I tried installing to try it out. After installation I get the error "User Authentication is not turned on. You cannot log in." How do I turn authentication on?
Thanks,
1.35.20 Ubuntu 20.04 "User Authentication is not turned on. You cannot log in."
Re: 1.35.20 Ubuntu 20.04 "User Authentication is not turned on. You cannot log in."
This is a development version...there may still be a problem getting access to the database.
So, try this:
viewtopic.php?f=42&t=30563#p120473
So, try this:
- bkjaya1952
- Contact:
No it is not working . It seems there is a problem in mysql configuration in the latest version of zoneminder master .dougmccrary wrote: ↑Tue Mar 09, 2021 1:21 amThis is a development version...there may still be a problem getting access to the database.
So, try this:
- bkjaya1952
- Contact:
The problem seems to be fixed in the latest zoneminder master realesed today.But ,there is a problem in creating USB camara monitors
I am also having problems with local USB cameras not streaming but seem to be capturing. Also my network cameras that use "Remote" as the Source Type are showing the same behavior.
latest should fix issues with non-ffmpeg monitor adding.
- bkjaya1952
- Contact:
