10/20/21 14:07:25.272636 zmc_m18[206011].DB4-zm_packet.h/112 [packet 95 unlocked]
10/20/21 14:07:25.272672 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 96]
10/20/21 14:07:25.272685 zmc_m18[206011].DB4-zm_packet.h/102 [packet 96 locked]
10/20/21 14:07:25.272692 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:96 with keyframe:0, video frames in queue:91 max: 10, queuesize:65]
10/20/21 14:07:25.272702 zmc_m18[206011].DB4-zm_packet.h/112 [packet 96 unlocked]
10/20/21 14:07:25.272737 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 97]
10/20/21 14:07:25.272755 zmc_m18[206011].DB4-zm_packet.h/102 [packet 97 locked]
10/20/21 14:07:25.272763 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:97 with keyframe:0, video frames in queue:91 max: 10, queuesize:64]
10/20/21 14:07:25.272773 zmc_m18[206011].DB4-zm_packet.h/112 [packet 97 unlocked]
10/20/21 14:07:25.272793 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 98]
10/20/21 14:07:25.272805 zmc_m18[206011].DB4-zm_packet.h/102 [packet 98 locked]
10/20/21 14:07:25.272813 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:98 with keyframe:0, video frames in queue:91 max: 10, queuesize:63]
10/20/21 14:07:25.272822 zmc_m18[206011].DB4-zm_packet.h/112 [packet 98 unlocked]
10/20/21 14:07:25.272836 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 99]
10/20/21 14:07:25.272846 zmc_m18[206011].DB4-zm_packet.h/102 [packet 99 locked]
10/20/21 14:07:25.272854 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:99 with keyframe:0, video frames in queue:91 max: 10, queuesize:62]
10/20/21 14:07:25.272861 zmc_m18[206011].DB4-zm_packet.h/112 [packet 99 unlocked]
10/20/21 14:07:25.272879 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 100]
10/20/21 14:07:25.272890 zmc_m18[206011].DB4-zm_packet.h/102 [packet 100 locked]
10/20/21 14:07:25.272898 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:100 with keyframe:1, video frames in queue:91 max: 10, queuesize:61]
10/20/21 14:07:25.272906 zmc_m18[206011].DB4-zm_packet.h/112 [packet 100 unlocked]
10/20/21 14:07:25.272921 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 101]
10/20/21 14:07:25.272930 zmc_m18[206011].DB4-zm_packet.h/102 [packet 101 locked]
10/20/21 14:07:25.272937 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:101 with keyframe:0, video frames in queue:91 max: 10, queuesize:60]
10/20/21 14:07:25.272945 zmc_m18[206011].DB4-zm_packet.h/112 [packet 101 unlocked]
10/20/21 14:07:25.272958 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 102]
10/20/21 14:07:25.272967 zmc_m18[206011].DB4-zm_packet.h/102 [packet 102 locked]
10/20/21 14:07:25.272975 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:102 with keyframe:0, video frames in queue:91 max: 10, queuesize:59]
10/20/21 14:07:25.272984 zmc_m18[206011].DB4-zm_packet.h/112 [packet 102 unlocked]
10/20/21 14:07:25.272999 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 103]
10/20/21 14:07:25.273014 zmc_m18[206011].DB4-zm_packet.h/102 [packet 103 locked]
10/20/21 14:07:25.273024 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:103 with keyframe:0, video frames in queue:91 max: 10, queuesize:58]
10/20/21 14:07:25.273033 zmc_m18[206011].DB4-zm_packet.h/112 [packet 103 unlocked]
10/20/21 14:07:25.273047 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 104]
10/20/21 14:07:25.273059 zmc_m18[206011].DB4-zm_packet.h/102 [packet 104 locked]
10/20/21 14:07:25.273067 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:104 with keyframe:0, video frames in queue:91 max: 10, queuesize:57]
10/20/21 14:07:25.273075 zmc_m18[206011].DB4-zm_packet.h/112 [packet 104 unlocked]
