Today, I have tested the latest Zoneminder-master 1.35.6~20200827192711-focal released 8 hrs back.
USB Camera monitor can't be added as the Source button and Storage button are not working.
Error Log
Usb camera monitor can't be added to the latest Zoneminder -master 1.35.6~20200827192711-focal [solved ]
- bkjaya1952
Re: Usb camera monitor can't be added to the latest Zoneminder -master 1.35.6~20200827192711-focal
See previous post ALERT UI
knight-of-ni wrote: ↑Thu Aug 27, 2020 9:34 pm Just a heads up that I have just begun layout changes to the monitor view.
What you see today is by no means the final result. Everything should work, but buttons, links, and alignment are not in their final state.
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
- knight-of-ni
- bkjaya1952
knight-of-ni wrote: ↑Fri Aug 28, 2020 12:43 pm Fixed:
https://github.com/ZoneMinder/zoneminde ... b16c160b68
Thank you very much ! Now it is working
After Mr knight-of-ni's Fix https://github.com/ZoneMinder/zoneminde ... b16c160b68 USB camera monitor can be added
Mr knight-of-ni's Fix was applied to the bkjaya1952/docker-zoneminder-php7.4-mysql8 at https://hub.docker.com/r/bkjaya1952/zon ... ker-latest
