Version: v1.35.4
Installed on Ubuntu Server 20.04 LTS
From MySQL:05/24/20 23:13:09.282725 web_php[2003].ERR [192.168.1.121] [SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'ONVIF_URL' in 'field list'', statement was 'INSERT INTO Monitors (`Id`, `Name`, `Notes`, `ServerId`, `StorageId`, `Type`, `Function`, `Enabled`, `LinkedMonitors`, `Triggers`, `ONVIF_URL`, `ONVIF_Username`, `ONVIF_Password`, `ONVIF_Options`, `Device`, `Channel`, `Format`, `V4LMultiBuffer`, `V4LCapturesPerFrame`, `Protocol`, `Method`, `Host`, `Port`, `SubPath`, `Path`, `Options`, `User`, `Pass`, `Width`, `Height`, `Colours`, `Palette`, `Orientation`, `Deinterlacing`, `DecoderHWAccelName`, `DecoderHWAccelDevice`, `SaveJPEGs`, `VideoWriter`, `OutputCodec`, `OutputContainer`, `EncoderParameters`, `RecordAudio`, `RTSPDescribe`, `Brightness`, `Contrast`, `Hue`, `Colour`, `EventPrefix`, `LabelFormat`, `LabelX`, `LabelY`, `LabelSize`, `ImageBufferCount`, `WarmupCount`, `PreEventCount`, `PostEventCount`, `StreamReplayBuffer`, `AlarmFrameCount`, `SectionLength`, `MinSectionLength`, `FrameSkip`, `MotionFrameSkip`, `AnalysisFPSLimit`, `AnalysisUpdateDelay`, `MaxFPS`, `AlarmMaxFPS`, `FPSReportInterval`, `RefBlendPerc`, `AlarmRefBlendPerc`, `Controllable`, `ControlId`, `ControlDevice`, `ControlAddress`, `AutoStopTimeout`, `TrackMotion`, `TrackDelay`, `ReturnLocation`, `ReturnDelay`, `DefaultRate`, `DefaultScale`, `SignalCheckPoints`, `SignalCheckColour`, `WebColour`, `Exif`, `Sequence`, `ZoneCount`, `Refresh`, `DefaultCodec`) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' params:,Monitor-1,,0,0,Local,Mocord,1,,,,,,,/dev/video1,0,255,,1,,v4l2,,,,,,,,1280,800,4,1448695129,ROTATE_0,0,,,3,0,,,# Lines beginning with # are a comment
# For changing quality, use the crf option
# 1 is best, 51 is worst quality
#crf=23,0,0,-1,-1,-1,-1,Event-,%N - %d/%m/%y %H:%M:%S,0,0,1,20,0,5,5,0,1,600,10,0,0,,0,,,100,6,6,0,,,,,0,,-1,,100,100,0,#0000be,#1b46dc,0,1,0,,auto] at /usr/share/zoneminder/www/includes/database.php line 152
05/24/20 23:13:09.856026 web_php[2003].ERR [192.168.1.121] [Error saving new Monitor.] at /usr/share/zoneminder/www/includes/actions/monitor.php line 224
mysql> describe Monitors;
| Field | Type | Null | Key | Default | Extra |
| Id | int unsigned | NO | PRI | NULL | auto_increment |
| Name | varchar(64) | NO | | | |
| Notes | text | YES | | NULL | |
| ServerId | int unsigned | YES | MUL | NULL | |
| StorageId | smallint unsigned | YES | | 0 | |
| Type | enum('Local','Remote','File','Ffmpeg','Libvlc','cURL','WebSite','NVSocket','VNC') | NO | | Local | |
| Function | enum('None','Monitor','Modect','Record','Mocord','Nodect') | NO | | Monitor | |
| Enabled | tinyint unsigned | NO | | 1 | |
| LinkedMonitors | varchar(255) | YES | | NULL | |
| Triggers | set('X10') | NO | | | |
| Device | tinytext | NO | | NULL | |
| Channel | tinyint unsigned | NO | | 0 | |
| Format | int unsigned | NO | | 0 | |
| V4LMultiBuffer | tinyint unsigned | YES | | NULL | |
| V4LCapturesPerFrame | tinyint unsigned | YES | | NULL | |
| Protocol | varchar(16) | YES | | NULL | |
| Method | varchar(16) | YES | | | |
| Host | varchar(64) | YES | | NULL | |
| Port | varchar(8) | NO | | | |
| SubPath | varchar(64) | NO | | | |
| Path | varchar(255) | YES | | NULL | |
| Options | varchar(255) | YES | | NULL | |
| User | varchar(64) | YES | | NULL | |
| Pass | varchar(64) | YES | | NULL | |
| Width | smallint unsigned | NO | | 0 | |
| Height | smallint unsigned | NO | | 0 | |