10/20/21 14:07:25.273088 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 105]
10/20/21 14:07:25.273099 zmc_m18[206011].DB4-zm_packet.h/102 [packet 105 locked]
10/20/21 14:07:25.273117 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:105 with keyframe:0, video frames in queue:91 max: 10, queuesize:56]
10/20/21 14:07:25.273129 zmc_m18[206011].DB4-zm_packet.h/112 [packet 105 unlocked]
10/20/21 14:07:25.273144 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 106]
10/20/21 14:07:25.273156 zmc_m18[206011].DB4-zm_packet.h/102 [packet 106 locked]
10/20/21 14:07:25.273165 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:106 with keyframe:0, video frames in queue:91 max: 10, queuesize:55]
10/20/21 14:07:25.273181 zmc_m18[206011].DB4-zm_packet.h/112 [packet 106 unlocked]
10/20/21 14:07:25.273285 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 107]
10/20/21 14:07:25.273304 zmc_m18[206011].DB4-zm_packet.h/102 [packet 107 locked]
10/20/21 14:07:25.273313 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:107 with keyframe:0, video frames in queue:91 max: 10, queuesize:54]
10/20/21 14:07:25.273324 zmc_m18[206011].DB4-zm_packet.h/112 [packet 107 unlocked]
10/20/21 14:07:25.277510 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 108]
10/20/21 14:07:25.277544 zmc_m18[206011].DB4-zm_packet.h/102 [packet 108 locked]
10/20/21 14:07:25.277551 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:108 with keyframe:0, video frames in queue:91 max: 10, queuesize:53]
10/20/21 14:07:25.277558 zmc_m18[206011].DB4-zm_packet.h/112 [packet 108 unlocked]
10/20/21 14:07:25.277578 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 109]
10/20/21 14:07:25.277584 zmc_m18[206011].DB4-zm_packet.h/102 [packet 109 locked]
10/20/21 14:07:25.277588 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:109 with keyframe:0, video frames in queue:91 max: 10, queuesize:52]
10/20/21 14:07:25.277594 zmc_m18[206011].DB4-zm_packet.h/112 [packet 109 unlocked]
10/20/21 14:07:25.277608 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 110]
10/20/21 14:07:25.277613 zmc_m18[206011].DB4-zm_packet.h/102 [packet 110 locked]
10/20/21 14:07:25.277618 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:110 with keyframe:1, video frames in queue:91 max: 10, queuesize:51]
10/20/21 14:07:25.277622 zmc_m18[206011].DB4-zm_packet.h/112 [packet 110 unlocked]
10/20/21 14:07:25.277641 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 111]
10/20/21 14:07:25.277646 zmc_m18[206011].DB4-zm_packet.h/102 [packet 111 locked]
10/20/21 14:07:25.277651 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:111 with keyframe:0, video frames in queue:91 max: 10, queuesize:50]
10/20/21 14:07:25.277656 zmc_m18[206011].DB4-zm_packet.h/112 [packet 111 unlocked]
10/20/21 14:07:25.277665 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 112]
10/20/21 14:07:25.283781 zmc_m18[206185].DB4-zm_packet.h/112 [packet 112 unlocked]
10/20/21 14:07:25.283870 zmc_m18[206011].DB4-zm_packet.h/102 [packet 112 locked]
10/20/21 14:07:25.283892 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:112 with keyframe:0, video frames in queue:91 max: 10, queuesize:49]
10/20/21 14:07:25.283908 zmc_m18[206011].DB4-zm_packet.h/112 [packet 112 unlocked]
10/20/21 14:07:25.283969 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 113]
10/20/21 14:07:25.283980 zmc_m18[206011].DB4-zm_packet.h/102 [packet 113 locked]
10/20/21 14:07:25.283986 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:113 with keyframe:0, video frames in queue:91 max: 10, queuesize:48]
