ZMC not analyzing random monitors
Posted: Wed Apr 07, 2021 2:45 pm
Good day, Zoneminder community.
Long story (TL/DR version):
Right now I am on the latest build as of this morning. Apr. 7, 2021; 1.35.23, and still experiencing the same problem. We have been maintaining this system with updates fairly regularly, at least once every week or two, and I can only say that this issue was first noticed about three to four weeks ago. It's an Ubuntu 20.04.2 system. This system was set up new about five months ago, and up until this issue started, we have been having no problems with it since the first small issues I discovered before it went live.
The problem is that some of my monitors won't detect motion and record. I have a nine camera system, and only four or five of the nine monitors will decide to detect motion. If I let ZM run for a day or so, those same four or five monitors will continue to analyze, and the same four or five monitors which weren't being analyzed will continue to not be analyzed, so it doesn't appear that they spontaneously start working and fail working; when I start Zoneminder, it so far appears that it will be those same monitors with problems. They play fine in the console window, and look fine on ZMNinja, but the monitors which have problems simply refuse to detect motion.
If I restart Zoneminder, chances are very good that the monitors which don't get analyzed will change. If I look at the process list, all nine instances of ZMC will be running and consuming around the normal amount of CPU that they always have.
The cameras are IP based h.264 devices. They were originally set up as camera passthrough for recording, so I was only storing the mpeg files for events - this was successful for several tens of thousands of events over the past handful of months that the system was in use.
To troubleshoot, I changed to encoding and saving jpeg files, changed image buffer sizes to big and small amounts, dropped the Analysis FPS to 1, then 5, then back to default (empty), deleted and recreated all the monitors, toggled the "Analysis Enabled" option for each source, and basically diddled with everything I could think of, including cussing and shaking my finger at the server to no avail. The system still exhibits this problem.
Thinking that it was something I did wrong, I even totally wiped everything back to just the bare metal Ubuntu system - I removed Zoneminder, and dropped the zm database to no avail. Thinking that it was some really really strange thing, I then removed MySQL and Zoneminder in total and then installed a clean ZM install. All for naught. The system still exhibits this issue from a fresh, clean install.
Here's a typical snippet of the events in the log showing that ZM is failing to analyze some of the monitors:
If I could, I wouldn't mind rolling it back to a version from a few months prior and leave it alone, but it seems there's no real easy way to do that.
Short story:
Help!
Regards,
Matt
2021-04-07 10:28:14 Breakroom: 45800 - Analysing at 0.00 fps from 0 - 0=0 / 1617805694.681905 - 1617802641.165685 = 3053.516220
2021-04-07 10:28:14 Front Hallway: 45800 - Analysing at 15.02 fps from 45801 - 45701=100 / 1617805694.661421 - 1617805688.003812 = 6.657609
2021-04-07 10:28:14 Breakroom: 45800 - Capturing at 15.01 fps, capturing bandwidth 492309bytes/sec
2021-04-07 10:28:14 Front Hallway: 45800 - Capturing at 14.99 fps, capturing bandwidth 471484bytes/sec
2021-04-07 10:28:13 Back Door: 46700 - Analysing at 0.00 fps from 0 - 0=0 / 1617805693.792868 - 1617802574.126049 = 3119.666819
2021-04-07 10:28:13 Back Door: 46700 - Capturing at 14.95 fps, capturing bandwidth 497836bytes/sec
2021-04-07 10:28:12 Breezeway: 45600 - Analysing at 15.03 fps from 45601 - 45501=100 / 1617805692.182630 - 1617805685.528825 = 6.653805
2021-04-07 10:28:12 Breezeway: 45600 - Capturing at 14.95 fps, capturing bandwidth 376377bytes/sec
2021-04-07 10:28:11 Master Control: 45600 - Analysing at 15.09 fps from 45601 - 45501=100 / 1617805691.988577 - 1617805685.362517 = 6.626060
2021-04-07 10:28:11 Master Control: 45600 - Capturing at 14.95 fps, capturing bandwidth 501139bytes/sec
2021-04-07 10:28:11 Lobby: 46500 - Analysing at 0.00 fps from 0 - 0=0 / 1617805691.701587 - 1617802591.443599 = 3100.257988
2021-04-07 10:28:11 Lobby: 46500 - Capturing at 14.99 fps, capturing bandwidth 510878bytes/sec
2021-04-07 10:28:11 Loading Dock: 46600 - Analysing at 15.04 fps from 46601 - 46501=100 / 1617805691.427238 - 1617805684.776688 = 6.650550
2021-04-07 10:28:11 Loading Dock: 46600 - Capturing at 15.05 fps, capturing bandwidth 515214bytes/sec
2021-04-07 10:28:08 Telecom Entrance: 46600 - Analysing at 14.96 fps from 46601 - 46501=100 / 1617805688.482486 - 1617805681.797649 = 6.684837
2021-04-07 10:28:08 Telecom Entrance: 46600 - Capturing at 15.01 fps, capturing bandwidth 501294bytes/sec
2021-04-07 10:28:08 Breakroom: 45700 - Analysing at 0.00 fps from 0 - 0=0 / 1617805688.042568 - 1617802641.165685 = 3046.876883
2021-04-07 10:28:08 Front Hallway: 45700 - Analysing at 14.99 fps from 45701 - 45601=100 / 1617805688.003812 - 1617805681.330805 = 6.673007
2021-04-07 10:28:07 Breakroom: 45700 - Capturing at 15.07 fps, capturing bandwidth 508973bytes/sec
2021-04-07 10:28:07 Front Hallway: 45700 - Capturing at 15.01 fps, capturing bandwidth 513055bytes/sec
2021-04-07 10:28:07 Back Door: 46600 - Analysing at 0.00 fps from 0 - 0=0 / 1617805687.102549 - 1617802574.126049 = 3112.976500
2021-04-07 10:28:07 Back Door: 46600 - Capturing at 15.02 fps, capturing bandwidth 506599bytes/sec
2021-04-07 10:28:05 Breezeway: 45500 - Analysing at 15.01 fps from 45501 - 45401=100 / 1617805685.528825 - 1617805678.866396 = 6.662429
2021-04-07 10:28:05 Breezeway: 45500 - Capturing at 15.01 fps, capturing bandwidth 376711bytes/sec
2021-04-07 10:28:05 Master Control: 45500 - Analysing at 14.94 fps from 45501 - 45401=100 / 1617805685.362517 - 1617805678.669643 = 6.692874
2021-04-07 10:28:05 Master Control: 45500 - Capturing at 15.08 fps, capturing bandwidth 511394bytes/sec
2021-04-07 10:28:05 Lobby: 46400 - Analysing at 0.00 fps from 0 - 0=0 / 1617805685.035258 - 1617802591.443599 = 3093.591659
2021-04-07 10:28:04 Lobby: 46400 - Capturing at 15.01 fps, capturing bandwidth 498057bytes/sec
2021-04-07 10:28:04 Loading Dock: 46500 - Analysing at 14.91 fps from 46501 - 46401=100 / 1617805684.776688 - 1617805678.069582 = 6.707106
2021-04-07 10:28:04 Loading Dock: 46500 - Capturing at 14.96 fps, capturing bandwidth 493753bytes/sec
2021-04-07 10:28:01 Telecom Entrance: 46500 - Analysing at 15.02 fps from 46501 - 46401=100 / 1617805681.797649 - 1617805675.140058 = 6.657591
2021-04-07 10:28:01 Telecom Entrance: 46500 - Capturing at 15.01 fps, capturing bandwidth 501678bytes/sec
Short story:
Help!
Regards,
Matt