| Colours | tinyint unsigned | NO | | 1 | |
| Palette | int unsigned | NO | | 0 | |
| Orientation | enum('ROTATE_0','ROTATE_90','ROTATE_180','ROTATE_270','FLIP_HORI','FLIP_VERT') | NO | | ROTATE_0 | |
| Deinterlacing | int unsigned | NO | | 0 | |
| DecoderHWAccelName | varchar(64) | YES | | NULL | |
| DecoderHWAccelDevice | varchar(255) | YES | | NULL | |
| SaveJPEGs | tinyint | NO | | 3 | |
| VideoWriter | tinyint | NO | | 0 | |
| OutputCodec | enum('h264','mjpeg','mpeg1','mpeg2') | YES | | NULL | |
| OutputContainer | enum('auto','mp4','mkv') | YES | | NULL | |
| EncoderParameters | text | YES | | NULL | |
| RecordAudio | tinyint | NO | | 0 | |
| RTSPDescribe | tinyint unsigned | YES | | NULL | |
| Brightness | mediumint | NO | | -1 | |
| Contrast | mediumint | NO | | -1 | |
| Hue | mediumint | NO | | -1 | |
| Colour | mediumint | NO | | -1 | |
| EventPrefix | varchar(32) | NO | | Event- | |
| LabelFormat | varchar(64) | YES | | %N - %y/%m/%d %H:%M:%S | |
| LabelX | smallint unsigned | NO | | 0 | |
| LabelY | smallint unsigned | NO | | 0 | |
| LabelSize | smallint unsigned | NO | | 1 | |
| ImageBufferCount | smallint unsigned | NO | | 100 | |
| WarmupCount | smallint unsigned | NO | | 25 | |
| PreEventCount | smallint unsigned | NO | | 10 | |
| PostEventCount | smallint unsigned | NO | | 10 | |
| StreamReplayBuffer | int unsigned | NO | | 1000 | |
| AlarmFrameCount | smallint unsigned | NO | | 1 | |
| SectionLength | int unsigned | NO | | 600 | |
| MinSectionLength | int unsigned | NO | | 10 | |
| FrameSkip | smallint unsigned | NO | | 0 | |
| MotionFrameSkip | smallint unsigned | NO | | 0 | |
| AnalysisFPSLimit | decimal(5,2) | YES | | NULL | |
| AnalysisUpdateDelay | smallint unsigned | NO | | 0 | |
| MaxFPS | decimal(5,2) | YES | | NULL | |
| AlarmMaxFPS | decimal(5,2) | YES | | NULL | |
| FPSReportInterval | smallint unsigned | NO | | 250 | |
| RefBlendPerc | tinyint unsigned | NO | | 6 | |
| AlarmRefBlendPerc | tinyint unsigned | NO | | 6 | |
| Controllable | tinyint unsigned | NO | | 0 | |
| ControlId | int unsigned | YES | | NULL | |
| ControlDevice | varchar(255) | YES | | NULL | |
| ControlAddress | varchar(255) | YES | | NULL | |
| AutoStopTimeout | decimal(5,2) | YES | | NULL | |
| TrackMotion | tinyint unsigned | NO | | 0 | |
| TrackDelay | smallint unsigned | YES | | NULL | |
| ReturnLocation | tinyint | NO | | -1 | |
| ReturnDelay | smallint unsigned | YES | | NULL | |
| DefaultRate | smallint unsigned | NO | | 100 | |
| DefaultScale | smallint unsigned | NO | | 100 | |
| DefaultCodec | enum('auto','MP4','MJPEG') | NO | | auto | |
| SignalCheckPoints | int unsigned | NO | | 0 | |
| SignalCheckColour | varchar(32) | NO | | #0000BE | |
| WebColour | varchar(32) | NO | | red | |
| Exif | tinyint unsigned | NO | | 0 | |
| Sequence | smallint unsigned | YES | | NULL | |
| TotalEvents | int | YES | | NULL | |
| TotalEventDiskSpace | bigint | YES | | NULL | |
| HourEvents | int | YES | | NULL | |
| HourEventDiskSpace | bigint | YES | | NULL | |
| DayEvents | int | YES | | NULL | |
| DayEventDiskSpace | bigint | YES | | NULL | |
| WeekEvents | int | YES | | NULL | |
| WeekEventDiskSpace | bigint | YES | | NULL | |
| MonthEvents | int | YES | | NULL | |
| MonthEventDiskSpace | bigint | YES | | NULL | |
| ArchivedEvents | int | YES | | NULL | |
| ArchivedEventDiskSpace | bigint | YES | | NULL | |
| ZoneCount | tinyint | NO | | 0 | |
| Refresh | int unsigned | YES | | NULL | |
96 rows in set (0.01 sec)
