Page 1 of 2
Alarmframes (*-analyse.jpg) broken since 1.35.5~20200716162846-bionic
Posted: Tue Jul 21, 2020 7:46 pm
by tomcat84
Hi, since the last Update to 1.35.5~20200716162846-bionic all my Alarmframes (*-analyse.jpg) looks like the picture attached if I click on them.
If I click behind or before the frame I see them using PREV / NEXT but the detected area is not longer marked.
Any Ideas whats the reason for this problem ?
Folowing zoneminder related sources are in sources.list
deb http://ppa.launchpad.net/iconnor/zonemi ... ter/ubuntu bionic main
deb http://ppa.launchpad.net/savoury1/ffmpeg4/ubuntu bionic main
Re: Alarmframes (*-analyse.jpg) broken since 1.35.5~20200716162846-bionic
Posted: Tue Jul 21, 2020 9:51 pm
by iconnor
Please try today's image. I think I fixed this a few days ago
Posted: Tue Jul 21, 2020 11:29 pm
by nrbell
I'm still seeing this problem with 1.35.5~20200721160555-bionic.
Posted: Wed Jul 22, 2020 8:52 am
by tomcat84
same here.
Posted: Wed Jul 22, 2020 9:39 pm
by iconnor
I think I have it fixed. Building new packages now.
Posted: Thu Jul 23, 2020 12:06 am
by hybrid
Mine just updated and now I have a problem I hadn't seen before.
Jul 23 10:03:38 sarkmekawk zma_m3[3458]: ERR [zma_m3] [Failed to write frame image]
Jul 23 10:03:38 sarkmekawk zma_m3[3458]: ERR [zma_m3] [Can't open P#030|Y▒U/00147-capture.jpg for writing: No such file or directory]
I have checked my settings and the storage location still looks fine (/var/cache/zoneminder/events)
So I'm not sure what is causing this error. No events are currently being written to disk, but I can see the live camera fine.
Edit: this may not be just isolated to ubuntu:
viewtopic.php?f=42&t=29743#p116607
Posted: Thu Jul 23, 2020 3:02 am
by iconnor
Sigh.. I swear I've been testing...
just pushed a fix for the capture jpeg path problem.
Posted: Thu Jul 23, 2020 4:39 am
by hybrid
iconnor wrote: Thu Jul 23, 2020 3:02 am Sigh.. I swear I've been testing...
:lol:
All good now, thank you.
Posted: Thu Jul 23, 2020 6:14 pm
by nrbell
With 1.35.5~20200722224526-bionic, I'm now seeing alarm frames generated with proper images, but they don't show motion outlines. They show a red-outlined frame, but blobs are not outlined.
Posted: Thu Jul 23, 2020 9:18 pm
by iconnor
Check latest build. Should be > 2020072317
Mine is outlining.
It may be that the crashes were causing analysis images to not be written meaning it might be falling back to the capture image.
Posted: Thu Jul 23, 2020 9:57 pm
by nrbell
That's got it!
I still have to use 1.35.5~20200616165015-bionic because of the rotation problem I reported in github.
Posted: Thu Jul 23, 2020 11:50 pm
by hybrid
Jul 24 09:45:58 sarkmekawk zma_m3[1082]: ERR [zma_m3] [Can't open PȻ▒OV/00042-analyse.jpg for writing: No such file or directory]
Jul 24 09:45:58 sarkmekawk zma_m3[1082]: ERR [zma_m3] [Failed to write analysis frame image]
I'm still seeing this which is bizarre because certainly some images are being written during an event.
When I replay the event in the web interface, it seems to get to the end of the motion where it would be just writing the end frames and I see this in the logs:
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00172-capture.jpg: No such file or directory]
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00173-capture.jpg: No such file or directory]
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00174-capture.jpg: No such file or directory]
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00175-capture.jpg: No such file or directory]
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00176-capture.jpg: No such file or directory]
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00177-capture.jpg: No such file or directory]
Jul 24 09:47:37 sarkmekawk zms_e139040[3068]: ERR [zms_e139040] [Can't open /var/cache/zoneminder/events/3/2020-07-24/139040/00178-capture.jpg: No such file or directory]
So maybe it's writing fine until it starts writing the post event images?
Edit: hold up... another update. Will install that and test again.
Posted: Fri Jul 24, 2020 9:46 pm
by iconnor
Today's build SHOULD be solid.
Rotation is fixed.
Posted: Sat Jul 25, 2020 12:51 pm
by tomcat84
Hm after update to this version all Recordings have 0 Byte :(
And the log is spammed with
2020-07-25 14:53:59 web_php 5345 FAT Can't create frame capture images from video because there is no video file for this event at /var/cache/zoneminder/events/1/2020-07-25/836/ /usr/share/zoneminder/www/views/image.php 263
Posted: Sat Jul 25, 2020 8:10 pm
by Painter
I had the same issue with the previous update that i did earlier today.
For me it was just fixed with the fresh build 1.35.5~20200725145046-focal
