Record audio only
Forum for questions and support relating to 1.35.x development only.
Chefboyrc9
Record audio only
Post by Chefboyrc9 » Thu Jul 30, 2020 9:12 am
I would like to just record the audio of some live streams, no video. It will be a 24/7 live audio recorder. I have searched online and I can't find anything that will work, except by using a dvr software and modifying it to ignore video. Has anyone tried this? Thoughts?
Re: Record audio only
Post by dougmccrary » Thu Jul 30, 2020 9:35 am
I've not actually tried it, but it appears to be trivial with ZM given the device's stream address, and doing as you suggest in the storage section.
Post by dougmccrary » Thu Jul 30, 2020 8:51 pm
Well, I tried it, and as the warning notes, it doesn't work.
Bummer.
Maybe vlc could decode and send audio-only out. I'm no vlc expert though...
Post by iconnor » Thu Jul 30, 2020 10:55 pm
I'll work on this in 1.35/1.36.
It has been on my todo list, to add a second url to get the audio from. While I am doing that I will make it possible to not have a video stream. Not sure what ramifications there might be, but logically it should be easy.
Post by dougmccrary » Fri Jul 31, 2020 6:04 am
Isaac, is that to-do list online somewhere?
Post by iconnor » Sun Aug 02, 2020 2:55 pm
You could consider the github issues list the todo list... but it's not maintained very well.
My personal todo list involves many other projects and changes depending on funding/emergencies/needs etc.
Post by dougmccrary » Sun Aug 02, 2020 9:15 pm
Right.
Thanks.
jameswilson
Post by jameswilson » Tue Aug 11, 2020 10:21 pm
Bear in mind in uk audio is a huge issue, recording especially, there are few good usage cases for it
James Wilson
Post by dougmccrary » Wed Aug 12, 2020 12:13 am
Curious about that jameswilson.
In this case, the audio can already be recorded with the video; does separating audio from video make the audio more of a problem?
