High CPU usage
xefil
Re: High CPU usage
Post by xefil »
Hello, where to look which FPS is registering ZM?
About the cams, they are:
2x 1080p direct stream analysis (no low-res stream, it hangs on two streams simultaniously - VstarCAM C16S)
2x 1080p for high stream, but with low res and linked monitor for MoDect.
Thanks, Simon
Re: High CPU usage
FPS should show in montage, unless you turned it off,
and camera views brought up by clicking on the camera thumbnail, or a less frequent one under function, where it's capturing.
Javoronok
Re: High CPU usage
Post by Javoronok »
Try to delete the apps you no longer need or force close those running for no reason.
vfredsasd
Re: High CPU usage
Post by vfredsasd »
Moreover, you can also delete or store some of your's computer data. This will free some space. If you are afraid of losing the data, you can easily restore it. Several platforms are offering these types of services. Personally, I used the RAID DATA RECOVERY platform when I needed to store some of my information. Just gave you some advice. At the end of the day, you decide what to do with it.
