Automatically Updated to 1.35.6 Lots of broken stuff
asprinkem90
Post by asprinkem90 »
I've never really had problems with the auto updates before but since this last one I have a lot of broken things. If I try to audit events report I get this error:
2020-09-11 01:18:27web_js6064ERRTypeError: minTime_element[0].form is nullzm/cache/skins_classic_views_js_report_event_audit-classic-1599780478.
I also seem to have issues with how it is calculating file size. It seems to max out at counting 29gb worth of events for all cameras.
I have also found I can't load events on mobile either as the web page gets cut off and wont load, and if i can manage to navigate to an event it wont play. It only works on PC now.
I tried doing an uninstall and reinstall but no luck. It pulled the old config right back in and I still have all the same issues.
Re: Automatically Updated to 1.35.6 Lots of broken stuff
1.35.6 is pretty old as far as the 1.35 series goes.
Furthermore it is considered bleeding edge. If you don't want things to break, stay on 1.34.