10/20/21 14:07:25.283993 zmc_m18[206011].DB4-zm_packet.h/112 [packet 113 unlocked]
10/20/21 14:07:25.283999 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 114]
10/20/21 14:07:25.284008 zmc_m18[206011].DB4-zm_packet.h/102 [packet 114 locked]
10/20/21 14:07:25.284012 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:114 with keyframe:0, video frames in queue:91 max: 10, queuesize:47]
10/20/21 14:07:25.284037 zmc_m18[206011].DB4-zm_packet.h/112 [packet 114 unlocked]
10/20/21 14:07:25.284044 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 115]
10/20/21 14:07:25.284049 zmc_m18[206011].DB4-zm_packet.h/102 [packet 115 locked]
10/20/21 14:07:25.284053 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:115 with keyframe:0, video frames in queue:91 max: 10, queuesize:46]
10/20/21 14:07:25.284058 zmc_m18[206011].DB4-zm_packet.h/112 [packet 115 unlocked]
10/20/21 14:07:25.284067 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 116]
10/20/21 14:07:25.284072 zmc_m18[206011].DB4-zm_packet.h/102 [packet 116 locked]
10/20/21 14:07:25.284076 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:116 with keyframe:0, video frames in queue:91 max: 10, queuesize:45]
10/20/21 14:07:25.284081 zmc_m18[206011].DB4-zm_packet.h/112 [packet 116 unlocked]
10/20/21 14:07:25.284088 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 117]
10/20/21 14:07:25.284092 zmc_m18[206011].DB4-zm_packet.h/102 [packet 117 locked]
10/20/21 14:07:25.284097 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:117 with keyframe:0, video frames in queue:91 max: 10, queuesize:44]
10/20/21 14:07:25.284101 zmc_m18[206011].DB4-zm_packet.h/112 [packet 117 unlocked]
10/20/21 14:07:25.284107 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 118]
10/20/21 14:07:25.284111 zmc_m18[206011].DB4-zm_packet.h/102 [packet 118 locked]
10/20/21 14:07:25.284115 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:118 with keyframe:0, video frames in queue:91 max: 10, queuesize:43]
10/20/21 14:07:25.284120 zmc_m18[206011].DB4-zm_packet.h/112 [packet 118 unlocked]
10/20/21 14:07:25.284126 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 119]
10/20/21 14:07:25.284130 zmc_m18[206011].DB4-zm_packet.h/102 [packet 119 locked]
10/20/21 14:07:25.284135 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:119 with keyframe:0, video frames in queue:91 max: 10, queuesize:42]
10/20/21 14:07:25.284139 zmc_m18[206011].DB4-zm_packet.h/112 [packet 119 unlocked]
10/20/21 14:07:25.284147 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 120]
10/20/21 14:07:25.284152 zmc_m18[206011].DB4-zm_packet.h/102 [packet 120 locked]
10/20/21 14:07:25.284156 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:120 with keyframe:1, video frames in queue:91 max: 10, queuesize:41]
10/20/21 14:07:25.284161 zmc_m18[206011].DB4-zm_packet.h/112 [packet 120 unlocked]
10/20/21 14:07:25.284169 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 121]
10/20/21 14:07:25.284174 zmc_m18[206011].DB4-zm_packet.h/102 [packet 121 locked]
10/20/21 14:07:25.284178 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:121 with keyframe:0, video frames in queue:91 max: 10, queuesize:40]
10/20/21 14:07:25.284183 zmc_m18[206011].DB4-zm_packet.h/112 [packet 121 unlocked]
10/20/21 14:07:25.284191 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 122]
10/20/21 14:07:25.284195 zmc_m18[206011].DB4-zm_packet.h/102 [packet 122 locked]
10/20/21 14:07:25.284200 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:122 with keyframe:0, video frames in queue:91 max: 10, queuesize:39]
10/20/21 14:07:25.284205 zmc_m18[206011].DB4-zm_packet.h/112 [packet 122 unlocked]
10/20/21 14:07:25.284210 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 123]
10/20/21 14:07:25.284215 zmc_m18[206011].DB4-zm_packet.h/102 [packet 123 locked]
10/20/21 14:07:25.284219 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:123 with keyframe:0, video frames in queue:91 max: 10, queuesize:38]
10/20/21 14:07:25.284224 zmc_m18[206011].DB4-zm_packet.h/112 [packet 123 unlocked]
10/20/21 14:07:25.284229 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 124]
10/20/21 14:07:25.284242 zmc_m18[206011].DB4-zm_packet.h/102 [packet 124 locked]
10/20/21 14:07:25.284247 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:124 with keyframe:0, video frames in queue:91 max: 10, queuesize:37]
10/20/21 14:07:25.284252 zmc_m18[206011].DB4-zm_packet.h/112 [packet 124 unlocked]
10/20/21 14:07:25.284258 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 125]
10/20/21 14:07:25.284263 zmc_m18[206011].DB4-zm_packet.h/102 [packet 125 locked]
10/20/21 14:07:25.284267 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:125 with keyframe:0, video frames in queue:91 max: 10, queuesize:36]
10/20/21 14:07:25.284272 zmc_m18[206011].DB4-zm_packet.h/112 [packet 125 unlocked]
10/20/21 14:07:25.284276 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 126]
10/20/21 14:07:25.284281 zmc_m18[206011].DB4-zm_packet.h/102 [packet 126 locked]
10/20/21 14:07:25.284285 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:126 with keyframe:0, video frames in queue:91 max: 10, queuesize:35]
10/20/21 14:07:25.284290 zmc_m18[206011].DB4-zm_packet.h/112 [packet 126 unlocked]
10/20/21 14:07:25.284295 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 127]
10/20/21 14:07:25.284299 zmc_m18[206011].DB4-zm_packet.h/102 [packet 127 locked]
10/20/21 14:07:25.284304 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:127 with keyframe:0, video frames in queue:91 max: 10, queuesize:34]
10/20/21 14:07:25.284308 zmc_m18[206011].DB4-zm_packet.h/112 [packet 127 unlocked]
10/20/21 14:07:25.284316 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 128]
10/20/21 14:07:25.284321 zmc_m18[206011].DB4-zm_packet.h/102 [packet 128 locked]
10/20/21 14:07:25.284325 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:128 with keyframe:0, video frames in queue:91 max: 10, queuesize:33]
10/20/21 14:07:25.284330 zmc_m18[206011].DB4-zm_packet.h/112 [packet 128 unlocked]
10/20/21 14:07:25.284335 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 129]
10/20/21 14:07:25.284340 zmc_m18[206011].DB4-zm_packet.h/102 [packet 129 locked]
10/20/21 14:07:25.284344 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:129 with keyframe:0, video frames in queue:91 max: 10, queuesize:32]
10/20/21 14:07:25.284349 zmc_m18[206011].DB4-zm_packet.h/112 [packet 129 unlocked]
10/20/21 14:07:25.284354 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 130]
10/20/21 14:07:25.284359 zmc_m18[206011].DB4-zm_packet.h/102 [packet 130 locked]
10/20/21 14:07:25.284363 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:130 with keyframe:1, video frames in queue:91 max: 10, queuesize:31]
10/20/21 14:07:25.284368 zmc_m18[206011].DB4-zm_packet.h/112 [packet 130 unlocked]
10/20/21 14:07:25.284373 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 131]
10/20/21 14:07:25.284378 zmc_m18[206011].DB4-zm_packet.h/102 [packet 131 locked]
10/20/21 14:07:25.284382 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:131 with keyframe:0, video frames in queue:91 max: 10, queuesize:30]
10/20/21 14:07:25.284387 zmc_m18[206011].DB4-zm_packet.h/112 [packet 131 unlocked]
