Hello, everybody, i was founded that ZM v1.35.14 Ubuntu 20.04 TLS didn't work correctly with Chrome browser, example not work buttons "Storage", not visualizing page "LOG", when create New monitor not all options aviable
More one screenshots.
Int Microsoft Edge all is work fine, except tab "Log", it not work even in Edge
Please modify something
ZoneMinder 1.35. and Log tab
- Screenshot_83.png (27.05 KiB) Viewed 1914 times
- Screenshot_82.png (15.21 KiB) Viewed 1914 times
- bkjaya1952
Re: ZoneMinder 1.35. and Google Chrome
What is the Linux version ?
I resolved problem with buttons and etc. but still not working tab "Log", when tap in, i see just "Please wait for load"
Ubuntu Server 20.04
Ubuntu Server 20.04
Just as an aside: don't think this is specific to Ubuntu 20.04 LTS, per se.
I'm running the same as you: latest master ZM v1.35.14 on an up to date Ubuntu 20.04 LTS server install. I don't see the same issues with Chrome.
- bkjaya1952
Purge zoneminder and re install .
Please refer the following link
https://bkjaya.wordpress.com/2020/11/16 ... cal-fossa/
The ubuntu install guide is at https://wiki.zoneminder.com/Ubuntubkjaya1952 wrote: ↑Wed Nov 25, 2020 11:25 am Purge zoneminder and re install .
1.35 is unstable. You should install 1.34 (even numbers are stable) if you are not prepared to use a dev version.
fastest way to test streams:
I do not see a connection in reinstalling zm. it works stably and all problems have been fixed, with the exception of the "Log" tab, the logs are written to the / var / log / zm folder, I can open them, but through the web interface they do not open writes what I wrote above
Re: ZoneMinder 1.35. and Log tab
1.35.14~20201129162543-focal
the server disappeared in the logs. more precisely server data