10/20/21 14:07:25.284394 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 132]
10/20/21 14:07:25.284398 zmc_m18[206011].DB4-zm_packet.h/102 [packet 132 locked]
10/20/21 14:07:25.284403 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:132 with keyframe:0, video frames in queue:91 max: 10, queuesize:29]
10/20/21 14:07:25.284407 zmc_m18[206011].DB4-zm_packet.h/112 [packet 132 unlocked]
10/20/21 14:07:25.284414 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 133]
10/20/21 14:07:25.284419 zmc_m18[206011].DB4-zm_packet.h/102 [packet 133 locked]
10/20/21 14:07:25.284423 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:133 with keyframe:0, video frames in queue:91 max: 10, queuesize:28]
10/20/21 14:07:25.284432 zmc_m18[206011].DB4-zm_packet.h/112 [packet 133 unlocked]
10/20/21 14:07:25.284437 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 134]
10/20/21 14:07:25.284442 zmc_m18[206011].DB4-zm_packet.h/102 [packet 134 locked]
10/20/21 14:07:25.284446 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:134 with keyframe:0, video frames in queue:91 max: 10, queuesize:27]
10/20/21 14:07:25.284451 zmc_m18[206011].DB4-zm_packet.h/112 [packet 134 unlocked]
10/20/21 14:07:25.284456 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 135]
10/20/21 14:07:25.284461 zmc_m18[206011].DB4-zm_packet.h/102 [packet 135 locked]
10/20/21 14:07:25.284465 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:135 with keyframe:0, video frames in queue:91 max: 10, queuesize:26]
10/20/21 14:07:25.284470 zmc_m18[206011].DB4-zm_packet.h/112 [packet 135 unlocked]
10/20/21 14:07:25.284475 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 136]
10/20/21 14:07:25.284480 zmc_m18[206011].DB4-zm_packet.h/102 [packet 136 locked]
10/20/21 14:07:25.284484 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:136 with keyframe:0, video frames in queue:91 max: 10, queuesize:25]
10/20/21 14:07:25.284489 zmc_m18[206011].DB4-zm_packet.h/112 [packet 136 unlocked]
10/20/21 14:07:25.284495 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 137]
10/20/21 14:07:25.284500 zmc_m18[206011].DB4-zm_packet.h/102 [packet 137 locked]
10/20/21 14:07:25.284504 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:137 with keyframe:0, video frames in queue:91 max: 10, queuesize:24]
10/20/21 14:07:25.284509 zmc_m18[206011].DB4-zm_packet.h/112 [packet 137 unlocked]
10/20/21 14:07:25.284514 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 138]
10/20/21 14:07:25.284519 zmc_m18[206011].DB4-zm_packet.h/102 [packet 138 locked]
10/20/21 14:07:25.284523 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:138 with keyframe:0, video frames in queue:91 max: 10, queuesize:23]
10/20/21 14:07:25.284528 zmc_m18[206011].DB4-zm_packet.h/112 [packet 138 unlocked]
10/20/21 14:07:25.284533 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 139]
10/20/21 14:07:25.284538 zmc_m18[206011].DB4-zm_packet.h/102 [packet 139 locked]
10/20/21 14:07:25.284542 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:139 with keyframe:0, video frames in queue:91 max: 10, queuesize:22]
10/20/21 14:07:25.284547 zmc_m18[206011].DB4-zm_packet.h/112 [packet 139 unlocked]
10/20/21 14:07:25.284554 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 140]
10/20/21 14:07:25.284558 zmc_m18[206011].DB4-zm_packet.h/102 [packet 140 locked]
10/20/21 14:07:25.284563 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:140 with keyframe:1, video frames in queue:91 max: 10, queuesize:21]
10/20/21 14:07:25.284567 zmc_m18[206011].DB4-zm_packet.h/112 [packet 140 unlocked]
10/20/21 14:07:25.284573 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 141]
10/20/21 14:07:25.284578 zmc_m18[206011].DB4-zm_packet.h/102 [packet 141 locked]
10/20/21 14:07:25.284582 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:141 with keyframe:0, video frames in queue:91 max: 10, queuesize:20]
10/20/21 14:07:25.284587 zmc_m18[206011].DB4-zm_packet.h/112 [packet 141 unlocked]
10/20/21 14:07:25.284592 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 142]
10/20/21 14:07:25.284596 zmc_m18[206011].DB4-zm_packet.h/102 [packet 142 locked]
10/20/21 14:07:25.284601 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:142 with keyframe:0, video frames in queue:91 max: 10, queuesize:19]
10/20/21 14:07:25.284605 zmc_m18[206011].DB4-zm_packet.h/112 [packet 142 unlocked]
10/20/21 14:07:25.284632 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 143]
10/20/21 14:07:25.284641 zmc_m18[206011].DB4-zm_packet.h/102 [packet 143 locked]
10/20/21 14:07:25.284646 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:143 with keyframe:0, video frames in queue:91 max: 10, queuesize:18]
10/20/21 14:07:25.284651 zmc_m18[206011].DB4-zm_packet.h/112 [packet 143 unlocked]
10/20/21 14:07:25.284659 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 144]
10/20/21 14:07:25.284664 zmc_m18[206011].DB4-zm_packet.h/102 [packet 144 locked]
10/20/21 14:07:25.284669 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:144 with keyframe:0, video frames in queue:91 max: 10, queuesize:17]
10/20/21 14:07:25.284673 zmc_m18[206011].DB4-zm_packet.h/112 [packet 144 unlocked]
10/20/21 14:07:25.284680 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 145]
10/20/21 14:07:25.284684 zmc_m18[206011].DB4-zm_packet.h/102 [packet 145 locked]
10/20/21 14:07:25.284689 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:145 with keyframe:0, video frames in queue:91 max: 10, queuesize:16]
10/20/21 14:07:25.284694 zmc_m18[206011].DB4-zm_packet.h/112 [packet 145 unlocked]
10/20/21 14:07:25.284700 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 146]
10/20/21 14:07:25.284704 zmc_m18[206011].DB4-zm_packet.h/102 [packet 146 locked]
10/20/21 14:07:25.284709 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:146 with keyframe:0, video frames in queue:91 max: 10, queuesize:15]
10/20/21 14:07:25.284713 zmc_m18[206011].DB4-zm_packet.h/112 [packet 146 unlocked]
10/20/21 14:07:25.284720 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 147]
10/20/21 14:07:25.284725 zmc_m18[206011].DB4-zm_packet.h/102 [packet 147 locked]
10/20/21 14:07:25.284729 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:147 with keyframe:0, video frames in queue:91 max: 10, queuesize:14]
10/20/21 14:07:25.284733 zmc_m18[206011].DB4-zm_packet.h/112 [packet 147 unlocked]
10/20/21 14:07:25.284738 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 148]
10/20/21 14:07:25.284743 zmc_m18[206011].DB4-zm_packet.h/102 [packet 148 locked]
10/20/21 14:07:25.284747 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:148 with keyframe:0, video frames in queue:91 max: 10, queuesize:13]
10/20/21 14:07:25.284752 zmc_m18[206011].DB4-zm_packet.h/112 [packet 148 unlocked]
10/20/21 14:07:25.284757 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 149]
10/20/21 14:07:25.284761 zmc_m18[206011].DB4-zm_packet.h/102 [packet 149 locked]
10/20/21 14:07:25.284766 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:149 with keyframe:0, video frames in queue:91 max: 10, queuesize:12]
10/20/21 14:07:25.284770 zmc_m18[206011].DB4-zm_packet.h/112 [packet 149 unlocked]
10/20/21 14:07:25.284776 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 150]
10/20/21 14:07:25.284781 zmc_m18[206011].DB4-zm_packet.h/102 [packet 150 locked]
10/20/21 14:07:25.284785 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:150 with keyframe:1, video frames in queue:91 max: 10, queuesize:11]
10/20/21 14:07:25.284790 zmc_m18[206011].DB4-zm_packet.h/112 [packet 150 unlocked]
10/20/21 14:07:25.284796 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 151]
10/20/21 14:07:25.284800 zmc_m18[206011].DB4-zm_packet.h/102 [packet 151 locked]
10/20/21 14:07:25.284805 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:151 with keyframe:0, video frames in queue:91 max: 10, queuesize:10]
10/20/21 14:07:25.284809 zmc_m18[206011].DB4-zm_packet.h/112 [packet 151 unlocked]
10/20/21 14:07:25.284815 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 152]
10/20/21 14:07:25.284819 zmc_m18[206011].DB4-zm_packet.h/102 [packet 152 locked]
10/20/21 14:07:25.284823 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:152 with keyframe:0, video frames in queue:91 max: 10, queuesize:9]
10/20/21 14:07:25.284836 zmc_m18[206011].DB4-zm_packet.h/112 [packet 152 unlocked]
10/20/21 14:07:25.284843 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 153]
10/20/21 14:07:25.284848 zmc_m18[206011].DB4-zm_packet.h/102 [packet 153 locked]
10/20/21 14:07:25.284852 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:153 with keyframe:0, video frames in queue:91 max: 10, queuesize:8]
10/20/21 14:07:25.284857 zmc_m18[206011].DB4-zm_packet.h/112 [packet 153 unlocked]
10/20/21 14:07:25.284862 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 154]
10/20/21 14:07:25.284867 zmc_m18[206011].DB4-zm_packet.h/102 [packet 154 locked]
10/20/21 14:07:25.284871 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:154 with keyframe:0, video frames in queue:91 max: 10, queuesize:7]
10/20/21 14:07:25.284876 zmc_m18[206011].DB4-zm_packet.h/112 [packet 154 unlocked]
10/20/21 14:07:25.284881 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 155]
10/20/21 14:07:25.284886 zmc_m18[206011].DB4-zm_packet.h/102 [packet 155 locked]
10/20/21 14:07:25.284890 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:155 with keyframe:0, video frames in queue:91 max: 10, queuesize:6]
10/20/21 14:07:25.284895 zmc_m18[206011].DB4-zm_packet.h/112 [packet 155 unlocked]
10/20/21 14:07:25.284900 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 156]
10/20/21 14:07:25.284905 zmc_m18[206011].DB4-zm_packet.h/102 [packet 156 locked]
10/20/21 14:07:25.284909 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:156 with keyframe:0, video frames in queue:91 max: 10, queuesize:5]
10/20/21 14:07:25.284914 zmc_m18[206011].DB4-zm_packet.h/112 [packet 156 unlocked]
10/20/21 14:07:25.284919 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 157]
10/20/21 14:07:25.284923 zmc_m18[206011].DB4-zm_packet.h/102 [packet 157 locked]
10/20/21 14:07:25.284928 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:157 with keyframe:0, video frames in queue:91 max: 10, queuesize:4]
10/20/21 14:07:25.284932 zmc_m18[206011].DB4-zm_packet.h/112 [packet 157 unlocked]
10/20/21 14:07:25.284938 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 158]
10/20/21 14:07:25.284942 zmc_m18[206011].DB4-zm_packet.h/102 [packet 158 locked]
10/20/21 14:07:25.284946 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:158 with keyframe:0, video frames in queue:91 max: 10, queuesize:3]
10/20/21 14:07:25.284951 zmc_m18[206011].DB4-zm_packet.h/112 [packet 158 unlocked]
10/20/21 14:07:25.284956 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 159]
10/20/21 14:07:25.284961 zmc_m18[206011].DB4-zm_packet.h/102 [packet 159 locked]
10/20/21 14:07:25.284965 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:159 with keyframe:0, video frames in queue:91 max: 10, queuesize:2]
10/20/21 14:07:25.284970 zmc_m18[206011].DB4-zm_packet.h/112 [packet 159 unlocked]
10/20/21 14:07:25.284975 zmc_m18[206011].DB4-zm_packet.h/99 [locking packet 160]
10/20/21 14:07:25.284980 zmc_m18[206011].DB4-zm_packet.h/102 [packet 160 locked]
10/20/21 14:07:25.284984 zmc_m18[206011].DB1-zm_packetqueue.cpp/335 [Deleting a packet with stream index:0 image_index:160 with keyframe:1, video frames in queue:91 max: 10, queuesize:1]
10/20/21 14:07:25.284989 zmc_m18[206011].DB4-zm_packet.h/112 [packet 160 unlocked]
10/20/21 14:07:25.284994 zmc_m18[206011].DB1-zm_packetqueue.cpp/347 [Packetqueue is clear, deleting iterators]
10/20/21 14:07:25.284999 zmc_m18[206011].DB1-zm_packetqueue.cpp/362 [Packetqueue is clear, notifying]
10/20/21 14:07:25.285004 zmc_m18[206011].INF-zm_monitor.cpp/3109 [southeast-entrance: image_count:161 - Closing event 3337073, shutting down]
10/20/21 14:07:25.285049 zmc_m18[206011].DB1-zm_monitor.cpp/2781 [close event thread is not joinable]
10/20/21 14:07:25.285068 zmc_m18[206011].DB1-zm_monitor.cpp/2783 [Starting thread to close event]
10/20/21 14:07:25.285165 zmc_m18[206011].DB1-zm_monitor.cpp/2785 [Nulling event]
10/20/21 14:07:25.285187 zmc_m18[207155].DB4-zm_event.cpp/230 [Deleting video store]
10/20/21 14:07:25.285209 zmc_m18[207155].DB4-zm_videostore.cpp/636 [Flushing interleaved queues]
10/20/21 14:07:25.285235 zmc_m18[207155].DB1-zm_videostore.cpp/639 [Writing trailer]
10/20/21 14:07:25.285977 zmc_m18[207155].DB3-zm_videostore.cpp/644 [Success Writing trailer]
10/20/21 14:07:25.285993 zmc_m18[207155].DB4-zm_videostore.cpp/650 [Closing]
10/20/21 14:07:25.286001 zmc_m18[207155].DB2-zm_ffmpeg.cpp/69 [Statistics: 0 seeks, 30 writeouts]
10/20/21 14:07:25.286025 zmc_m18[207155].DB3-zm_videostore.cpp/670 [Freeing video_out_ctx]
10/20/21 14:07:25.286040 zmc_m18[207155].DB4-zm_videostore.cpp/724 [free context]
10/20/21 14:07:25.286063 zmc_m18[207155].DB4-zm_swscale.cpp/69 [SWScale object destroyed]
10/20/21 14:07:25.286074 zmc_m18[207155].DB2-zm_event.cpp/242 [start_time: 1634760418. 715446 end_time: 1634760429.710034]
10/20/21 14:07:25.286206 zmc_m18[206015].DB1-zm_db.cpp/189 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line
` ) VALUES ( 1634760445.285004, 'zmc_m18', 0, 206011, 0, 'INF', 'southeast-entrance: image_count:161 - Closing event 3337073, shutting down', 'zm_monitor.cpp', 3109 )]
10/20/21 14:07:25.287823 zmc_m18[207155].DB2-zm_db.cpp/218 [Success running sql update UPDATE Events SET Name='Event-3337073', EndDateTime = from_unixtime(1634760429), Length = 11.00, Frames
= 83, AlarmFrames = 0, TotScore = 0, AvgScore = 0, MaxScore = 0 WHERE Id = 3337073 AND Name='New Event'. Rows modified 1]
10/20/21 14:07:25.296183 zmc_m18[206011].DB1-zm_ffmpeg_camera.cpp/621 [Received terminate in cb]
10/20/21 14:07:25.296270 zmc_m18[206011].DB1-zm_monitor.cpp/1069 [Setting shared_data->valid = false]
10/20/21 14:07:25.302599 zmc_m18[206011].DB1-zm_db.cpp/189 [Success running sql query INSERT INTO Monitor_Status (MonitorId,Status) VALUES (18, 'NotRunning') ON DUPLICATE KEY UPDATE Status='N
otRunning']
10/20/21 14:07:25.302655 zmc_m18[206011].DB1-zmc.cpp/381 [terminating]
root@smdvr01:/var/log/zm#
otRunning']
I also upgraded to 1.36.9 from 1.36.7 and the behavior continues...fyi
From the debug log ... 10/20/21 14:07:25.296183 zmc_m18[206011].DB1-zm_ffmpeg_camera.cpp/621 [Received terminate in cb]
Not sure if this is meaningful ... running Ubuntu 20.04 standard build with ppa repository ffmpeg 4.2.4
